TS-E on the cheap? For architectural photography
Started Jul 2, 2013 | Questions
AmateurArchitectural New Member • Posts: 19
I shoot architecture, largely exteriors, for work but not for income. Mostly photos I only use at PowerPoint resolutions and for book/article illustrations. Really large prints are an occasional treat.
I really want to move to a TS-E, firstly because I much prefer to compose and problem-solve in-camera rather than in PS, and secondly because I loved my old Nikon shift and want to play with tilt too.
My question is, is it too bad a waste of a beautiful lens (17mm TS-E) to put it on a 7-year-old EOS400D?
- Will I be able to focus through the 400D’s little view-finder?
- Is the image quality in camera too low to be worth it?
My alternative is to shell out another £1000+ to get the 6D and the 24mm TS-E instead (17mm on FF the angles are too un-natural-looking for my kind of architecture), and consign my EFS to spare.
Any advice welcome!
(If you want to see the sort of thing I shoot, there's some here: http://www.flickr.com/photos/barnabas_calder/)
Dan_168 Forum Pro • Posts: 11,055
Re: TS-E on the cheap? For architectural photography
Any advice welcome!
To me a good lens is good lens, no such thing "a waste" on any camera, the unique T/S capabilities can be fully utilized for your type of work regardless what kind of camera body is mounted on, of course 6D is easier than the 400D due to all the newer technologies, but it's definitely not a "waste" on 400D, I have used my TSEs both film, old 20D and all the newer bodies like 5D2, 1DS3, all worked great.
Focusing the TSE with VF is not as difficult as you may think, I mainly use MF Zeiss and TSE primes and while it's "harder" to do that with VF than the LV LCD, but it's definitely doable if you take your time and practice more, you are not shooting fast moving objects with such combo, so don't be turned off by VF MF, you will love those TSE, once you tried, it's hard to go back to any other Canon WA lenses.
Mike K Veteran Member • Posts: 5,525
I own both the 17 TSE and 24 TSE II and use them quite a lot Vs other lenses.
I shot for several years using a older version of the TSE24 on a Canon 1DII. Despite the large viewfinder, I found it very difficult getting optimum tilt and shift adjustments using the viewfinder only. Tilt in particular was difficult, whereas sometime shift (perspective adjustments) could be done in the viewfinder by paying attention to larger items like trees, building columns, etc. With the Live View you can zoom into 5X or 10X, and with a higher resolution LCD , greatly facilitates Tilt and Shift lens movement adjustments.
So my advice for T/S use is get a camera with a good Live View implementation and a good LCD. The 400D has a 2.5" LCD with only 230,000 dots, a very first generation Live View that simply doesn't have the resolution to do critical lens movements. All of the current Canon dSLRs Including Rebels) have a 3" LCD (Some swivel and are touch sensitive) with about 1.1m dot resolution. Big difference.
Mike K
 Mike K's gear list:Mike K's gear list
Canon EOS-1D Mark II Canon EOS 5D Mark II Canon EOS D60 Canon EOS 6D Canon EF 135mm F2L USM +9 more
Howard S Senior Member • Posts: 2,212
I got a used TSE24 mk1 recently and shift is not bad with viewfinder although I use liveview when I can, but for tilt I want liveview
 Howard S's gear list:Howard S's gear list
Canon G3 X Canon EOS 7D Canon EOS M Canon EOS M50 Canon EOS M6 II +12 more
joger
joger Veteran Member • Posts: 7,513
. . . My question is, is it too bad a waste of a beautiful lens (17mm TS-E) to put it on a 7-year-old EOS400D?
Cameras really don't matter that much any more since a couple of years!
It's the lenses that make the difference!
Go for the TS-E 17 or 24 II and get a new camera when your old one stops to work properly.
I own the TS-E 17 and it is a fabulous lens - just amazingly good and easily outperforming any other wide angle lens on the market - you can't go wrong with it.
Camera bodies are widely overrated in terms of importance to the image quality. That said certain conditions require different feature sets - but for the sujets a TS-E 17 is built for a 400D will do just fine. The story is different for action and sports though.
As long as you can stay at low ISO values you might not see a significant difference even to the latest camera releases from Canon
__________________________________
isn’t it funny, a ship that leaks from the top
ISO 9000 definition of quality: 'Degree to which a set of inherent characteristic fulfills requirements'
I am the classic “Windows by Day, Mac by Night user'
“The horizon of many people is a circle with zero radius which they call their point of view.” Albert Einstein
 joger's gear list:joger's gear list
Sony a7R IV Sony FE 135mm F1.8 GM Sony FE 35mm F1.4 GM Sony FE 50mm F1.2 GM Sony FE 14mm F1.8 GM +12 more
But focus via the viewfinder, especially on some crop bodies, is not as easy as using liveview especially in tilt mode as you know
brightcolours Forum Pro • Posts: 15,885
No it does not
No, it does not have live view. At all. The 450D was the 1st of the series with live view.
Mike K
OP AmateurArchitectural New Member • Posts: 19
Live View indispensible for tilt (and shift)?
Thank you all very much for the answers so far - really helpful. Live View, especially for tilt, seems to be the critical issue.
If I'm stopping down to f11 most of the time and often at 10-20m from the critical focus subject will I be able to wing it without Live View, or will I find myself endlessly frustrated by slight missed focus?
If it comes to it, I'd probably rather spend more and enjoy using the kit than save and get driven mad by it!
I also have a fondness for over-polarised blue skies which makes me favour the 24mm for filters, at which point I'd need a FF body to be wide enough for architecture. (Sounds as if I'm trying to talk myself out of saving the money...).
Different options
That is your current situation. Your photography might grow, so try to take that into account if that is not very unlikely.
It does not go to waste, but maybe shine on a body with fewer restrictions.
That is the biggest problem. For smaller apertures and small sized images, slightly off focussing will not matter too much, though.
I guess you must mean image quality out of camera? At low ISO settings the 400D is fine. Just a tad less vibrant than other Canon models. Whether the 10mp is enough is for you to decide (it seems it is).
The main downsides of the 400D are the smallish LCD, no LiveView, in combination with the small XXXD viewfinder.
You can consider a 400D with 17mm TS-E. Will give you low quality higher ISO, usability problems with tilt judgement. No live view to aid you either.
You can consider a 650D with 17mm TS-E. Will give you much better higher ISO possibilities, a great high res. LCD which swivels (and offere live view) and has a nifty touch interface that you can use or leave, and will give you much better judgement of focus and tilt.
You can consider a 6D with 24mp TS-E II. Will give you a better than the 400D LCD, with live view. Will offer a bigger and brighter view finder, which helps a bit judging focus and tilt too.
You can consider a 6D with Samyang 24mm tilt shift. You get a tad lower quality optics than the Canon powerhouse, less build quality for a lower (more affordable) price.
You can consider a 6D with the old 24mm TS-E, 2nd hand.
Any advice welcome!
Re: Live View indispensible for tilt (and shift)?
Have a read of This it will probably help, and this
Mike CH Veteran Member • Posts: 9,631
Polarizer of less use on 24mm FF
Polarizer on a 24mm lens on an FF body?
The cases where you will get a uniformly blue sky are limited due to the wide angle the polarizer has to cover; intensity varies with the angle. So don't expect too much from that.
On the other hand, I douse a 24 TSE on my 5D3 - and you'd have to wrestle it out of my cold, dead hands
Regards, Mike
Wait and see...
 Mike CH's gear list:Mike CH's gear list
Canon G7 X II Canon EOS 5D Mark III Canon EOS 5D Mark IV Canon EF 16-35mm F2.8L II USM Canon EF 100mm F2.8L Macro IS USM +14 more
Re: Different options
This is a fantastically knowledgeable, helpful and clear answer - thank you so much. I hadn't thought of a cheapo new crop body as a clever way to keep costs down but get Live View! Along with Mike CH's observation about the limitations of polarisers at wide angles this is sounding like a great option:
EOS650D+TS-E17mm:
- decent resolution
- good quality Live View for focusing, especially with tilt
- excellent IQ (including avoiding the less good edges of TS-E)
- I don't lose my EF-S standard zoom
From the reviews of the EOS650D it sounds as if I might even be able to get the occasional shot at a quality and resolution needed for a smallish poster-sized print, if I get my technique bang-on.
Any down-sides I'm failing to spot?
Thank you!
Muresan Bogdan Contributing Member • Posts: 512
You can also try the new Samyang/Rokinon/Bower 24mm TS for less than half the price of Canon. It will not break the bank and let you get aquainted to TS techonlogy. Also with the money difference you can upgrade the body. A body with an articulated screen could be your best option. Also for TS you will need a sturdy tripod.
 Muresan Bogdan's gear list:Muresan Bogdan's gear list
Canon EOS 5D Mark III Fujifilm X-T1 Canon EF 50mm F1.4 USM Canon EF 85mm F1.8 USM Canon EF 24-105mm f/4L IS USM +1 more
photonius Veteran Member • Posts: 6,895
Do you still have the Nikon? Probably not, because you use past-tense, but there are cheap Nikon to Canon EOS adapters.
That depends on your purpose. for powerpoint it's all fine. But how much resolution do you need for your book/article illustrations. At 300DPI for printing you need 3000 pixels for 10 inches.
Given that the 400D has no live view (as others discussed), it seems sensible to upgrade to a newer body. So, that leaves you with the question how much to spend.
Anyway, no matter which body you put a new 17 or 24mm TS-E on, they will hold their value well.
Any advice welcome!
*** Life is short, time to zoom in *** ©
 photonius's gear list:photonius's gear list
Canon EF 100-400mm F4.5-5.6L IS II
EOS650D+TS-E17mm:
- decent resolution
Or bigger poster print... The bigger you print, the bigger the viewing distance will be. Print resolution kinda scales with viewing distance.
Also, if you go for a 17mm f4 TS-E, and you go FF in future, you can add a 1.4x TC (not totally sure about Canon, but Kenko for sure) I believe, and get a 1.4 x 17 = 23.8mm TS-E. This way you get two focal lengths for the price of one.
Thank you!
joger
exact tilting is nearly impossible with live view as well - the 3 inch screen is too small to do that - you can take an arbitrary approach and use a table with values instead and alter in slow steps three or four images - that's the way I do it on my 5D II as well - 3 " is simply too small to judge the effect.
If at all the WiFi function on the new Canons will make a difference - use a > 7" tablet and zoom in and you will be able to see something reliable.
tonyjr
tonyjr Veteran Member • Posts: 5,295
This is one of the rent 1st questions .
I would also do a search for Tilt shift on XTI and then other bodies .
 tonyjr's gear list:tonyjr's gear list
Canon EOS 400D Canon EOS 7D Canon EF 35mm F2.0 Canon EF-S 10-22mm F3.5-4.5 USM Canon EF-S 17-55mm f/2.8 IS USM +14 more
MarcosV Veteran Member • Posts: 6,522
Time to upgrade or post process
Any advice welcome!
I would go for the 6D and 24mm TS-E.  Full frame and wide glass go very well together.  You get other pluses like better high ISO performance.
Another option would be to research used bodies that have adequate live view implementation (factor in screen size and resolution) that you could use in the meantime.  If you find a few models that work that are readily available in your area at an acceptable price, you could go for the 17mm TS-E now and buy a slight body upgrade later.
Otherwise, I recommend that you continue to save your money by sticking with post processing.  You do state that you typically stay with smaller prints.  CS6's capabilities are very decent in smaller prints of building exteriors.
I found using a the tilt/shift capabilities effectively can take a lot of time to master.  I would definitely want to do such things on a sturdy tripod with live view, rather than trying to squint through a really small view finder.
 MarcosV's gear list:MarcosV's gear list
Sony RX100 IV Fujifilm XF 50-140mm F2.8 Fujifilm 16-55mm F2.8R LM WR Fujifilm XF 16mm F1.4 R WR XF 90mm +28 more
Steve Balcombe Forum Pro • Posts: 15,582
EOS650D+TS-E17mm:
- decent resolution
I think so, yes. The 17 TS-E has a huge bulbous front element which is a problem if you want to use filters; the 24 TS-E takes screw-in filters. Sharpness is not an issue with either of these lenses, but FWIW the 24 mm lens is sharper (and of course the 6D image would be cleaner and slightly higher resolution). The 17 is more expensive - not by a huge amount, but if you are buying a new body the difference will take you that much closer to the price of a 6D.
I don't own a T/S lens so take what I say with a pinch of salt, but if I was investing that much I'd want a full frame body, and the 6D makes that relatively affordable. You could also consider a used 5DII if you don't need the specific features of the 6D.
Re: Time to upgrade or post process
Any advice welcome!
That is debatable. If you set equivalent -f-ratios to get similar DOF, you need to set the ISO at an equivalent setting too. You will lose 1 1/3rd stop of "high ISO performance" right there. Then the difference is not so big anymore...
