What does a green flashing light mean on the NX300 when the camera is off?
Started Jul 16, 2013 | Questions
jack Hoggard
jack Hoggard Contributing Member • Posts: 825
I received my new NX300 yesterday, and when I inserted the battery, with the camera still off, the light on the rear of the camera started flashing green, and the word "SAMSUNG" was flashing on the screen.  I called Samsung, and after a review, they said it was new to them, and I should exchange the camera.
Has anyone seen this?
I was thinking it may be a faulty battery, so I looked for a local dealer.  Not only do none in the Northern California area carry the 1130 battery, but neither do Samsung or Amazon.
I'm reluctantly returning it.  (I asked this question on this forum yesterday an, hoping for some easy solution, but it was unanswered and then removed.  (Strange)
jaxupra
 jack Hoggard's gear list:jack Hoggard's gear list
Olympus Stylus 1 Sony Xperia Z Ultra Google Nexus 7 +1 more
Samsung NX300
viking79
viking79 Forum Pro • Posts: 14,157
Re: What does a green flashing light mean on the NX300 when the camera is off?
Yeah, that sounds like something is faulty and it is stuck in a reboot loop?  I haven't seen that before.  The few times I do get strange behavior I just pop the battery out and stick it back in.  I don't think I have had to do that with my NX300 yet.
Sorry to hear that!  I really like my NX300 so far.  I think you can also use the 1030 battery from the NX200, NX210, etc, but I haven't tried.
Eric
Sony a7R Samsung NX1 Samsung NX 30mm F2 Pancake Samsung NX 85mm F1.4 ED SSA Samsung NX 60mm F2.8 Macro ED OIS SSA +5 more
jack Hoggard
OP jack Hoggard Contributing Member • Posts: 825
Thanks.  I may get a 1030 to try before I return it.  Except for that constantly flashing light, the camera appears to work fine.
jaxupra
viking79
Try a different memory card too, or maybe try pulling the memory card out and see if it still does it?  Like you can take photos, etc?
Eric
tecnoworld
tecnoworld Veteran Member • Posts: 7,232
Try also a firmware upgrade to 1.13.
 tecnoworld's gear list:tecnoworld's gear list
Samsung TL500 Samsung NX100 Samsung NX200 Samsung NX300 Samsung NX1 +15 more
TJL LTFF
TJL LTFF Senior Member • Posts: 1,728
I use as a backup a 1030 non-Samsung battery that I had for an NX200; works fine in the NX300. It doesn't get as many shots, but it's a lot cheaper.
Good luck with the green light.
 TJL LTFF's gear list:TJL LTFF's gear list
Sony RX1R II Samsung NX1 Samsung NX500 Samsung NX 30mm F2 Pancake Samsung NX 18-55mm F3.5-5.6 OIS +10 more
seph Regular Member • Posts: 188
I have just tried a NX300 in a local shop about an hour ago, with my own BP1030 and SD (they couldn't find the original battery !). I use both of them with my NX1000 flawlessy.
And guess what ? When I put my battery in the camera (powerswitch OFF), the green light began to flash, while a Samsung logo started flickering on the screen.
I then switched it on, and it worked flawlessy. What an improvement when compared to the NX1000 ! A bit on the expensive side, but what a camera !
After my trying session, I tried to switch it off, but it started flickering and flashing again.
It's supposed to be a new and unsued unit, as they only put the batteries in the cameras on demand (prevent from stealth) and the salesman told me I was the first customer to ask about the NX300.
 seph's gear list:seph's gear list
Fujifilm XF10 Nikon Z6 Nikon AF Micro-Nikkor 60mm f/2.8D Nikon AP-F 70-300mm F4.5-5.6E Nikon Z 24-70mm F4
tecnoworld
Finally the voice of the truth. I laugth when I read ppl not even testing the nx300 and stating it's almost the same as previous gen.
Imo nx300 over nx200/210/1000 is much a bigger step forward then nx200 was over nx100. Ok, perhaps the sensor changed less, but the overall performance, features and usability improved esponentially.
If you like nx1000, you'll adore nx300. If you don't like nx1000, you'll probably like nx300, if you are not biased.
The thing is that I used to buy my NX cameras (and lenses) very cheap, as they don't sell that much.
I've had my NX10+30mm for about 350€, my NX1000+20-50 for about 290€. But now, about 700€ for the NX300 (I wish it was the awaited NX30 - NX300 electronics in a NX20 body - for that price), it's something else ! And the first unit I saw for real seems to be a defective one !
But as I can't bear my NX1000's sluggishness (RAW only user), I may have to do a step forward !
tecnoworld
when I had to decide whether to buy the nx300 or wait, I was also very scared by its price. I had very good deals both on nx100 (250€ including a sef15 flash) and the nx200 (290€). The nx300 was more than twice. Then I thought that this is such a good camera that all the captures I would have missed with the other two would have made for the price difference.
and I didn't regret one single moment.
(unknown member) Veteran Member • Posts: 6,192
Is there a greater love than Technoworld and his NX300? I cannot imagine it.
tecnoworld
ahaha I actually love this camera more than I did for any camera I owned since the yashica fx-3
I think that I finally found the perfect camera for me, after a lot of search. if only it had a high res evf and a larger buffer, I couldn't see a reason for any other camera.
jack Hoggard
I'm glad that someone else saw the flashing green light.  I'm also glad that you used a good battery, so that the problem is identified as in the camera.  I returned mine, but may end up getting another one - it has everything I'm looking for.  Thanks for the posts.
jaxupra
MOD Taffy Veteran Member • Posts: 5,020
Well I too love my NX 300. I cannot see anything wrong when someone is pleased with their camera purchase. All to often on these boards, all one hears about is people complaining that the camera that they have bought id nothing but a load of rubbish. I think the NX 300 is the best camera that I have ever used. I came to the NX 300 via, Canon and Olympus SLR's, to Fuji digital compacts and bridge cameras, to a Samsung GX 10, (a clone of the Pentax K 10), which is a DSLR. My Samsung NX 300 with its 18-55 m.m. kit lens beats all of these. This NX 300, is the first. (and so far, only), camera that i have been totally happy using in jpg mode. I do NOT say this lightly, as up until the NX 300, I only shot RAW images, and processed them in Silkypix, in order to get high quality images. The NX 300 I use jpg mode, there is no need for RAW, and all the rigmarole that is involved in processing each image.
Have a good day.
Regards, Allan.
jennyrae Senior Member • Posts: 2,690
what love? i remember techno saying nx200 is still better than nx300 and nx300 is only small improvement from old model. laugh.
nx200USER1 Senior Member • Posts: 1,097
lol @ jennyrae
I chimed in late with my remembering the green flashing light on the nx200 happens when in display save mode. In the nx300 menu, is there a 'display save' and 'power save' option and do their setting of 'OFF' and 'OFF' make any difference?
tecnoworld
Hehe, at those times I was actually referring to the poor buffer for raw continuous shooting, where even the old nx200 gphas a significative edge (8 vs 5 files captured in a row).
This is still an open issue, that has been faced in almost all thenreviews I read about the nx300. I think it's really odd to make a camera that can capture almost 9fps and let it record just 5 frames. I still hope samsung can improve this via fw.
Nevertheless the nx300 is gorgeous for many, many aspects and if it had a strong buffer it would be perfect. My hope for a future nx camera is a buffer able to store # at least # 10 raw files, but better 20. Fast memory is very cheap, now, and a big company like samsung could install 2gb of such memory like it uses for smartphones and tablets.
understand about raw buffer and could use improvement. I say however that 8fps raw buffer in nx200 point less because of process delay and inability to use camera for long time which make use of nx300 practical. I buy fast sandisk 90MB/s card next week because people say it make recording really fast for their camera and video. maybe it make raw recording faster and more than 6fps on nx300. I use now uhs 1 45MB/s shooting about 6 fps. no complain since I use only about 4 burst. enough for capture action.
GrasyaWafa New Member • Posts: 1
Hello Jack Hoggard
I'm not use to posting or joining to any forum but i would like to share how I manage to stop the blinking think when Samsung Nx300 is off. It's not the battery or defective camera but it's on the setting
Just simply go to SETTING-SOUND then TURN OFF AF Sound and that's it It works on me
Louza New Member • Posts: 2
I have exactly the same problem. Setting AF sound to off does not help. Any other proposals how to solve the issue?
