Problem with trailing shutter?
Started May 27, 2013 | Discussions
Phil_Rose
Phil_Rose Senior Member • Posts: 1,044
Hi all, I just did a shoot and of the 209 images shot two came out like this. Is this the trailing shutter (or leading shutter?!) These were shot with three Alien Bees (which all fired as far as I am aware. I didn't shoot this immediately after another shot so I think they would have had time to recycle) It, along with the previous shot which came out fine, was shot at f7.1, iso 100, 1/180 sec (on X setting).
Does this look like an intermittent problem with the camera or is there another, less worrying explanation? I have never seen this happen before. I didn't see this on any of the landscape format images which would have proved it was a camera issue (if the black line had been at the bottom).
Shot on my new K5ii with a 16-45 f4 DA.
Thanks for any thoughts you can offer.
Phil
I like turtles.
www.philrosephoto.com
Pentax K-5 Pentax K-5 II Pentax smc DA 16-45mm F4 ED AL
Wheatfield
Wheatfield Veteran Member • Posts: 6,297
Re: Problem with trailing shutter?
Pretty sure that's the trailing shutter. Were you using wireless triggers? Some of them can't keep up to the sync speed.
Phil_Rose
OP Phil_Rose Senior Member • Posts: 1,044
AHA! I was. That would be great if that was the problem. I wonder why it would happen intermittently though?
Thanks so much. I guess I'll need to do some more testing. I'll add my results when I get around to it.
Phil
I like turtles.
awaldram
awaldram Forum Pro • Posts: 13,271
Your Alien Bees are not maintaining X-sync
They are introducing a delay in the signal this delay shifts and occasionally the flash catches the trailing shutter.
Could be a battery issue or even a recovery issue (repeated flash ) but it not camera and unlikely to be  flash issue.
 awaldram's gear list:awaldram's gear list
Pentax K-x Pentax Q Olympus PEN E-PM2 Pentax Q7 Pentax K-3 +17 more
Meuh
Meuh Veteran Member • Posts: 3,184
I had this when using a really crap radio trigger, I recon is your triggers fault.
MightyMike Forum Pro • Posts: 41,691
In my understanding this can happen if a flash is getting over heated, just dropping to 1/160th or 1/125th sec can remedy the issues
Mike from Canada
http://www.michaelfastphotography.com/galleries/VP-BDI_3a.jpg
http://www.airliners.net/search/photo.search?sort_order=views%20DESC&first_this_page=0&page_limit=180&&emailsearch=mighty_mike88%40hotmail.com&thumbnails=
awaldram
Without an external battery pack it difficult to cook a flash, My 540 firing off an ext battery pack can trigger the O/heat protection but it just stops firing and doesn't sync delays.
Mike from Canada
