200-400 f/4.0 1.4x - My hands on review and samples.
Jun 13, 2013
Hi all,
I was in New York last week and visited B&H. To my surprise they had a Canon 200-400 f/4 on the shelf as a sample. The salesman allowed me to attach my 1D X and I quickly shot some samples - the lens had apparently only arrived that day. I did not spend that much time, as the store was busy.
I was VERY impressed with the lens, and I have now decided that I will purchase one when they are more readily available - if B&H had stock I would have bought one then and there.
I found the lens to be surprisingly light.
Now I realise that it actually weighs 3.6 kg. But a lot of "hands on" that I have read mostly mentioned how heavy the lens seemed, more so than it's size indicated. I am used to using a 600mm f/4 USM (version 1) and will either have it on a monopod with Wimberley head or resting on my knee - usually in the back seat of a landrover. So when I picked the 200-400 up it stuck me as being much lighter than I was expecting.
The lens is very easy to hand hold. The position of the zoom lens makes it slightly tricky to operate as it is towards the objective lens end. However from a weight point of view it was very easy to manage.
I fired off a few shots both with and without the 1.4x extender in position. The lever to operate the extender is easy to use and feels very solid and positive in use. There is a locking switch, but I don't think would be used much (at least by myself) as the lever seems unlikely to be accidentally moved.
If hand holding I would operate the 1.4x lever with my camera hand (right hand) with my left hand supporting the lens. However if the lens was mounted on a tripod/monopod then I would likely use my left hand to operate the 1.4x lever - this would allow me to continue to operate the camera with my right hand. Likewise operation of the zoom would also be much easier like this.
I also fitted by own 1.4x (Mark I) extender and the lens continued to function and autofocus both with and without the built in extender.
Autofocus was very very fast and very smooth. It felt to me as fast as a 300mm f/2.8 USM (mark I) - I have only used this lens once, and I don't own one. It easily felt as fast if not actually faster than my 600mm f/4 USM.
Build quality was superb and everything about the lens screamed solidity, quality and precision.
I LOVE this lens and I now intend to sell my 100-400 L and 600mm f/4 L as soon as practical as purchase a 200-400.
I had the ISO in my 1D set to 2000 and in retrospect this was too low - it was not that bright in the store. As a result not all images are that sharp. However despite sometimes getting a shutter speed as low as 1/40th sec I am surprised that they are not more blurry. The IS system seems to be very very good. So don't blame the lens, blame my poor technique!
Please note that I do not know the people in the photo's, nor did I seek their permission. So please do not publish these photo's anywhere else.
I had been planning to post these earlier, but thought that some of the new owners would be posting their own (and better) images, but has nothing has appeared so far. . .
So here you go
http://www.flickr.com/photos/conanbutcher/sets/72157634099707005/
Exif data is all there and the last two shots are with the 1.4x extender engaged and also with my own 1.4x (Mark I) extender fitted - gives 784mm at f/8.0. The name of each image describes the settings and focal length used.
Conan.
