Do pixels matter? What 20" x 30" prints reveal.
Started Jun 14, 2013 | Discussions
qianp2k Forum Pro • Posts: 10,350
Re: Yes. Yes they do.
Just another Canon shooter wrote:
primeshooter wrote:
Put it this way, pixels will matter alot more when canon release a 40MP camera.
Yeah, as they suddenly tried to matter to the Nikonians after the release of the D800. Remember the time when 12mp was enough?
Only effectively matter a) when you have lenses that capable to resolve 36mp or 40mp; b) you do need to print that big or you have higher enough resolution monitors such as 4K and 8K capable displaying these pixels.
Per Inge Oestmoen Senior Member • Posts: 1,890
Re: Do pixels matter? What 20" x 30" prints reveal.
Dan_168 wrote:
As a landscape shooter and current owner of D800E and 1DS2, 1DS3 1D2 & Sony NEX7, and previously 5D2 and D3, 20D, D300, I am really surprised to heard so many people claimed there is no difference between high resolution and low resolution when everything else being equal.
They do not care about differences or detail, they only ask "do I like the picture?" If the answer is "yes," the whole frame might be mush only - they would still say that it is good if the content is interesting and emotionally powerful.
However, the content and the technical quality of an image are two entirely different aspects, and there never was a situation where a brilliant content did not benefit from an equally brilliant technical presentation.
Everything matters - but the relative weights of the elements depend on the subject matter.
Per Inge Oestmoen, Norway
Just another Canon shooter Veteran Member • Posts: 4,691
Only effectively matter a) when you have lenses that capable to resolve 36mp or 40mp; b) [...]
Every lens known to man shows improvement from 8mp to 15-18mp APS-C, which translates from 5D2-3/6D to the hypothetical 40mp FF sensor. In fact, there are tests of EF lenses with Pentax Q, and it surprising to see how much resolution is lost with the current 20-22mp sensors.
 Just another Canon shooter's gear list:Just another Canon shooter's gear list
Canon EOS 5D Mark II Canon EF 15mm f/2.8 Fisheye Canon EF 35mm F1.4L USM Canon EF 50mm f/1.2L USM Canon EF 135mm F2L USM +4 more
The Davinator
The Davinator Forum Pro • Posts: 22,401
I found the opposite.   Most of the posts back then were a call for more MP....that said, I find 12 to be fine for wedding and portaits.  But for landscapes, or large group shots, I love the D800.  The 5D3 is fairly close up to 20x30 in scenes that dont require a large dynamic range.
 The Davinator's gear list:The Davinator's gear list
Canon EOS D30 Canon EOS 10D Nikon D2X Fujifilm X-Pro1 Fujifilm X-T1 +17 more
The Davinator
I found that even my old 35mm afd was great on my D800.  Modern lenses do just fine.
http://www.dxomark.com/index.php/Publications/DxOMark-Reviews/Which-lenses-should-you-choose-for-your-Canon-EOS-5D-Mark-III/Canon-EOS-5D-Mark-III-vs.-Nikon-D800-Competition-is-closer-than-expected
Yap, exactly as DXOMark Lab tests show. As a matter of fact, when Canon high MP camera is released there are more Canon lenses can take advantage of those pixels than Nikon's ones.
Re: I have some questions.
Great Bustard wrote:
The DR / pixel for the 5D3 is 11 stops at base ISO:
http://www.sensorgen.info/CanonEOS_5D_MkIII.html
The DR / pixel for the G15 is 11.5 stops at base ISO:
http://www.sensorgen.info/CanonPowershot_G15.html
GB, I know based on my own experiences in owning and extensively using 4 different crop format Canon cameras, this is not true.  Usually larger sensor results to better highlight clipping.
I am going to test this in a control way between my 5DIII, 60D and S95, maybe in this weekend.
Mako2011
MOD Mako2011 Forum Pro • Posts: 25,896
Well said
Very true as very very few Nikon lenses will be mounted on that Canon. Lets hope the higher MP doesn't make to obvious the minor flaws in lens and technique.
My opinions are my own and not those of DPR or its administration. They carry no 'special' value (except to me and Lacie of course)
