7D - 70D - 7D2
Started Jul 21, 2013 | Discussions
Birdman7
Birdman7 Senior Member • Posts: 1,058
7D - 70D - 7D2
Prior to the release of the EOS 70D, many would have thought that the specs of that camera, which were posted on some online rumour sites, could well have belonged to be that of the 7D2,  especially taking into account the similarities in sensor performance of the 5D3 compared to its predecessor.  Canon's 'incremental update' policy probably also gave credence to beliefs those rumoured specs indeed belonged to the 7D2.
In hindsight, those rumours were slightly off the mark,  although the other ramblings of a 24MP APS-C camera being tested in the field could well be the sensor used in the upcoming 7D2. The 70D, seems to have been fitted with some interesting performance features, such as the 7D AF module, customisation and 7FPS. Its quite a comprehensive feature list for a xxD body, and areasonable improvement from a camera to whom its closely related (7D) but not meant to replace.
Which brings us back to the question, are any inovative features going to be incorporated into the 7D2 that we dont know of, apart from the suspected WIFI, GPS, perhaps dual-pixel focus etc?  The release of the 70D may be a sign that Canon has heard past complaints from its customers  and will release a sucessor to the 7D with a substantial feature list Improvement
We wont have to wait too long!
Bird Photography workshops
Digiscoping courses
Birdwatching tours
Specialising in Spain & Morocco
www.aviantours.net
 Birdman7's gear list:Birdman7's gear list
Canon EOS-1D Mark IV Canon EOS 5D Mark II Canon EOS 7D Canon EF 50mm F1.8 II Canon EF 85mm f/1.2L II USM +7 more
Canon EOS 5D Mark III Canon EOS 70D Canon EOS 7D
RedFox88 Forum Pro • Posts: 29,535
Re: 7D - 70D - 7D2
Says, who?  I think just you.  The 70D's less than 100% OVF, less than 8 fps, SD card, non magnesium body, and flip-out LCD are all red flags to not be a 7D2.
My guess is neither of those go into the 7D2.  Those are gimmicks that usually don't go into a Pro model.
Just look at the 5D3.  1D-series AF and 2 added fps.
Canonrumors suggest no 7D2 shipped this year, although it might be announced.  If it were to be announced this year shipping next year I would not think it be announced until October or November.
Pritzl Senior Member • Posts: 1,474
Re: 7D - 70D - 7D2
Gimmicks or not, I'd be highly surprised if dual-pixel AF and WiFi at least don't make it on to the 7D mark II.
 Pritzl's gear list:Pritzl's gear list
Fujifilm X10 Canon EOS 70D Fujifilm X-T2 Canon EF 50mm f/1.4 USM Tokina AT-X Pro 12-24mm f/4 DX II +9 more
PC Wheeler
PC Wheeler Forum Pro • Posts: 17,902
Re: 7D - 70D - 7D2
+1. I expect the 7D2 will have all the features of the 70D, but exceed the 70D in areas where the 7D is already a pace setter. Specifically, I expect:
  • The sensor for dual-oixel AF
  • 100% OVF coverage
  • Programmable tracking parameters exceeding those in the 7D
  • Articulated LCD
  • 20-24 megapixel sensor
  • Same weather proofing as 7D -- or better
  • Dual-memory card slots: CF & SD/SDHC/SDXC
But I'm less convinced about wi-fi and GPS, likely because I have cameras with those features and don't use them
Phil
 PC Wheeler's gear list:PC Wheeler's gear list
Canon PowerShot ELPH 330 HS Panasonic ZS100 Sony RX10 IV
WilbaW
WilbaW Forum Pro • Posts: 11,595
Re: 7D - 70D - 7D2
The way I see it, if the 70D were a replacement for the 7D it would have spot AF (and the other advanced PD AF features that didn't carry over).
 WilbaW's gear list:WilbaW's gear list
Canon EOS 60D Canon EOS 7D Mark II
skanter
skanter Forum Pro • Posts: 22,504
Re: 7D - 70D - 7D2
60D has spot AF, I would assume 70D has it as well.
Sam K., NYC
 skanter's gear list:skanter's gear list
Sony a6300 Sony E 55-210mm F4.5-6.3 OSS Sony E 10-18mm F4 OSS Sony E 16-50mm F3.5-5.6 PZ OSS Sony E 35mm F1.8 OSS +2 more
WilbaW
Re: 7D - 70D - 7D2
skanter wrote:
60D has spot AF
What page in the instruction manual tells me how to do that?
Can you find it in the instruction manual?
Alastair Norcross Veteran Member • Posts: 7,090
Re: 7D - 70D - 7D2
Sam K., NYC
Really? I've never seen a mention of it in posts or the DPR review of the 60D. But, I don't have the 60D, so I'm not an expert.
Edit: I've just double-checked the DPR reviews of the 7D and the 60D. On the specifications page, under AF point selection, spot focusing is specifically mentioned for the 7D, but not for the 60D. It's a feature of the AF module in the 7D. AFAIK the 60D's AF is the same as the 50D, which I had, and which definitely didn't have spot AF.
Alastair
http://anorcross.smugmug.com
Equipment in profile
 Alastair Norcross's gear list:Alastair Norcross's gear list
Canon G7 X II Canon EOS 7D Mark II Canon EOS M6 Canon EOS M6 II Canon PowerShot S100 (2000) +26 more
Karl Gnter Wnsch Forum Pro • Posts: 11,408
Wrong on both accounts!
skanter wrote:
60D has spot AF,
The 60D doesn't have spot AF because the AF sensor doesn't provide it.
And here you assume wrongly: Although the AF sensor does provide the necessary hardware the 70D does not allow Spot-AF!
regards
Karl Günter Wünsch
 Karl Gnter Wnsch's gear list:Karl Gnter Wnsch's gear list
hires Regular Member • Posts: 429
Re: Wrong on both accounts!
What is the difference between center point and spot AF?  My 550D has center point as did my 30D.  From this thread it sounds like the 7D might be the better camera for bird photography with the 400 5.6?
Jerry-astro
Jerry-astro Forum Pro • Posts: 14,754
Center point vs. spot AF
Spot AF is to autofocus as spot metering is metering.  It enables you to focus accurately in an area that might be very busy with potential targets.  Think, for example, of shooting a small bird sitting on a branch surrounded by foilage.  A standard AF sensor is large enough that the surrounding foilage may confuse it and in a situation where you're shooting long with thin DOF, you will not get accurate focus acquisition on the target.  With spot AF, the AF sensor is smaller and will have the capability of picking a smaller, high contrast area and hopefully eliminate surrounding clutter that could throw off focus.
I haven't had the opportunity or need to use it extensively on my 7D, but for those few times where I've needed it, it's been invaluable.  There were definitely cases where standard AF simply could not properly acquire a target and the only way to accurately nail the target would be manual focus or spot AF.
Center point simply defines one of the points available for AF.  If you have spot AF enabled on the 7D, it can be used with any of the AF points you've selected including the center point.
 Jerry-astro's gear list:Jerry-astro's gear list
Fujifilm X-H1 Carl Zeiss Touit 2.8/12 Fujifilm XF 10-24mm F4 R OIS Fujifilm 16-55mm F2.8R LM WR Fujifilm XF 100-400mm F4.5-5.6 OIS WR +1 more
Limburger
Limburger Veteran Member • Posts: 7,841
Re: 7D - 70D - 7D2
Sam K., NYC
Hi Sam,
Could it be you mistaken weighing exposure for locked af point(s) in evaluative?
Cheers Mike
 Limburger's gear list:Limburger's gear list
Fujifilm FinePix X100 Canon EOS 7D Sony a7 Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 70-200mm F4L USM +3 more
Re: 7D - 70D - 7D2
  • 100% OVF coverage
  • Articulated LCD
Don't think same weather sealing can happen with a flip-out LCD.
Phil
Mark B. Forum Pro • Posts: 26,439
Re: 7D - 70D - 7D2
You could be right about GPS, but I think wifi is going to become as standard as AF.
I don't know that Canon has ever announced a camera late in the year to have it released the following year;  typically those announcements have been in Jan/Feb with the camera released only a month or 2 later at the most.
Mark
Re: 7D - 70D - 7D2
  • 100% OVF coverage
  • Articulated LCD
So because youdon't use wifi and GPS, you think Canon won't put them in the 7D2? I think you overestimate your importance
wihakowi Regular Member • Posts: 242
Re: 7D - 70D - 7D2
One O-ring and done. A lot simpler than weatherproofing a lens/body connection or even the jacks under the flippy rubber boots.
 wihakowi's gear list:wihakowi's gear list
Canon EOS 7D Canon EOS 600D Canon EF 50mm f/1.4 USM Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F2.8L IS II USM +8 more
elfroggio
MOD elfroggio Veteran Member • Posts: 3,005
Re: 7D - 70D - 7D2
Somehow Olympus did it very successfully with the E3 and the E5. Many people have reported it as "waterproof".
There are many youtube videos "floating" around (pun intended) showing the E3 and the E5 being dunked in water or in the shower or water being poured on.
http://www.sritch.com
Street Photography: The Dogs of Vancouver, BC
Frederik Paul Regular Member • Posts: 105
Re: 7D - 70D - 7D2
The 7D Mk. II will be a stunning camera full of current and new technology that will bring this class to a new level. Canon simply waits for Nikon to blink first. And I hope that the 7D Mk. II will get a built-in vertical grip with more powerful powerpack to rival the 1Dx's AF. So, basically a mini 1Dx.
Re: 7D - 70D - 7D2
If it has a built-in vertical grip (which it won't have), how would it be a mini 1DX? Wouldn't it be the same size as the 1DX, more or less?
Alastair
Birdman7
OP Birdman7 Senior Member • Posts: 1,058
Re: 7D - 70D - 7D2
Im pretty convinced it will not have a built-in vertical grip, but I DO HOPE the grip will have a rubber gasket on the inner - outer region to protect from dust & moisture ingress, a simple feature which non of the other vertical grips have.
Digiscoping courses
Birdwatching tours
www.aviantours.net
