Buying an emount f/2.8 zoom?
Started Jul 26, 2013 | Discussions
Alohaman Contributing Member • Posts: 576
SAR has a rumor about the 55-150 f/2.8 zoom e mount and asked would you buy one? I voted "no". Half voted "yes" and the other half voted "no" or "I don't know". I have the 55-210 zoom and usually use in outdoors during the day, so its f/4.5-6.3 doesn't bother me. I usually don't need a fast zoom outdoors.
Now if the rumored 16-xx zoom comes out as a constant f/2.8, I'd be the first to buy one. I have a Canon EPS 17-55 f/2.8. It's a great walk around and good indoors in low light.
So if both rumored lenses (55-150 and 16-xx) come out as f/2.8, which one would you buy?
 Alohaman's gear list:Alohaman's gear list
Sony a7R II Panasonic Lumix DMC-GX85 Olympus M.Zuiko Digital 17mm 1:1.8 Sony Vario-Tessar T* FE 16-35mm F4 ZA OSS Panasonic Lumix G X Vario 35-100mm F2.8 OIS +1 more
docvale Regular Member • Posts: 215
Re: Buying an emount f/2.8 zoom?
I would say that if I had to invest serious money to expand my Nex, a 16-50/80mm f2.8 would be the only thing I'd consider (apart of the external EVF).
A 55-150mm zoom wouldn't be interesting to me: the only time I felt my 55mm were too short was at a zoo! But it might be interesting to others...
 docvale's gear list:docvale's gear list
Sony Alpha NEX-5N Sony E 18-55mm F3.5-5.6 OSS +3 more
academytim Regular Member • Posts: 206
Definitely the 16ish to 55ish 2.8. I used a 17-50 2.8 Tamron with my A700 and it hardly ever came off of the camera. My sel3518 is now my primary lens, and I hardly ever use the kit zoom. I faster normal zoom would become my walk around lens with the 35 being used strictly for low light situations.
 academytim's gear list:academytim's gear list
Sony a6300 Sony E PZ 18-105mm F4 G OSS Sigma 16mm F1.4 DC DN (Sony)
kcamacho11 Senior Member • Posts: 1,529
That 55-150 is going to cost quite a bit.
If the 55-200 is $349, I would suspect the 55-150 F2.8 to go for at least $999 (and that's being optimistic).
captura Forum Pro • Posts: 26,131
Re: Get the Sigma 1 F1.8 DC HSM8-35mm ?
- http://www.dpreview.com/previews/sigma-18-35-1-8
- Made in Japan
-Canon mount should be adaptable to NEX with all controls intact.
"Sigma's choice of F1.8 as maximum aperture isn't a coincidence; it means that the lens will offer the same control over depth of field as an F2.8 zoom does on full frame. What's more, it will also offer effectively the same light-gathering capability as an F2.8 lens on full frame."
  • 18-35mm focal length (27-53mm equivalent)
  • Extremely fast F1.8 maximum aperture
  • Ring-type ultrasonic focus motor with full-time manual override
  • Initially available in Canon EF, Nikon F and Sigma SA mounts
http://photorumors.com/2013/07/21/dxomark-on-the-sigma-18-35mm-f1-8-dc-hsm-a-best-performing-aps-c-zoom/
DxOmark tested the Sigma 18-35mm f/1.8 DC HSM A lens for Canon mount ($799) and labeled it as the "best performing APS-C zoom":
"With the introduction of this model, Sigma has the best performing zoom of its type. The DxOMark score of 25 points puts well ahead of both the full-frame Canon EF 24-70mm f/2.8 L II USM and the Tamron SP 24-70mm f/2.8 Di VC USD (though bear in mind those lenses become the equivalent to a 38-112mm on a Canon APS-C body)."
Read more on PhotoRumors.com: http://photorumors.com/2013/07/21/dxomark-on-the-sigma-18-35mm-f1-8-dc-hsm-a-best-performing-aps-c-zoom/#ixzz2aAjFXT5C
 captura's gear list:captura's gear list
Sony a7 Sony Alpha NEX-7 Olympus OM-D E-M10 Canon EOS Rebel SL1 Canon EF 50mm f/1.8 STM +3 more
Exactly, and since the only time I really use the telezoom, I'm outside and don't really need the extra light, the expense wouldn't make it viable for me. Maybe if I was doing indoor wedding photography or something.
I would pay 500ish for a 17-50 2.8 emount. Anything more than that wouldn't be worth it for me.
blue_skies
blue_skies Forum Pro • Posts: 11,607
The Sigma APO 50-150mm F2.8 EX DC OS HSM has an msrp of $1,650, and seems to be selling around $1k. I can't imagine a Sony version being any cheaper than that.
Check the link, the Sigma weighs in at 1.4kg (47oz), 200/85mm (77mm thread).
Henry
Sony Alpha NEX-6 Sony a6000 Sony a5100 Sony a7 II Sony a7R II +36 more
SinSilla
SinSilla Regular Member • Posts: 124
You use the 55-200 mainly indoors, thats why it's slow aperture doesnt bother you? Weird
I'd be all over a fast and stabilized 16-80, a 55-150 is Not exactly what i was looking for.
But could still end up being the next best thing if there won't be a good normalzoom. There are enough good lenses between 16mm and 60mm available.
 SinSilla's gear list:SinSilla's gear list
Fujifilm X-T10 Fujifilm XF 35mm F2 R WR
sportyaccordy Forum Pro • Posts: 12,729
Depends on how small it is and how much they wanted for it. So realistically probably not. I would not want something like the Canon 17-50 2.8 hanging off my NEX, that seems pointless.
I'd rather a good fast wide prime actually. If someone made a 20-24 f/1.4-2.0 with AF for <$600 I would do it. There's other avenues to the same FOV/speed as well, if weight isn't an issue. A cheap FX zoom + Lens Turbo would equate to something like a 2.0-2.5 zoom in some cases. So there are different ways to do it.
 sportyaccordy's gear list:sportyaccordy's gear list
NEX-5T Sony a7R II Canon EOS 5D Mark IV Rokinon AF 50mm F1.4 FE Samyang 14mm F2.8 IF ED MC Aspherical +6 more
Who said they usually use the 55-210 indoors?
forpetessake
forpetessake Veteran Member • Posts: 4,892
That would be a perfect concert/sports/events lens. The current 55-210 is pretty unusable for all that -- it's slow, soft, with unreliable focusing, so-so image stabilization -- I finally got rid of it. I'm currently using manual Nikon 75-150/3.5, and it's a marvelous lens, very sharp, reasonably fast, and the size of 55-210. If Sony could make something similar or better, they can easily charge $1000-1500 and they will be flying off the shelves. But I'm afraid, all quality stuff is reserved for A-mount cameras, so if they start producing compact A-mount, that will be the place to be.
That zoom for A-mount + the required adapter would make the entire package very bulky, though...
SinSilla
The Op said that.
EinsteinsGhost
Primes instead
I would rather see development of a 200/2.8 and a 300/4 prime for E-mount especially if the next generation AF is designed for action/sports photography. For a zoom, 50-200/4 may do it within size and cost constraints.
Sony Cyber-shot DSC-F828 Sony SLT-A55 Sony Alpha NEX-6 Sony 135mm F2.8 (T4.5) STF Sigma 70mm F2.8 EX DG Macro +12 more
Re: Primes instead
Respectfully, I disagree.
I see such large lenses on a DSLR.
The Op said that.
"I have the 55-210 zoom and usually use in outdoors during the day, so its f/4.5-6.3 doesn't bother me. I usually don't need a fast zoom outdoors."
Maybe worded a little funny, but he definitely said he uses it primarily outdoors.
I agree though, I don't want a large, bulky native telezoom. The 55-210 is perfect for what I use it for. A fast normal zoom would be beneficial though, again...as long as it isn't too bulky.
PeterNMIF Senior Member • Posts: 2,438
But the rumor is about a "G" lens. Right?
This implies it will be pretty high quality.  That would be nice, in spite of the likely high price.
 PeterNMIF's gear list:PeterNMIF's gear list
Panasonic Lumix DMC-LX5 Olympus E-M1 Olympus OM-D E-M5 NEX5R Sony Alpha NEX-6 +1 more
zackiedawg
zackiedawg Forum Pro • Posts: 30,557
No on both, but give me a 2x TC and I'm in...
Don't have a need or interest in either lens.
But if they would be kind enough to offer an e-mount specific, matched 2x TC that can pair with the 55-150mm F2.8 to help it become a 110-300mm F5.6, then I might well be interested.  If the 2x was of very high quality, G series, specifically designed to be paired with that lens, it could produce very good image quality and at F5.6 still be plenty fast for 300mm in daylight.
I'm still waiting and hoping for something in the 300-400mm optical focal range for e-mount - prime, zoom, whatever!
Justin
galleries: www.pbase.com/zackiedawg
 zackiedawg's gear list:zackiedawg's gear list
Sony a6300 Sony DT 18-250mm F3.5-6.3 Sony E 18-55mm F3.5-5.6 OSS Sony E 55-210mm F4.5-6.3 OSS Sony E 16mm F2.8 Pancake +22 more
EinsteinsGhost
Re: Primes instead
I have one such lens designed for full frame and you'd be hard pressed to find a smaller f/2.8 lens that zooms to tjat FL. That lens is Minolta 200G.
Zoom, larger sensor and larger aperture is a recipe for larger lens.
SinSilla
The Op said that.
Oops, my fault then. My brain somehow left "out" away when i read that.
