Canon EF 50mm f1.4 USM Lens Worth Getting?
Started Jun 1, 2013 | Discussions
DaniellllD Forum Member • Posts: 51
Hey everyone!
I have recently been looking at the Canon EF 50mm f1.4 USM Lens, but I have a few questions before I dish out the bucks. So first off I am more of a video shooter so I need to know if the focus is noisy, as in when you use the focus manually and automatically does it make a lot of sound? It does say USM but I would like an answer from someone who has actually used it. I know a lot of the cheaper lens do but I wouldn't be sure. Second question is what is the focus actually like is it quite good and easy to use? Last off how amazing is the low light performance for photos and video? Even though it would seem obvious since it is f1.4, you have to factor in that it is quite an old lens (Released in June 1993). Also I use a Canon EOS 7D with a RĂ˜DE VideoMic Pro for audio. Anyways thanks in advance!
Daniel
 DaniellllD's gear list:DaniellllD's gear list
Sony a7S II Canon EF 50mm F1.8 II Canon EF 16-35mm F2.8L II USM Canon EF 70-200mm F2.8L IS II USM Samyang 85mm F1.4 Aspherical IF +2 more
tonyjr
tonyjr Veteran Member • Posts: 5,295
Re: Canon EF 50mm f1.4 USM Lens Worth Getting?
I seldom even use my 50 1.8 mk 1 anymore . Other than the bokeh a higher ISO is OK .
I would look at the new 40 mm or even the new one with IS . Both will give better bokeh and have better coatings .
 tonyjr's gear list:tonyjr's gear list
Canon EOS 400D Canon EOS 7D Canon EF 35mm F2.0 Canon EF-S 10-22mm F3.5-4.5 USM Canon EF-S 17-55mm f/2.8 IS USM +14 more
Muresan Bogdan Contributing Member • Posts: 512
The 50mm f1.4 is a great lens and I personally use it a lot. The focus mechanism is an old type of USM that still has some gears and you can hear a small sound when it focuses ( compared to my 24-105 or the 85 mm f1.8 USM is a bit noisier). Manual focus is great but doesn't have that very long run that you might need in video. For that maybe look at the Samyang 35mm cine lens. They are great optically, have a declicked version and the focus has a very long race for precise manual focus.
The Canon is great from f2.2-f2.8 up. It is usable from f1.4 to f2, but some chromatic aberations can be seen. Also it is slightly soft in that area but you probably won't notice this in video. I shoot mainly stills so I prefer to use it from f2.2 up. Also under f2 the focus field is so small you will have a real problem focusing - maybe only still subjects from a tripod.
 Muresan Bogdan's gear list:Muresan Bogdan's gear list
Canon EOS 5D Mark III Fujifilm X-T1 Canon EF 50mm F1.4 USM Canon EF 85mm F1.8 USM Canon EF 24-105mm f/4L IS USM +1 more
OP DaniellllD Forum Member • Posts: 51
Oh wow the Samyang 35mm cine lens looks amazing! Can't believe I didn't see this before thanks!
Arkon
Arkon Regular Member • Posts: 194
Canon line up for 50 mm lenses are out dated.  The optical quality is now below the current offerings from Nikon and Sigma.  I would consider the 35 mm f2 IS as the "normal lens".
 Arkon's gear list:Arkon's gear list
Nikon D2H Canon EOS-1D X Canon EF 85mm F1.8 USM Canon EF 135mm F2L USM Canon EF 28mm f/2.8 IS USM +2 more
Fixxxer
Fixxxer Regular Member • Posts: 291
I use my Canon 50mm f1.4 all the time and I think it's a great lens. Very fast and not very noisy but I only take stills so how it works in video-mode I have no idea. Samyang have great lenses (cheap and excellent in color) but they're only manually focused so if you want an AF lens you can't use theirs.
 Fixxxer's gear list:Fixxxer's gear list
Canon EOS-1D Mark II N Canon EOS-1Ds Mark II Olympus E-1 Pentax K100D Olympus E-620 +9 more
Y Hafting
Y Hafting Contributing Member • Posts: 787
DaniellllD wrote:
Hey everyone!
Daniel
the 50mm 1.4 isnt as noisy as old servo motors, but it is no stm either. I'd reccomend reading up on this:
http://www.dpreview.com/forums/thread/3217548
Basicly you do not want to use AF on an USM lens during video- it will never look or sound pretty. USM is fast, but CDAF is moving stepwise, so there will be noticable sound and steps. The new stepper motor lenses should be a much better choice for video.
Focusing the 50mm 1.4 while shooting video is better done manually, and unless you are on a tripod or need fast glass in particular a lens with stabilization would normally be a better choice.
Other than that im quite satisfied with my 50mm 1.4, but i normally don't use it for video.
Good luck!
-Yngve
Dan_168 Forum Pro • Posts: 11,061
I owned quite a few 50mm in the last twenty some years including this  EF 50 1.4 lens, currently has Sigma 50 F1.4, Zeiss 50 F2 and Nikon AIS 50 F1.2, the Canon EF 50 F1.4 is one of those lens I will never recommend it to any friends. I had that lens twice and sold it twice, the last copy i had I use it on my 1D2 and 1DS2 for a few years and was never happy with its built quality and optic quality, as soon as the Sigma 50 F1.4 arrived, I put that on the Craigslist the same day and never look back, the Sigma has so much better wider open performance, better Bokeh quality, not to mention the huge difference in built quality difference, it's two completely different class lens.
You mentioned you will be using it for video, would you consider manual focus? there is quite a few manual focus 50mm which give you much better optical performance than the EF 50 1.4. I personally only use the Sigma when I need to shoot large aperture, or anything other than landscape, because no matter how I  stop it down, the Sigma 50 never gives me super sharp edge, it's just as bad as the EF 50 1.4 in this regard, for landscape, I only use either my Nikon AIS 50 F1.2 or  Zeiss 50 2.0 because of their local contrast and amazing edge performance, I also use these two with video many times, but I hardly shoot video so I am not the expert on this topic.
