Poll: what is your preference? 24-70 II @28mm or Zeiss 2/28 ZF
Started Jul 4, 2013 | Polls
Rick Knepper
Rick Knepper Forum Pro • Posts: 17,870
I took my new 5D3 out to my usual spot earlier today to compare against the D800E using a single lens for both, the Zeiss 2/28mm ZF, considered one of the sharper Zeiss lenses made for the Nikon/Canon mounts. The Zf model has a native mount for Nikon cameras and for the Canon shots, I used an adapter. At the conclusion of the shooting, I threw the 24-70 II on the 5D3 to shoot a set to compare to shots taken a few weeks on the 5D2. Back at the hacienda, I discovered I had left the zoom at 28mm so this has now become a slightly different comparison.
5D3 + 24-70 II ISO 100, f5.6, 1/500
5D3 + Zeiss 2/28mm ZF ISO 100, f5.6, 1/500
In addition to these smallish images (downsized by Flickr), you can download unscathed, full size jpegs, tiffs and RAWs at the following link:
https://www.box.com/s/lll7qcz1bbf0ur8j9h9z
If your answer is number 3, Baam!!, you may have already come to the realization of how good the 24-70 II is.
 Rick Knepper's gear list:Rick Knepper's gear list
Pentax 645Z Canon EOS 5DS R Fujifilm GFX 50S Sony a7R IV Pentax smc D FA 645 55mm F2.8 AL (IF) SDM AW +11 more
POLL
I prefer the image made with the 24-70 II
52.7% 29  votes
I prefer the image made with the Zeiss 2/28 ZF
20.0% 11  votes
I can't tell the difference.
27.3% 15  votes
  Show results
bhollis
bhollis Veteran Member • Posts: 3,931
Re: Poll: what is your preference? 24-70 II @28mm or Zeiss 2/28 ZF
Can't get the link to work.  And, IMO, the posted images are too small to allow for a meaningful comparison.
 bhollis's gear list:bhollis's gear list
Sony RX1R Canon EOS 5D Mark IV Nikon Z7 Canon EF 70-200mm F4L IS USM Canon EF 24-70mm F2.8L II USM +5 more
Rick Knepper
OP Rick Knepper Forum Pro • Posts: 17,870
Please copy and paste link in the OP
For larger sizes and RAW, please copy/paste link in the Original Post to your browser.
Rick Knepper, photographer, non-professional, shooting for pleasure, check my profile for gear list and philosophy. TJ said, "Every generation needs a new revolution".
Rick Knepper
Thanks for looking (or attempting to). Copy/paste the link to your browser. DPR has an issue with it for some reason. The site where my files are located is Box.net. Quite respectable.
cale johnson
cale johnson Regular Member • Posts: 121
From what I can tell, the Zeiss lens is sharper. There are color differences too, there's more blue in the Canon pic.
Zeiss Sample
Canon Sample
 cale johnson's gear list:cale johnson's gear list
Canon EOS 5D Mark II Canon EOS 7D Canon EF 50mm f/1.2L USM Canon EF 85mm F1.8 USM Canon EF 24-105mm f/4L IS USM +2 more
salamander1 Senior Member • Posts: 1,427
can't tell the difference.  24-70 f/2.8L II is an amazing lens.
Rick Knepper
That it is.
cale johnson
Re: That it is.
I can't tell if you want us to believe that the Canon is an amazing lens or if you want us (the viewers) to believe that it is capable of identical results.
If the first, I agree the Canon lens is a great lens considering that it is a zoom lens. Albeit an expensive zoom.
But if you are searching for the answer, is it capable of identical results and you want us to believe it is...I'm sorry to say, it is not as sharp as the Zeiss. That's not conjecture, that's a fact.
(Of course, this assumes that each lens was used to it's maximum potential in your test, which I am simply incapable of determining.)
Note: I have 30 years of experience in the sale of high-end commercial offset printing. I've looked at enough detail and done enough press checks over the years to know that; a) most people don't really look at images carefully enough, and b) getting the best possible image sometimes isn't worth the bother. YMMV.
rebel99 Veteran Member • Posts: 4,025
thank you for posting these comparison photos, i have both lenses (zeiss 21mm f2.8 and 100mm f2.0) on canon mount so it will help my expectation from both lenses, as i haven't used neither extensively as of yet! i have noticed that perhaps the metering in your photo with canon 24-70 f2.8II could be off because it seems a bit darker or under exposed!
i have 2 zeiss lenses (as i have mentioned above), 21mm f2.8 distagon and 100mm f2.0 makro, and i clearly see the advantage goes to zeiss optics when i compare my result. it seems like zeiss lenses have their own signature and characteristic that are unmatched, whether it is sharpness or micro contrast, but they are distinct, imho. i just received my canon 24-70 f2.8II and i haven't used it seriously yet but from short period that i have used it casually, i have noticed the iq of this lens to be on par with zeiss lenses in every aspect. i have plan to use these lenses for the purpose of comparison shortly and hopefully be able to post my result for participants in these forums soon
cheerz.
ed rader Veteran Member • Posts: 9,068
Re: That it is.
lenses only get so sharp and the 24-70L II is easily among the sharpest I have owned. have you tried the lens? also the zoom is weathersealed, has ring USM and is prime like thoughout the range.
to me, that makes the zeiss waaaay overpriced.  looks the poll may even agree with me :-).
 ed rader's gear list:ed rader's gear list
Canon EOS 80D Canon EOS 5D Mark IV Sigma 15mm F2.8 EX DG Diagonal Fisheye Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM +4 more
cale johnson
Re: That it is.
Nope, have tried either lens. I thought we were judging the two sample pictures.
Agree that other factors are also important when choosing a lens, see comment "b" in my note.
Agree that others are weighing-in in favor of the Canon lens, see comment "a" in my note.
Rick Knepper
Re: That it is.
Sorry Cale. I was going to respond to your post above but I wanted to use it as a bump too.
My objective was to publish a comparison and let others decide for themselves. Perhaps I did potential lookers a disservice by being so flip. Whenever these types of comparisons are posted, you always get someone who will say "I can't tell the difference" so I was offering a bit of logic to attach to the observation i.e. so if the image looks the same to you, which lens gives you the extra value-added?
I am not searching an answer. I've purchased and used enough lenses to know what I am looking for nearly the instant I see it. I posted because others may be searching for an answer.
Okay. Cool.
What part of the image did you compare to one another? The street in the distance is the center of the lens.
You know something? I totally agree with both of these things and I would think this comparison would illustrate what you've said quite brilliantly.
Rick Knepper
cheerz.
I eagerly await this comparison. My Zeiss 28 isn't the lofty 21mm but it is considered quite good but I'd like to see this though the mismatch in FL will be a problem for some.
I bracketed these shots so that I would have a variety of shutter speeds to match as closely as possible. I was able to obatin the same aperture and shutter speed for both images but the one still turned out a bit darker than the other. if you downloaded the RAWs and turned everything to zero and matched WB, the 24-70 II still turns out darker (or should we say more contrasty?). Perhaps the coatings are doing this.
Rick Knepper
cheerz.
Okay this was a terrible sentence above but DPR will not let me edit the post.
My Zeiss 28 isn't the lofty 21mm but it is considered quite good. I'd like to see this though the mismatch in FL will be a problem for some.
cale johnson
Re: That it is.
Okay. Cool.
In my first post I offered links to the two pictures, each enlarged to offer detail. Having done that, I now see the obvious difference between the two pictures when I observe them even casually. In printing, the effect of being drawn instantly to a "flaw" or item of "brilliance" could turn the client's mood from one extreme to the other. The more experienced clients being the most resilient.
I was drawn to your thread because I just purchased a zeiss 135 for my D7100. Problem is, it's very expensive and if I open the box, I'll forfeit 15% in restocking fees should I do the smart thing and return it. Your thread has only added confusion to my situation.
Re: That it is.
i agree with you zeiss lenses being a notch above canon lenses in micro contrast and sharpness, but i have to give credit to canon for introducing the new 24-70mm f2.8II. i just got mine and i have to admit that the new 24-70mm f2.8II is an outstanding lens, comparable to zeiss lenses in every aspect. i would like to mention canon's excellent tse lenses, such as tse 17mm and tse 24mm for landscape and architecture as well
cheerz.
Rick Knepper
Re: That it is.
Okay. Cool.
Just to provide full disclosure, I have not printed an image in at least 8 years so I am unfamiliar with the issues.
Sorry again, I responded to the 2nd post without going back to the first but I do not think it registered upon me at the first reading that those were links. You've given folks inclined to look at this comparison a good starting point within the image to make their comparisons. However, 99% of my photography does not include such obvious straight lines.
The reason I upload different variants of the images in this type of comparison is so that folks can apply their typical PPing regimen to the images at the image size they commonly use. It is possible that those special wunderkinds on PS and other editing software can mitigate the difference to a degree in some parts of the image on characteristics involving sharpness, color and contrast.
I do not want to color this thread with any more personal opinions but I will say that differences between the two images are more visible in certain small areas of the image at the size I generally use making the difference of the majority of area within the image a big Meh. I would advise folks to look at the images at 100% and at the sizes they commonly use.
Your situation is tough. Nikon doesn't have a 24-70 II equivalent in terms of IQ. I own the 24-70G and no matter the camera, D3x or D800E, whatever Canon camera I use in combination with the 24-70 II, 5D2 or 5D3, the images from the Canon combo appears sharper, crisper to my eye. That's all lens there. I do not own any Nikon lenses in the range you have concerns about.
I recently divested all of my Canon primes save the specialty lenses I feel have a leg up on Nikon, the TSE 17mm & 100L Macro for reasons I have discussed ad neaseum in many other threads. The reason I kept my entire bevy of Zeiss lenses in the ZF mount (18, 25/2.8, 28, 35/2 & 50/2 Makro) was because they ARE decidedly sharper to varying degrees than the Nikon equivalent FL in the 14-24G & 24-70G zooms I own with the sad exception of the 25/2.8.
My opinion only but I wouldn't buy an expensive 135 for a crop camera unless it was the very reasonably priced 135L. If you own a FF or if you have plans to acquire a FF, then the Zeiss 135 could be a difference-maker. On crop, you are cropping away much of the image area the Zeiss 135 would address otherwise and which contributed greatly to its big price.
billythek Veteran Member • Posts: 5,260
I can't see much difference between them, even in the crops supplied by another poster.  Yeah, some slight differences, but nothing very significant to me.  Note that I am not all that impressed with either photo, but I guess that is because we are looking at the results of RAW files with minimal processing.
- Bill
 billythek's gear list:billythek's gear list
DxO One Canon EOS 5D Mark III Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM
MirekE
MirekE Contributing Member • Posts: 925
Zeiss lenses have certain signature, but it does not show in every image. It does not show in the comparison either. Apart from the difference in exposure, the pictures look the same to me. WRT resolution - I think that with most lenses of this calibre, they are good enough for the print sizes I make and for the resolution of my camera. One thing that bothered me on the 28 was purple fringing. the Canon might be better in this respect.
Rick Knepper
These are not intended to pose as finished photos. Other than ACR's standard 25%/.05 radius  sharpening (that I use for capture sharpening), there is zero processing (other than to matched WB of several degrees). I've supplied jpeg, tiff and RAW for those who wish to apply their own standard PPing regimen. It's good to know that the thought crossed your mind. In my next posted comparison, I will mention the PPing or lack thereof so that the intention is clear.
