Lens Issues with canon 70-200 f/4 IS
Started Jul 10, 2013 | Questions
scottyf123 New Member • Posts: 1
hey guys my canon 70-200 has issues i believe with back or front focusing. when i use the lens i notice its really soft around edges and sometimes one part of an image is in focus and the rest of the image isnt. it is really noticable at wide appertures f/4 etc. where the images arent even usuable. just want to know if anyone has had issues like this and whats the best course of action to get this fixed. ive attached an image to show what the images come out like.
f/4 as you can see image looks blurry
MisterPootieCat
MisterPootieCat Veteran Member • Posts: 3,123
EF70-200 f/4 IS
Something is amiss for sure. You might try taking some test shots with IS turned off. This lens is very sharp, even when used at f4. Or maybe try another camera body if you have access to one as a way to eliminate suspects.
 MisterPootieCat's gear list:MisterPootieCat's gear list
Canon EOS 40D Canon EOS 300D Canon EOS 7D Canon EOS 80D Canon EF 50mm F1.4 USM +24 more
canuck dave
canuck dave Veteran Member • Posts: 3,202
Re: Lens Issues with canon 70-200 f/4 IS
You have camera/operator movement. I suspect nothing is 'wrong' with your excellent lens!
PEPhoto New Member • Posts: 6
I had the same problem as you. I recommend you send it to a Canon service centre near you. In my instance they were not able to repair, as it would have been more expensive to repair it than the lens was worth. I had found that the right side was really soft but the let side was good, on occasion that would vary the left side would be soft and the right sharp. The 70-200F4 IS lens is one of the sharpest lenses out there, in mine somehow the elements got misaligned.
rebel99 Veteran Member • Posts: 4,025
try a tripod and manual focus and perhaps different F stops for start
cheerz.
happysnapper64 Veteran Member • Posts: 5,421
I am a relative beginner, & I have this lens on a 7D, & have to say, this is one of the worst images I have seen with this lens. I was thinking, maybe a focus issue, but the whole of the frame is fuzzy. How long have you had the lens, is this typical of the result you are getting? 1/1600 should all but eliminate camera shake, but as one poster has suggested, try it on a tripod, man focus, IS turned OFF, mirror lock-up & timer delay.
lee uk.
There are old pilots, & there are bold pilots, but there are no old bold pilots.
"I'm so fast, when I turn off the light, i'm in bed before the room gets dark" The great Mohamed Ali.
 happysnapper64's gear list:happysnapper64's gear list
Canon EOS 5D Mark II Canon EOS 7D Sigma 150mm F2.8 EX DG OS Macro HSM Sigma 17-50mm F2.8 EX DC OS HSM Canon EF 24-105mm f/4L IS USM +6 more
pixseal
pixseal Veteran Member • Posts: 4,061
I agree with another responder that there is both subject and camera movement in your example.  Do you have another example with a static subject?
That said, my 70-200/4L IS did develop a problem.  After several years of flawless use, the lens unexplainedly could not produce a sharp image.  I can best describe the results as a "lens baby" effect (much worse than your example).  I sent it in to Canon for an out-of-warranty repair - for $200 they replaced some parts and fixed it.
 pixseal's gear list:pixseal's gear list
Canon EOS R7 Canon EF-S 10-22mm F3.5-4.5 USM Canon EF 100mm F2.8L Macro IS USM Canon EF 500mm f/4.0L IS II USM Canon EF 100-400mm F4.5-5.6L IS II +14 more
Peter too Contributing Member • Posts: 909
What's the black patch in the bottom left? If it was something close, like a finger, the camera might have tried to focus on that and failed to focus at all.
Lemming51
Lemming51 Forum Pro • Posts: 15,278
There is nothing in focus in that pic, left right up or down.  Doesn't look to me to be misalignment, nor front/back focus.  Agree with Peter Too, it looks like it's at minimum focus distance, maybe due to the obstruction at lower left.
The "nervous" bokeh and misty-ness look like the result of a protective filter (get rid of it) and/or condensation on the filter or lens.
IMHO, YMMV
Unapologetic Canon Apologist
 Lemming51's gear list:Lemming51's gear list
Canon EOS 40D Canon EF 50mm F1.8 II Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 70-200mm f/2.8L USM Canon EF-S 55-250mm f/4-5.6 IS STM +5 more
Jos van Eekelen Regular Member • Posts: 463
Do a few controlled tests of static subjects, with different aperture/shutter speed combinations. Preferably on a stable tripod. A flat object (paper, brick wall) will show whether the focus is off or not. Also try taking a picture with details close and far away to see if there is any place in the frame that is sharp. Use the Canon software to see which autofocus point was used. There are lots of things you can do to evaluate the lens before deciding to send it to Canon.
The 70-200 f/4 IS has a very good reputation but it may be defective.
 Jos van Eekelen's gear list:Jos van Eekelen's gear list
Canon EOS R6 Canon EF 24-105mm f/4L IS USM Canon RF 50mm F1.8 STM
