How to remove broken GGS screen protector
Started Jul 18, 2013 | Discussions
Greg Lovern Senior Member • Posts: 1,613
About a year and a half ago I bought a used K-7. It had a "GGS" screen protector on it.
Now that screen protector has broken. I looked up how to remove it on the GGS website, but they say to use a "plastic flake" which I suppose they included with the screen protector. However the person who sold the K-7 to me did not include anything like that:
http://www.ggs020.com/en/products/sp2.html
Any suggestions on how I can remove the broken GGS screen protector without mangling the K-7?
BTW the force that broke it was very slight; I didn't even realize what had happened until later. Much less force that their website seems to indicate. Basically I just stepped backward into stove handle. I normally carry it diagonally on a shoulder, and it had somehow twisted around backwards behind me. I heard a very faint "crack" but it was so faint and I had applied so little pressure that I didn't think anything of it until a couple minutes later when I noticed the broken glass. Nothing like that ever happened to my *ist D in eight years with no screen protector.
Thanks,
Greg
Brand loyalty is a character flaw.
Pentax *ist D Pentax K-7
NotSteve Regular Member • Posts: 240
Re: How to remove broken GGS screen protector
Your caution is well founded. I had read a sad and ironic post somewhere about someone trying to remove a glass protector. They cracked it taking it off but the force and angle of the sharp edge was such that the protector damaged the screen it was meant to protect. I guess that means try not to flex it upwards.
Someone says dental floss works:
http://www.dpreview.com/forums/post/36087181
 NotSteve's gear list:NotSteve's gear list
Pentax K-5 Pentax Q Pentax K-01
sentro Senior Member • Posts: 1,242
Try using dental floss.
Jenna B
Jenna B Senior Member • Posts: 2,700
A thin guitar string or cheese wire should also work - dental floss tends to fray when I try to do similar (removing glued-on plastic emblems and such)
Hope you get it sorted
 Jenna B's gear list:Jenna B's gear list
Pentax K100D Pentax K-5 II Pentax smc DA 55-300mm F4.0-5.8 ED Tamron SP AF 90mm F/2.8 Di Macro Pentax smc DA 18-135mm F3.5-5.6ED AL [IF] DC WR +2 more
Gary2010
Gary2010 Contributing Member • Posts: 573
I second the dental floss.  I have removed several of them with it.  It just takes a little patience and a few pieces of floss.  I use a back and forth cutting motion with the floss under a corner and work across the protector.
 Gary2010's gear list:Gary2010's gear list
Olympus Tough TG-4 Nikon D500 Nikon D850 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF-S Nikkor 200-400mm f/4G ED VR II +13 more
OP Greg Lovern Senior Member • Posts: 1,613
Thanks - removed it with dental floss
Thanks all, I removed it with dental floss. It was very easy; hardly any back & forth motion required. Three baby wipes later all the goo is removed too.
Now the only problem is that the dust that I had thought was behind the screen protector, is in fact behind the screen itself.
Greg
