Magenta cast on DP2x
Started Jun 21, 2013 | Discussions
barrykap Forum Member • Posts: 90
There's always been a slight magenta cast problem with all the Sigma DP's I've had, but the latest camera (DP2X) is much worse now.
It never originally had a strong magenta cast, it was almost invisible in fact but just recently, over the last few months, the cast has become impossible to work with. It is always more prominent on any over-exposed frames, I am doing a lot of auto-bracketing and the 2 stops over just gives me a magenta and white image mostly. Hardly any other colour showing. Really horrible. The 'normal' exposed frame gives magenta cast too but this is more controllable with post-processing. The under exposed one is not too bad but still a faint evidence of magenta cast on them too. What bothers me is it is getting worse and I am unable now to get rid of the cast completley using Photoshop. I have had a little more success with Oloneo Photo-engine, but it should not be necessary to have to do all this drastic tweaking. I use RAW format all the time.
Does anyone else have this bad problem and is there a solution? Unfortunatley the camera was bought just over 12 months ago so I can't claim anything under warrantee.
The sample JPG is of one of the over-exposed frames, converted from RAW.
Any advice welcome.
Thanks.
Barrykap
The over-exposed frame of a two-stop auto-bracketed set, converted from a RAW original
Sigma DP2x
victorgv
victorgv Senior Member • Posts: 2,123
Re: Magenta cast on DP2x
Stupid question, but did you check your monior? When CFL backlight starts to go bad it will give you magenta cast in darker areas and sometimes does the same thing happens when calibration goes wrong.
Any advice welcome.
Thanks.
 victorgv's gear list:victorgv's gear list
Sigma DP1 Sigma DP2 Merrill Sigma dp2 Quattro Sigma sd Quattro H
SigmaTog
SigmaTog Senior Member • Posts: 1,114
Basically under expose - 0.7 EV.
This is + 2 EV & is way too much.
ΣigmaTog
Johan Borg Veteran Member • Posts: 3,433
Could you post a (non-overexposed) X3F file somewhere so others can try developing it? My first guess is that the RAW converter (SPP?) is applying some wrong color management profile or something..
 Johan Borg's gear list:Johan Borg's gear list
Sigma dp2 Quattro Sigma fp Sigma 45mm F2.8 DG DN
OP barrykap Forum Member • Posts: 90
Sorry I forgot to mention I am taking +/- 2 stops for HDR set.
I have uploaded a X3F 3-set of that particular sample, thus giving 'normal, -2 and +2 samples.
They can be downloaded from here;-
http://barryknapper.com/HOME/downloads/magenta/
Barrykap
Robert F. Tobler
Robert F. Tobler Senior Member • Posts: 1,149
Sigma DPx (non-Merill) auto bracketing shots have incorrect white-balance...
If the shot was taken from an auto bracketing sequence (and not manually
set to +2), the broken color balance is due to a bug in all non-Merill
Sigma DPs: the correct white balance is only done for the correctly
exposed shot. In the following test the issue is shown in low-light shots,
but the white balance problem is true for normal light as well:
http://rftobler.at/Photography/Tests/Sigma-DP1-Auto-Bracket/
Note that this is fixed in the Merrill cameras.
Greetings,
Robert
 Robert F. Tobler's gear list:Robert F. Tobler's gear list
Sigma DP1 Merrill Sigma DP2 Merrill Sigma DP3 Merrill Olympus E-M5 II Olympus Zuiko Digital 1.4x Teleconverter EC-14 +2 more
Rudi Senior Member • Posts: 2,047
... except SDIM8439, which is overexposed, the images are within normal limits on my Window 7 PC with SPP 5.5.1 (basic Windows sRGB profile). Can´t find anything wrong with the DP2x.
Did You run an update of Your graphic card drivers or something like that ?
vkphoto
vkphoto Senior Member • Posts: 1,632
Hi,
Yes, +2 is all magenta. But, your 'normal' file has plenty details in both highlights and shadows, easily can be further pp-ed to look HDR-ish.
BTW, this photo looks great in B&W, I can share my conversion results if you would like.
vkphoto
Re: Sigma DPx (non-Merill) auto bracketing shots have incorrect white-balance...
aaaaah.  Thanks. That really answers my question perfectly. Yes I was using auto-bracketing as it is obviously convenient to use especially as the 'compact' camera is carried in my pocket without a tripod handy.
I have a SD15 too, which I also take HDR sets on auto-bracketing and this seems to be a lot better, although there is the occasional magenta saturation in these too. But much better than the DP2x. Is the same problem (re non-merril bug) apparant in the SD15 too?
I suppose my solution is to just use the SD15 for HDR's and if I do need to use the DP2x then to use a tripod and manual under/over expose the bracketing.
Thanks again.
Barrykap
Robert F. Tobler
Since I only own the DP1 and the DPx Merrills, I can't say.
Thanks again.
You are welcome.
Greetings,
Robert
PrebenR Veteran Member • Posts: 4,164
Thanks again.
Maybe I missed the point, but didn't you say you shoot in RAW? Simply set the WB afterwards to the same in all frames...
Lightwriting with Sigma
victorgv
Thanks again.
HA! You were absolutely just checked it out changing from auto to sunlight got rid of magenta cast.
Now i am curious if he would have shot not with auto wb but sunlight or whatever would he have the same problem ?
I was using autoWB yes, because I found that the most reliable in the past. But as you say, changing to sunlight removes magenta, BUT it now gives an overcsat of green!  This i knew before, but I suppose I can fiddle about in Sigma Photo Pro to adjust WB Post-shot. I was just trying to get it all right at the start.
Barrykap
rick decker
MOD rick decker Forum Pro • Posts: 19,097
There was a thread some years ago about WB affecting panos/hdr shots and the recommendations were to avoid AUTO.
Funny really as Auto has (up to this recent problem) always served me well.
Wish I had seen that a while ago. Might have led me onto better things.
Cheers.
Barrykap
PicOne
PicOne Veteran Member • Posts: 6,932
Cheers.
So..  what happens if you just choose Auto for WB in SPP?   I'm actually curious whether SPP does analysis of the shot scene and provides Auto result different from the in-camera determination of Auto.  In other words, is choosing "Auto" any different than choosing "Original" in the WB settings dialogue?
'Everything in photography boils down to what's sharp and what's fuzzy.'
-Gaylord Herron
Good question.
Anyone got an answer?
I do notice when selecting a different WB in SPP it does take some time to process it. So most lilkely it is regenerating within SPP a new result and not using the camera results.
Barrykap
rick decker
Yes I have wondered about that also.  I will try to get an answer for that in the next day or so.
R
