When extreme high ISO is better than nothing: a rundown on my experiences shooting ballet
Started Jul 5, 2013 | Discussions
Petroglyph
Petroglyph Veteran Member • Posts: 6,096
Re: When extreme high ISO is better than nothing: a rundown on my experiences shooting ballet
joseluismx wrote:
Petroglyph wrote:
I think you're shots are pretty good. Have you added a denoiser, such as Topaz, to your LR flow. I use it for any ISO shots with 4 digits or over. I've even used it on 6D shots with ISO 25600 (I'll see if there is one I can post on the forum). With Topaz you can probably get away with 12800 on the K5II (just a guess) but that would give you another stop of shutter and it recovers some detail you'll appreciate. If you decide to go FF choose a Canon 6D (standard ISO range is 100 - 25600) expanded to ISO 102400. They have the 85mm f/1.2 L (pricey) or the excellent 135mm f/2 L (might be perfect for what you're doing). On this cam set the min shutter to 1/320 and forget about it (1/640 for basketball).
Cheers.
I use only Lightroom's noise reduction slider. Haven't tried third party denoisers, yet. I'll give them a shot and see if there's significant improvement.
For me they are much better than LR's version.  Be sure to experiment with the detail recovery slider if you get topaz.  It converts to one of the Photopro RGB palettes as a 16-bit tiff before going to work.  Don't do any sharpening (or let the cam) until it has done its work.
Cheers.
 Petroglyph's gear list:Petroglyph's gear list
Sony a7R II Zeiss Batis 25mm F2 Zeiss Batis 85mm F1.8 Samyang 20mm F1.8
(unknown member) Contributing Member • Posts: 873
Stage light is stage light, as is. Wonderful stuff.
citrontokyo Contributing Member • Posts: 812
Hi Brooke,
I believe you gave me some advice in the past on this subject that really helped me get my head around this problem, and helped me rethink what I was doing.
In return, I'd like to add my own 2 cents on this discussion. What I've learned is as follows.
1. Perhaps the most important thing when shooting ballet is the metering. Spot meter the subject's leotard because for one thing it is larger than the face, and for another it will help you to get an accurate measure of what NEEDS to be exposed accurately. It is also the most likely object on the stage to end up with blown highlites that have to be corrected after. If the dancer is wearing anything white it must be metered. Generally speaking, you do not need to expose to for the background, and if you do, you will overexpose the face and/or leotard because they are most likely lit differently.
This is key because it saves you from unnecessarily setting the camera to high ISO, low shutter speed or underexposure.
2. Perhaps the most important thing when shooting is metering. Spot meter...oops! I guess that's all I wanted to say. After metering, everything that has been mentioned above can be tinkered with, but without an accurate meter, we're just tinkering with a mistaken exposure and wasting our time.
Anyway, I'm enjoying this discussion, and Brooke I admire your work. I'll just add a couple of my own shots to illustrate the point:
 citrontokyo's gear list:citrontokyo's gear list
Pentax K-5 Pentax smc DA 55-300mm F4.0-5.8 ED Pentax smc DA 21mm F3.2 AL Limited Pentax smc DA 70mm F2.4 AL Limited Pentax smc FA 43mm F1.9 Limited +4 more
Love this shot.
Jim in Hudson Senior Member • Posts: 2,501
Brooke -- very nice shot. Curious about one thing (and I suspect you answered this elsewhere)... do you meter each shot or do you do a spot reading off a dancer and then just go with that for a bunch of shots in manual? Thanks.
 Jim in Hudson's gear list:Jim in Hudson's gear list
Pentax K-3 Fujifilm X-T3 Sigma 17-70mm F2.8-4 DC Macro OS HSM | C Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Tamron 17–70mm F2.8 Di III-A VC RXD +1 more
Trevor G Veteran Member • Posts: 6,580
Bernie3 wrote:
Try keeping the ISO lower and take an underexposed shot and raise it in PP. Here is my image shot at ISO 800, f 8, 1/125 sec no PP. Shot with K-5 and DA 50 -200.
Why are you shooting f8?
Cheers
Trevor G
Silkypix tutorials at: http://photo.computerwyse.com
I shoot enough stage to know my starting point will be EV7 or 8, based on Sunny 16. Then its experience & histogram feedback. Sometimes, I have to stop down if the costumes are light & reflective. I'll get familiar with lighting cues and whether I need to go up or down a stop, usually with ISO. Always in manual and I just don't use the camera meter. I do carry a little Digisix meter and use it sometimes, especially if its staged shots for promotion. Since my first K10 in 2007, have only shot DNG's, K5 DR is a wonderful thing.  P
Shooting dance is a passion and I'm very lucky to a great relationship with a local conservatory.  75 to 80 percent of what I shoot in rehearsal & performance, I delete for any number of reasons.  I was late, I was early, dancer out of character, the move wasn't very good, my framing was wrong, I was too tight, etc etc.   Had a great time recently shooting an aerialist for Cirque du Soleil.  I was on a press pass, editorial only and finally got permission for the performer to show on her sites.  Same technique but way up.   Tanya Burka
I don't know of any way to meter this.
Looks like you're finding what works for you. You're right about exposing for the dancer, not the background.   Its exactly what I do in studio where the background is bright windows.  Let the background go, expose for the dancer.
Fantastic ethereal-feeling shot. Great example of metering priority.
