Have you seen this RX1 grip?
Started Jun 2, 2013 | Discussions
cosmonaut
cosmonaut Senior Member • Posts: 2,223
Sony RX1
miro3 Veteran Member • Posts: 3,048
Re: Have you seen this RX1 grip?
cosmonaut wrote:
It looks interesting and cheaper than the thumb thingy.
http://www.ebay.com/itm/3S-KangRinpoche-PSRX1G-Professional-Quick-Release-Plate-with-Grip-for-SONY-RX1-/200921621099?pt=LH_DefaultDomain_0&hash=item2ec7dca26b
Yes, I bought it from them at the end of March, and it is excellent!
Highly recommended.
cosmonaut
OP cosmonaut Senior Member • Posts: 2,223
Highly recommended.
Thanks I may have to get one soon.
www.gregmccary.com
elliottnewcomb Forum Pro • Posts: 18,214
If they had made it a slot at the tripod screw, it could adjust length wise for several cameras, like my rx100. A wide slot with a retainer would move side to side and front to back.
what material, metal or plastic, is the bottom piece? do you think it could be modified for the rx100?
Elliott
 elliottnewcomb's gear list:elliottnewcomb's gear list
Sony RX1R Sony RX100 III Olympus Stylus 1s Sony RX100 VI Sony Xperia XZ +1 more
FramerDave Contributing Member • Posts: 666
The openning next to the tripod screw is made to allow access to the battery/memory card door. Unless you want to mount and dismount this every time you need to change battery/SD card you would not want to mod this for other cameras.
I believe the whole piece is made out of aluminum hence the $120 price. It would probably add too much bulk and weight for most RX100 owners.
good points, thanks for answers.
Elliott
tesilab
tesilab Veteran Member • Posts: 3,004
Very good card and battery access, even when mounted to a tripod.
It is light, comfortable, and sleek. A perfect match for my Sirui T-025 Tripod!
See also:
http://www.flickr.com/photos/tesilab/8654647454/
http://www.flickr.com/photos/tesilab/8653546233/
 tesilab's gear list:tesilab's gear list
Sony RX1R II Panasonic Lumix DMC-GX8 Sony a7 III Panasonic Leica Summilux DG 25mm F1.4 Sony FE 85mm F1.8 +1 more
alextardif
alextardif Senior Member • Posts: 1,376
IMHO there are better alternatives.  Take a look at the RRS version .  I have one and the overall appearance, lines/shape, modular design, longer base plate all have an advantage.  It's more expensive but it is for a nearly $3K camera after all.
 alextardif's gear list:alextardif's gear list
Sony FE 35mm F1.4 Sony a7R III Sony FE 90mm F2.8 macro Sony FE 24-70mm F2.8 GM Sony FE 85mm F1.4 GM +2 more
I second that. I went all out for the L-plate as well.
cosmonaut
Now I like that one I haven't seen it. Thanks for posting.
www.gregmccary.com
