who uses a Canon type II tele plus the 52WII polarizer plug in filter?
Started Aug 1, 2013 | Questions
joger
joger Veteran Member • Posts: 7,513
Hi guys,
I'd be very interested in sample images and your thoughts on using the 52WII circular polarizer on the 300 / 400 f/2.8 II or the 500 / 600 f/2.0 II (thoughts on the type (I) teles are also welcome.
I own the 300 f/2.8 L IS USM II and think of spending the 200 bucks for the filter
(sorry only the above mentioned lenses are of interest to me)
I have following questions:
1) How much is the image quality affected?
2.) How much light do you loose - is it in the range of 1-2 stops?
3.) Do you use it often or is it a waste of money?
4.) In which situations do you use the polarizer?
5.) Is the lens still water resistant with the filter in place?
6.) How good does the mechanism to control the effect work in the field?
thx for your answers in advance!!!
__________________________________
isn’t it funny, a ship that leaks from the top
ISO 9000 definition of quality: 'Degree to which a set of inherent characteristic fulfills requirements'
I am the classic “Windows by Day, Mac by Night user'
“The horizon of many people is a circle with zero radius which they call their point of view.” Albert Einstein
don't feed trolls - ignore them
rebel99 Veteran Member • Posts: 4,025
Re: who uses a Canon type II tele plus the 52WII polarizer plug in filter?
joger wrote:
Hi guys,
i do have the filter you mentioned for my 300 2.8II but i haven't used it yet, this may not be the answer you are looking for but i'll be interested in other photogs answer who have used it, as well i will let you know when i use mine but i am not sure when at this time!
cheerz.
oh, and good thing is that it fits my 600 f4II as well, i just tried it
cheerz.
joger
OP joger Veteran Member • Posts: 7,513
cheerz.
was expecting that
(would be ridiculous to have several differnt designs for such a simple filter (holder) system)
 joger's gear list:joger's gear list
Sony a7R IV Sony FE 135mm F1.8 GM Sony FE 35mm F1.4 GM Sony FE 50mm F1.2 GM Sony FE 14mm F1.8 GM +12 more
Franz Kerschbaum
Franz Kerschbaum Senior Member • Posts: 1,243
I use it from time to time on the 300 and 500mm mark I lenses. It is helpfull to reduce haze and reflection if the angle towards the sun is fitting. Its operation (i.e. rotation) is easy via a small toothed weel on its side. The light loss was not measured but in the range of typical polarizer which is 1.5 EV or so...
 Franz Kerschbaum's gear list:Franz Kerschbaum's gear list
Canon EOS 5D Mark II Canon EOS 7D Mark II Canon EOS M6 Canon EOS Ra Canon EOS R5 +30 more
joger
thx - do you happen to have sample images?
Franz Kerschbaum
Sorry no, would not be easy to single them out of my ten-thousands of pics since it is a "non-reporting" filter holder...   If I don't forget it I can do some extra new ones for you...
joger
Oh sure - non reporting - I know - are there any filters that are reported?
Would be great if you could post some.
Franz Kerschbaum
Here is a link with two pics with and two pics without pol at two different apertures of the 500/28IS L Mark I... (dev. in DPP)
https://dl.dropboxusercontent.com/u/23832864/5D3_500mm_pol.zip
joger
thx!!
Looks more like 2 - 3 stops loss of light
good example to see the difference!!
Franz Kerschbaum
the number of stops is tricky. for this I would have to picture unpolarized light which would not show the strong contrast and color enhancement as in the example... Unfortunately I was to quick this morning with the focus (focusing on different parts of the tree) so it is hard to judge the effect on sharpness but when looking carefully - because of the optical depth of the tree structures -  one can see that sharpness is not effected by the filter...
