Warning! Possible bug in newest Metz 58-AF1 and Metz 58-AF2 firmware
Started Jun 25, 2013 | Discussions
Hoowdy Junior Member • Posts: 38
I downloaded the newest firmware for Metz 58 AF-1 and the flash does NOT fire in A or M mode. The PTTL and PTTL-HSS is not affected. I am posting this here to warn fellow Pentaxians against a possible problem. I posted this information on the "other" forum (www DOT pentaxforums DOT com) but since the issue seems important I am putting it here as well.
I've tested this on Metz 58 AF-1 (firmware v 5.0) using Pentax K-7 and kit lens (18-55 AL WR).
Can anyone confirm this problem?
Pentax K-7
awaldram
awaldram Forum Pro • Posts: 13,271
Re: Warning! Possible bug in newest Metz 58-AF1 and Metz 58-AF2 firmware
As posted over on the other thread what do you mean A and M are you talking Auto and manual on flash or Av and manual on body.?
Either way seems a bit of an obvious error for QC to have missed.
My 48 v5.00 and 50 v4.00 do not show any issues.
 awaldram's gear list:awaldram's gear list
Pentax K-x Pentax Q Olympus PEN E-PM2 Pentax Q7 Pentax K-3 +17 more
Nfrw Junior Member • Posts: 49
Just did a quick test. Metz 58 AF-1 running firmware V.5 and K5-II. Runs wirelessly on Slave after the firing on camera then taking it off trick. Fires on camera using PTTL. Won't fire using A or M modes. I upgraded the firmware yesterday because of the supposed upgrade for K5-IIs.
 Nfrw's gear list:Nfrw's gear list
Pentax K-5 II Pentax K-3 Pentax K-1 II Pentax smc DA 16-45mm F4 ED AL Tamron SP AF 70-200mm F/2.8 Di LD (IF) MACRO +3 more
OP Hoowdy Junior Member • Posts: 38
"A" and "M" modes on the flash. I've tried this on "X" (flash sync) settings on the body.
Ivan Gordeli Forum Member • Posts: 70
Same here K-5 + 58 AF2
Same issue here. In A or M mode on the flash the flash does not fire (pre-flash does). K-5 + Metz 58-AF2 firmware 4.0
Have you reported it to Metz?
"Notes on Photography" blog http://gordeli.wordpress.com/
 Ivan Gordeli's gear list:Ivan Gordeli's gear list
Sony Cyber-shot DSC-F717 Panasonic Lumix DMC-ZS3 Pentax K-5 Tamron SP AF 17-50mm F/2.8 XR Di II LD Aspherical (IF)
awaldram
Ah wouldn't affect my 48 and 50 then (no Auto), I'll check Manual though when I get home.
Kerusker
Kerusker Senior Member • Posts: 1,464
Thanks for the info
I'll wait for METZ to clear the bug before updating the FW.
][.Kerusker
we don't see that we don't see (eye's blind spot)
 Kerusker's gear list:Kerusker's gear list
Sony RX10 IV Pentax K-1 Pentax smc DA 15mm F4 ED AL Limited Pentax K-5 IIs Pentax smc FA 50mm F1.4
il_alexk Senior Member • Posts: 2,878
Is there a reason to update unless using K30 or K5II?
The new FW improves HSS with K-30/K5II. I'll skip this upgrade.
 il_alexk's gear list:il_alexk's gear list
Pentax K-5 IIs Sony a7R III Fujifilm X-A5 Fujifilm X-T100 Pentax smc FA 50mm F1.4 +9 more
Kerusker
new firmware 5.1 fixes the bug (Auto, Manual)
new FW vers 5.1 fixes the bug according to METZ
http://www.metz.de/en/lighting/flash-units.html
haven't checked it yet
][.Kerusker
Solution(?): full link to the new firmware
It looks like Metz just have uploaded a new firmware version 4.1 for the 58-AF2 http://www.metz.de/en/flash-units/firmware-download-flash-units/mecablitz-58-af-2-digital/pentax.html
and version 5.1 for the 58-AF1 http://www.metz.de/en/flash-units/firmware-download-flash-units/mecablitz-58-af-1-digital/pentax.html
That was fast!!!
I wish Pentax (or Nikon, Fuji, Canon, Singer, ... add the missing name.) could issue FW fixes in 24 hours.
Re: new firmware 5.1 fixes the bug (Auto, Manual)
The Mac version hasn't been posted yet...
awaldram
Re: That was fast!!!
Why the time constraint?,  as were talking flash ........ ever would be a good start
dick eduard
dick eduard Senior Member • Posts: 1,565
I have the 58 AF-1 many years now
I checked the firmware and...  1.0 the first and i never updated. Should I do it now ? The flash works fine withe my K20d and K5.
What's you'r advice
Dick
awaldram
Re: I have the 58 AF-1 many years now
Every manufacturers releases firmware updates to
1 fix reported issues with compatibility
2 fix bugs
3 add functionality
4 correct major failings
of the above they will generally only mentions 3 and 4 as features of new releases.
So look at the list and decide if you want any of them if the answer is yes then update.
working in the IT industry I update everything  as soon as FW is released and sometimes before (from discussion with manufacturer I sometime get updates prior to release (not Metz)).
as a user your safest bet is wait 1-2 weeks from update posted then update anything else is building up risk of disappointment
What's you'r advice
Dick
dick eduard
Thanks awaldram, much help and..
I will update my flash
Cheers
Dick
2 fix bugs
3 add functionality
What's you'r advice
Dick
Confirmed: problem solved for me
For my combo K-5 + 58-AF2 and DA40 Limited the new firmware 4.1 has solved the problem
2 fix bugs
3 add functionality
5. add new bugs
Works for me as well (Metz 58 AF-1 + Pentax K-7)
The newest firmware for Metz 58 AF-1 (v 5.1) available on the Metz site WORKS FLAWLESSLY. I've tested it on both A, M, PTTL, and PTTL-HSS flash modes - everything works as it should have.
For Metz 58 AF-2 the newest v. 4.1 version is here.
I urge everyone who has v 5.0 (Metz 58 AF-1) or v. 4.0 (Metz 58 AF-2) firmware to upgrade to v.5.1 and v.4.1 respectively.
In short: PROBLEM SOLVED!
Because I'm a Mac user... I sent a comment from the Metz website asking when it would be available. In less that 24 hours I received a reply with the file attached. The email said that the update will be posted to the Metz website as soon as possible, though as of this morning, it isn't up yet.
