Access to "Bayer RAW" pre-processed image data
Started May 29, 2013 | Discussions
inqque New Member • Posts: 9
Hello,
I made this post here earlier but I thought I would try it with retouching forum,
http://www.dpreview.com/forums/post/51547606
I'm new to DP Review and hope you can help me with my question.
I'm working with Canon 1Ds Mark II, and processing camera RAW (.CR2) files Mac OS 10.8, and in Lightroom 4.0. I have been working with digital files since Photoshop 2.0 and have tried many RAW processing software such as Capture One, and Aperture.
I want to access the raw file data before demosaicing. I don't want to work on the "camera raw" file but the "Bayer RAW" files pre-processed image data.
This link is useful in showing sample files.
http://adamhooper.com/blog/posts/186-how-cameras-work-interpolation
My aim is to process the raw pixels, export as tif or jpg as seen in the attached image.
Thank you!
Inqque
Canon EOS-1Ds Mark II
exdeejjjaaaa
exdeejjjaaaa Veteran Member • Posts: 8,263
Re: Access to "Bayer RAW" pre-processed image data
inqque wrote:
Hello,
Thank you!
Inqque
you can use RPP ( http://www.raw-photo-processor.com/RPP/RPP64_1641Beta.zip ) with -NoCFA command line option, something like this :
/Applications/Raw Photo Processor 64.app/Contents/MacOS/Raw Photo Processor 64 -NoCFA YES
 exdeejjjaaaa's gear list:exdeejjjaaaa's gear list
Sony a7R II Sony FE 55mm F1.8 Phase One Capture One Pro +25 more
OP inqque New Member • Posts: 9
exdeejjjaaaa wrote:
inqque wrote:
Hello,
Thank you!
Inqque
Thank you, I think I almost got, but lost you on "-NoCFA YES"
I noticed a couple of other posts
http://www.luminous-landscape.com/forum/index.php?topic=71218.20
http://www.dpreview.com/forums/thread/3153469?page=2
and downloaded RawDigger
if you want that (colorized dots), then you need rawdigger - http://www.rawdigger.com - which is not a raw converter exactly, but good enough for illustration purposes... it will show you RGGB undemosaicked dots colorized... rpp was intended in such mode specifically for bw cameras (like bayer cameras with CFA removed or monochrome MF/Leica) where you natually do not need any demosaicking and image was supposed to be b/w/greyscale
How do I export the file as TIF?
Thanks.
With RPP 64 I was able to export this file but without the RgBg squares.
Thank you.
exdeejjjaaaa
indeed... but why do you need rgbg coloring ? and then you shall ask if software that shows you rgbg color dots does color transforms in a proper manner... unless you want this for illustration purposes only.
mikes
mikes Veteran Member • Posts: 3,437
Reverse Engineering
Maybe just make your own if its for illustration purposes only.
Thank you.
Only when you can criticize yourself, should you criticize others. Mikes.
Exdeejjjaaa,
Sorry, I'm either not understanding something about the pre-processed Bayer raw file or not writing my request clearly.
I am not using this for illustration purposes.
I posted earlier this link that clearly illustrates the raw workflow.
I want to experiment with visual effects and work directly with the unprocessed Bayer Raw image data. The RawDigger seems to work but I can't export the file as a high res TIF image and maintain the RGBG 2x2 square pixels. I can only make lores screen captures.
Thanks so much for your help.
–Inqque
Don Glenn Contributing Member • Posts: 854
I once played with bayer filter data.  I don't have statistics, but I suspect strongly that most camera raw converters use dcraw.c, or modified a version, to get the raw data.  It was very educational, if you want to know what the files look like.
http://en.wikipedia.org/wiki/Dcraw
http://www.dpreview.com/news/2005/4/27/davecoffininterview
exdeejjjaaaa
inqque wrote:
Exdeejjjaaa,
and RPP w/ NoCFA works for you quite well - you just need to handle color transforms for data from sensels yourself :-)... when you have some "color" assigned to those that is a result of some processing (color transform), not unprocessed data... alternatively you can use dcraw (or libraw) to dump such data... there are also programs like Iris (astronomical images processing) or even Matlab
Thanks, very helpful interview. Yes, when I first started researching the topic, everything was pointing to dcRAW by Dave Coffin. Working on a Mac with limited knowledge of programming has not been easy. However this link I recently found might help.
http://bellavist.com/blog/?p=466
Jack Hogan Veteran Member • Posts: 6,989
You probably want imagej with the dc-raw plugin.  Alternatively straight dc-raw.  Both have a learning curve.
Jack
BillHinge Senior Member • Posts: 1,032
Is this the kind of image you are looking for ? (I wasn't sure)
The green tint is because I haven't edited it or changed the colour balance
I chose the Bayer option, not the CFA option
dethis2 Regular Member • Posts: 360
–Inqque
You can trick RawTherapee to do this.
Open your raw file in editor.
If you want "pure" raw pixels disable the color management at tab "color" and then close it.
Change directory at the file browser so that you can change the *.pp3 (settings file).
Open the *.pp3 with notepad and at "RAW" section change "Method=amaze" with "method=none"
Reopen your file and save to tiff 16bit.
You will take what you want but with WB applied. If you want pure raw pixels without WB, you must first convert to DNG and change in exif data the WB multipliers to 1 1 1
I think Dcrawjdc http://jacques.desmis.perso.neuf.fr/geraud/photo_calcul.php has an option (q 100 ) which does the same. You have to set WB at 1 1 1 1 if you want and choose -o 0 to disable color management
I hope this helps.
Ilias
