nx300 problem
Started Jul 17, 2013 | Questions
tuncayt New Member • Posts: 3
nx300 problem
i used my camera in the morning .After 10 minutes when i try to use again. Camera not started. İ changed and used another original battary. nothing happend. So how can i solve this problem ? when i charged again red indicater seems 5 seconds and dissapear.Camera doesnt start
Samsung NX300
jennyrae Senior Member • Posts: 2,690
Re: nx300 problem
you try on 10 sec and off camera without battery. clean contacts of battery and open camera battery slot and try wipe with dry cloth. insert battery and start charge. not turn on camera. see if red light turn on for charge. when full, red light is off then try turn on camera.
OP tuncayt New Member • Posts: 3
Re: nx300 problem
thank you for answer.  i tried your ideas step by step. now camera turns on then closing after 5 seconds. i dont know how to solve it
Marco Zaitsev New Member • Posts: 1
Re: nx300 problem
Same problem with my nx300, have you solved the issue?
EvanEgan New Member • Posts: 1
Re: nx300 problem
I had a very similar issue to you. My wife was using the camera and then later that day we get a constant black screen, but if you listened carefully you could hear the shutter movement if you tried to take a picture. I thought that something might have corrupted software wise but couldn't access anything because of a dead screen. Today in a last ditch effort I went for the obvious answer. I removed the back plate following these directions. ( www.ifixit.com/Guide/Samsung+NX300+Back+Panel+Assembly+Replacement/36896 ).  Once I had separated the camera I unplugged the back panel from the Motherboard and very carefully re plugged it into the motherboard.  I put a battery in, and turned it on a viola the screen turned right on as if nothing had ever been wrong with it.  I resecured the tape on the connector and closed the camera up and now it works without any issues.  If it happens again I might use a electronics safe glue to permenantly attach it but that will be a last ditch effort.  Hope this helps.  Ohh and before I forget.  The redlight for the battery turning off a few seconds after you plug it in to charge is because it is fully charged already.  I tried both of my batteries once the screen worked and both were fully charged.
