Can I backup the "activation code" for Adobe CS6 or Lightroom?
Started May 27, 2013 | Discussions
LongTimeNikonUser Senior Member • Posts: 1,126
For Windows 7 or Office 2010, Microsoft stores a "tokens.dat" file that can be backed up.  In practice, if you redo your Windows install from scratch, you can restore these files so that you don't need to reactivate Windows or Office.
(If people want, I can post these locations for Windows 7.  Or else, do a search for "Josh Cells Software." )
I have CS 6 installed on both a desktop and a laptop system.  I would like to do the same for my Adobe products, because I need to wipe and rebuild my Windows 7 install on my desktop system.  Adobe's activation policy is a pain in the rear, and I was wondering how Adobe software detects that it has been activated.
If the activation indication is a registry entry, rather than a file, that's OK.  I'm quite comfortable with regedit.  If the file is normally hidden, I can deal with that also.
I want to be very clear about this.  I am a legit, paid up user of this software with the install DVD from Adobe, and I do not condone piracy.  I am just trying to manage my systems more carefully and with less total time and effort.
I've done some searching on this question, and all I get are a mixture of sites advising on how to install CS6 or else pirate sites (which are also dangerous because of all the malware.)
Thanks in advance.
LongTimeNikonUser
 LongTimeNikonUser's gear list:LongTimeNikonUser's gear list
Nikon D3 Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-Nikkor 80-200mm f/2.8D ED +8 more
Sean Nelson
Sean Nelson Forum Pro • Posts: 12,865
Re: Can I backup the "activation code" for Adobe CS6 or Lightroom?
You don't need to save the activation status, just deactivate it before you re-install and then reactivate it afterward using the same key you did the first time.  It's very simple - just open up one of the CS6 products (such as Photoshop) and use the "Help --> Deactivate" menu path.
I've never bothered worrying about activation issues like this - I just be sure that I keep the license key safe so that I can use it again if necessary.
The worst-case scenario is that your system crashes with the CS software still active, in which case an attempt to activate it again will run into the 2-instance activation limit.   I'm not worried about that scenario because I make image backups of my system which I can simply restore if needed.
digitalshooter
digitalshooter Forum Pro • Posts: 19,604
and if you still have an issue you call and they help you (nt)
Thanks,
Digitalshooter
PS: all posts are just my opinion!
 digitalshooter's gear list:digitalshooter's gear list
Sony Alpha DSLR-A700 Canon Pixma Pro9000 Mark II
