Re: Is it really the off-sensor ADC?
TTMartin wrote:
In the thread titled dynamic range confusion David Hull wrote:
texinwien wrote:
Sensor Dynamic Range vs. Camera Dynamic Range
This windowing of DR is occurring because the camera doesn't deliver the full DR that the sensor is capable of at base ISO; rather it is limited by the rest of the electronics -- the ISO amplifier and ADC. The sensor has a DR of about 14 stops, while the amp/ADC have a bit less than 12 stops DR. There are about two stops of extra dynamic range to be had in DSLR's that is currently being thrown away by limitations of components other than the sensor.
This appears to be exactly the case, a point I have been making for quite a while. From a sensor perspective what Canon is putting in there appears to be every bit as good as what Sony is making:
Nikon D600: QE=53%, Read Noise = 2.8e-, FWC=76231, DR~14.7 stops
Canon 6D: QE=50%, Read Noise 1.6 e-, FWC=76606, DR~15.5
Source: Bob's Sensorgen site (which is ultimately DxO, I guess)
People need to stop slamming the Canon sensor technology because it is actually pretty darn good. This also says the front end noise figure of ISO amp is pretty good as well. The demons are hiding in the rear end of it as Mr. Martinec points out. The sensor is not where bodies are buried in these things.
Thanks for putting this up, I had not seen it before – good stuff.
With the above showing that the 6D sensor is actually capable of producing 15.5 EV of DR it's time to again ask if it is really the off-sensor ADC?
It has been repeated ad nauseum that the off-sensor ADC is dumping tons of read noise in Canon RAW files.
If it were ADC inefficiencies, it should manifest itself as clipping not as read noise. Or in the off chance it was introducing read noise, that read noise should not decrease as ISO increases. Nor should the amount of read noise vary as much as it does from one Canon camera to another.
Why would this be the case?
If some other component were introducing read noise prior to the ADC, then the read noise should not decrease as ISO increases.
A camera is just like a satellite receiver. Let's say you have a LNA (low Noise Amplifier) in the front end that has a noise figure of 1 dB (very low noise) and its gain is 40 dB. This amplifier is followed by a subsequent stage that has a noise figure of 25 dB (lots of noise). In this case the effective noise figure of the cascaded stages will be 1.107 dB.
If you now reduce the gain of that first stage to 5 dB (think of that first stage as the ISO amplifier and you are turning its gain down) the effective noise figure of the chain is now 20 dB.
This is known as Friis Formula or more generally as the "cascade Noise Figure Formula" it is fundamental receiver lineups -- this is radio engineering 101.
http://en.wikipedia.org/wiki/Friis_formulas_for_noise
Looking at the 5DIII, you have 22 MPix sampled at 6 FPS, so the converter needs to run at 132 MSPS. In this camera there are 8 channels so each of the converters will be running at 16.5 MSPS. They are probably using 20 MSPS or 40 MSPS converters. You can look these up yourself if you want (ADI-9257 might be a good one). You can look at the data sheet for these things and you will see that the SINAD rating is in the range of 73-75 dB (depending on the speed and quality of the part). This equates to an ENOB [ENOB=(SINAD-1.76)/6.02] of 11.8 to 12.2 dB.
Basically what you are doing is amplifying the front end noise to the point where it dominates over the back end noise when you increase the gain. Let’s say that you have a very weak signal but your front end is very quiet (very low noise) you pass that directly (unamplified) to a second stage that has 10 times the noise. That second stage noise will be dominant and will swamp out your signal and your noise. Now let’s say you increase the gain of that very quiet amplifier to 1000. Now the noise (and the signal) out of that first stage is 100 times the noise of the second stage. The SNR of the first stage dominates and the noise of the second one is rendered irrelevant.
Essentially you have a noise floor of 74 dB in the back end, it will never get any better than that.
None of the scenarios involving the off sensor ADC should manifest itself as increasing read noise, as you lower the ISO.
But, then where is that read noise coming from?
I've been ridiculed for my suggestion of where that tons of read noise comes from.
Is there anyone now willing to have a mature discussion on the subject?
