How to shoot Time Lapse with a T1i?
Started Jun 2, 2013 | Questions
Kelemvor Regular Member • Posts: 233
So I know I either need an intervalometer (or wahtever it's called) or I can hook the camera up to my laptop, which is what I'll want to do to start with.
Main question is, what software from Canon do I need to contorl the picture taking over time?  I see a ton of various software items when I go to the Software page at Canon.com.
http://www.usa.canon.com/cusa/support/consumer/eos_slr_camera_systems/eos_digital_slr_cameras/eos_rebel_t1i#DriversAndSoftware
Can anyone help with what software I need and maybe some quick info on how I go about using it?
Thanks!
PowderMaggot Regular Member • Posts: 132
Re: How to shoot Time Lapse with a T1i?
I don't know that Canon will help you, but you can try Magic Lantern. I haven't tried this feature of that software, so I don't know how well it works. But it's free and you don't need the laptop connection.
ferian
ferian Forum Member • Posts: 63
i've tried using magic lantern to do timelapse, it works well....
 ferian's gear list:ferian's gear list
Sony a7 II Sony FE 28mm F2 Sony FE 85mm F1.8
Y0GI Veteran Member • Posts: 5,257
Thanks!
Canon's "EOS Utility" is what you need.  Hook up the camera to the USB port, turn on the camera  and open EOS Utility.  Select: "Camera Settings/Remote Shooting."  This will open the camera control module.  In the center of the pop-up screen on the right hand side is an icon of a clock face.  Click on this icon and the rest should be self explanatory.
Yogi
When you get down to the nuts and bolts of photography, the results depend on the 'nut' behind the camera!
See the 'Gear List' in my 'Profile' for my current equipment.
Check out WilbaW's beginner FAQs at - http://snipurl.com/RebelFAQ
 Y0GI's gear list:Y0GI's gear list
Canon EOS 7D Canon EF-S 10-22mm F3.5-4.5 USM Canon EF-S 17-55mm f/2.8 IS USM Canon EF 100-400mm f/4.5-5.6L IS USM +2 more
OP Kelemvor Regular Member • Posts: 233
Wow, I forgot I made this since there was no email updates before.  Glad to see what was finally added.
I'll hopefully be able to give this a try this weekend so I'll let you know how it goes.
icor1031 Regular Member • Posts: 408
How did it go?
 icor1031's gear list:icor1031's gear list
Canon EOS 5DS Carl Zeiss Apo Sonnar T* 2/135 Sigma 50mm F1.4 DG HSM | A Zeiss Otus 85mm F1.4 Sigma 85mm F1.4 Art +2 more
