GH3 & 100-300, St. Thomas Airshow, AFC & burst modes
Started Jul 2, 2013 | Discussions
hifi
hifi Senior Member • Posts: 2,569
5
Yesterday, I went to a big airshow in St. Thomas (Ontario, Canada).  These are all with my GH3 and the 100-300 lens.  Most of these are in high-speed burst, AFC mode.  The GH3's AFC mode can do sports, and quite well too.  The trick is, that it is very challenging with the EVF - I had help by using a RDS (red dot sight) attached to the hot shoe.  The RDS makes it much easier to track motion.  I posted a thread a short while back showing some results on birds with good success.  I found it easier with the planes (being larger).  These are some, but check my gallery for more.  Thanks for looking!
 hifi's gear list:hifi's gear list
Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GX85 Panasonic Lumix DC-G9
Martin.au
Martin.au Forum Pro • Posts: 14,339
Re: GH3 & 100-300, St. Thomas Airshow, AFC & burst modes
Great shots.
My RDS should be here in the next day or so. I'm going to try and photograph some swallows.
Which RDS did you get?
 Martin.au's gear list:Martin.au's gear list
Olympus OM-D E-M5 Olympus E-M1 II Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G Fisheye 8mm F3.5 Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ +7 more
hifi
OP hifi Senior Member • Posts: 2,569
I got one made by Tasco.  Picked it up from a local store in the sporting goods section for $50.  Works very well.  Also got the photosolve mount to attach it to the hot shoe.
Digital Dick Senior Member • Posts: 2,379
In the USA you can go to jail for a very long time for pointing a laser at any airplane in flight. Does your red dot violate US law?
Dick
 Digital Dick's gear list:Digital Dick's gear list
Olympus OM-D E-M5 Olympus E-M5 II
hifi
Dick
http://en.wikipedia.org/wiki/Red_dot_sight
A red dot sight does not project any light or laser at the target.  The light is only visible to the user and is reflected back by the front element.
aljudy Senior Member • Posts: 1,208
Would you please post a picture of the GH3 with the RDS on it?
Amateur Photographer of family mainly
 aljudy's gear list:aljudy's gear list
Panasonic Lumix DMC-GH2 Panasonic Lumix DMC-GH4 Panasonic Lumix DMC-GX85 Panasonic Lumix G Vario 100-300mm F4-5.6 OIS Panasonic Lumix G Vario 14-42mm F3.5-5.6 ASPH OIS +9 more
Sorry, my bad - didn't understand how they worked.
Dick
hifi
Taken with a smartphone, not high quality - but you get the idea.
yslee1 Contributing Member • Posts: 640
6 FPS works for you?
I do agree that the EVF is like a really poor SLR from the early days. I assume the RDS has parallax correction controls?
Barry Stewart
Barry Stewart Veteran Member • Posts: 9,147
Digital Dick
Dick,
Thanks for taking the hit  for me. I didn't know how those red dot sights worked either.
Barry
 Barry Stewart's gear list:Barry Stewart's gear list
Olympus E-1 Olympus E-M1 Olympus E-M5 II Olympus Zuiko Digital ED 50mm 1:2.0 Macro Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD +6 more
hifi
Yup. Actually, the 6 fps spec. is only in AFS or manual focus... When in AFC, the burst speed slows down to 4 fps. For BIF's, a higher burst in AFC would be nice but I have done quite well at 4. For the planes, 4 fps was good. I would like something higher, but for now I can live with it, but maybe in the next body that spec. will improve (GH4 possibly?) For more static sports shooting (example, locking focus on home plate in baseball, a player staying in roughly the same spot, etc.), 6 fps is quite fast IMO.
The EVF is arguably the weakest point on the GH3 now.  Still, it does work very well for landscape, family, and most general types of photography.  I am happy with it.  It is just for fast motion tracking that it really lets the whole camera down.  With the RDS, I think the camera works just as well for sports as most entry or mid level DSLRs.
I am not sure if I understand about the RDS and parallax correction controls, but it adjusts with little adj. screws so you can calibrate it with the lens.  When I am looking through it, if I shift my head up/down or sideways, the red dot stays in the center.  I assume that is what you mean?
Stefan Sobol Regular Member • Posts: 307
Since the RDS is mounted above the lens (by some distance) the spot displayed will also offset from the centerline of the lens. Therefore the view of the sight and the view of the lens is slightly different. The closer the subject is to the camera the bigger an issue this becomes. Since you are taking pictures of objects that are quite some distance away, the difference in the two fields of view is very slight.
Trevor Carpenter
Trevor Carpenter Forum Pro • Posts: 19,436
I have tried an RDS in the past but decided it was more trouble than it was worth.  What I don't understand is how RDS users know they have focus.  I get the information from my EVF
Nice pictures , love the B17
Panasonic G85 Panasonic Lumix DC-G9 OM-1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S +1 more
hifi
I guess it just takes practice. The more I used it, the better I got at following motion and being able to track. Now, after using the RDS, I could not imagine trying to go back to the EVF for fast motion.  It is a little odd at first looking only through the RDS, not seeing any exposure or focus values, but I found that I was so busy just concentrating on tracking the subject, and letting the GH3 do its thing.
When doing BIF's I turn on the focus confirmation beep. It is not totally necessary, but helps. For the planes, I did not bother with the beep: the planes are typically large enough that they fill a good portion of the screen for the camera to lock focus on. My focus was set to single point, centre, with the box enlarged 2 times. That worked like a charm, and I had very few OOF pictures for the whole airshow. Just my experience...
Thanks!
hifi
Ok - excellent explanation, I understand now.  Thanks!
Martin.au
Yay. Mine arrived today. It's sitting in the post office.
savonie
savonie Senior Member • Posts: 2,652
Enjoyed your pics-
I am interested in the RDS - What is needed to attach it to the hot shoe?
Where did you get the attachment?
I'm in London Ont so could probably go where you went-
Monty
 savonie's gear list:savonie's gear list
Olympus E-3 Olympus PEN E-P5 Olympus PEN-F Olympus E-M1 II Olympus Zuiko Digital 14-54mm 1:2.8-3.5 II +5 more
hifi
savonie wrote:
Enjoyed your pics-
Monty
I had it shipped to me from the US. Here is the link to the company:
http://www.photosolve.com/main/product/xtendasight/index.html
The RDS is the Tasco model from Canadian Tire.
savonie
Thanks for the reply-
