Canon 24-70mm f/2.8L with cracked filter stuck on lense. Any ideas to remove?
Started May 22, 2013 | Questions
rickpoole Senior Member • Posts: 1,241
Re: Now you know why not to use filters for "protection"
Here is another trick - I used it to free up a stuck filter years ago.  Since the filter screws inside the lens barrel if you can either expand the lens barrel or contract the filter it may loosen just enough to remove it.  The easiest way is to get a block of ice, put a piece of wax paper or plastic on the block of ice then set the lens filter down on top of the protective paper/plastic.  Maybe it will contract the damaged filter just enough to allow you to unscrew it.
 rickpoole's gear list:rickpoole's gear list
Canon EOS 7D Mark II Canon EOS 5D Mark IV Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F4L IS USM Canon EF 100-400mm F4.5-5.6L IS II +7 more
Mark B.
Mark B. Forum Pro • Posts: 29,756
NomadMark wrote:
If you didn't have a filter mounted, that damage would have been done to the front end of the lens. I'd sooner have issue taking a broken filter off, than never being able to get one back on, or worse!!
A lens hood would have absorbed the impact, the lens would not have been damaged.  I have firsthand experience with this.
Mark.
bruxi
bruxi Regular Member • Posts: 318
Re: Tip.
brightcolours wrote:
bruxi wrote:
Austin_Luker wrote:
I don't drop lenses, but have had many front elements poked going through the woods and saved by a filter, so I guess to each his own.
I have a simple tip for you. Lens cap.
Unfortunately the subjects (birds and animals) aren't so great at waiting around for me to put lens caps on and off....
 bruxi's gear list:bruxi's gear list
Canon EOS 60D Canon EF 50mm F1.4 USM Canon EF 70-200mm F4L IS USM Canon EF 24-70mm F4L IS USM
R2D2 Forum Pro • Posts: 26,550
Re: Tip.
That's true.
I use a hood religiously and wear a camera strap that keeps the lens pointed down (it hangs at my left hip).  I've never scratched a front element in 40+ yrs of shooting (no protective filters).
Though I have indeed personally witnessed a shattered filter from a dropped camera leave scratches in a lens (fellow photog).
Knock on wood!
R2
ps. NOBODY drops lenses... until they drop one.
ed rader Veteran Member • Posts: 9,068
The anti-filter jihadis hate your filters!
They can't answer a simple question without declaring jihad on all filters.  God is great!
 ed rader's gear list:ed rader's gear list
Canon EOS 80D Canon EOS 5D Mark IV Sigma 15mm F2.8 EX DG Diagonal Fisheye Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM +4 more
hotdog321
hotdog321 Forum Pro • Posts: 21,141
Re: The anti-filter jihadis hate your filters!
Only the holiest of filters will be saved: CP and ND! Death to the foul filters foisted by the grinning lackeys of the capitalist running dogs!
 hotdog321's gear list:hotdog321's gear list
Canon EOS 5D Mark IV Canon EF 100mm f/2.8 Macro USM Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM +3 more
hotdog321
Heh, heh, heh! Thanks!
MASTERPPA Contributing Member • Posts: 870
Both is best. The old lens hoods on the 24-70 version 1 was great for protection.
New hoods are not much more then shock dampers.
Depending on the hardness of your front lens, and what you are doing, UV glass is best is most cases.
My macro lens is the best example. Their are all kinds of scratches on the front of the UV filter, and these would have been on the lens element.
My lens hit a rock face one time while hiking, (it was not very hard, the camera was swing as I was hiking next to a rock wall) the UV glass did not shatter, but had a BAD scratch on it..
Nonsense. He had no lens hood on. With hood the lens would be fine.
People get to all kinds of odd ideas in order to keep on using thin slabs of glass to "protect" lenses.
Agree, but even the best UV add a little reflect.  I use a $130UV filter on my 24-70 2.8II and the only time I can see UV is in dark churches with lots of candles. Their are an extra reflection.
I've probably saved 2-3 front elements using filters (especially out in the field) and done every kind of IQ test and there is no difference.  I could post photos from every one of my lens tests and you could never pick the shots with the filter on.  It's all in your head.
ME TOO. and the UV was scratched BAD.
We can debate this ALL DAY, but it comes down to this. In certain shooting situation, UV is better then no UV. For drops, lens hoods are better. I use BOTH.
Some lenses are harder coatings on the front.
My old digital camera screen had tons of scratches on it. My 5DIII has NONE. Beating coatings.
For my hiking where the camera is on my neck, no lens caps (So I can catch a bear or deer, really fast) I do not use a lens cap, so the UV saves me all the time.
bruxi wrote:
tim73
tim73 Regular Member • Posts: 489
Here's a quick test with a good quality filter.  Notice the green flare and reduction in contrast.
Which filters are those?
brightcolours Forum Pro • Posts: 15,885
If you are so strangely clumsy, yes, use "protection" filters always.
You have all kinds of "examples", don't you? So yeah, for someone with your odd track record of not protecting your lenses with sensible lens hood and lens cap and love to just beat your camera through bushes and rocks, and who oddly enough does have lenses with "soft coatings", sure. You should put on thin slabs of flat glass on all your lenses all the time.
And sure, you will never get extra lens flares introduced and will never get ghost lights. Sure.
Funny thing is that the only filter I ever use may be a pol. filter.
Now for some TRUE stories:
I go hiking through the forest often. I bike/walk through forest, urban areas. I have dropped a certain lens twice. One time it tumbled a few stairs down till it hit a concrete floor, the lens hood broke its fall (it split on the side), the lens was fine. I dropped it on concrete side walk tiles from about a meter when switching lenses, its lens cap got a tiny mark and a tiny chip of white paint on the zoom ring is missing. Lens is fine. No filter to tray and pry off on both occasions, no broken thin slab of glass wanting to put scratches on the front element either. Since I do not protect stuff with... thin slabs of glass.
I have about 14 lenses. None of them I "protect" with UV filters. None of them have scratches on front or back elements, none of them have ever broken a front element.
Of course, there are situations thinkable where you CAN use a UV filter for protection where it actually makes sense. When sand is flying around. Or when it creates weather sealing during conditions where that is a good idea.
tim73
More reasons to avoid UV filters
Heliopan UV on a EF 28-135mm lens (the only filter-lens combination I still posses).  This was just a quick test with a desk-lamp as a light source. Notice that the un-filtered shot has no ghost reflections, which shows that my lighting was far from extreme.  With a stronger narrower light source - such as the sun - the reflections would be even more objectionable.
I stopped using UV filters about 15 years ago, reasoning that good-quality filters would cost more than any lens repairs I was likely to require.  Moreover the filter is more fragile than the front-element on the lens.  Should the filter take a heavy blow it would be likely to send shards of glass onto the lens's front element, turning a point-impact into a deluge of scratches.
Since then none of my lenses have received any damage to the glass.  I'm careful, but I do a lot of hiking and travelling and I don't like carrying bulky padded camera bags - so my gear does take knocks.  If I do scratch the front surface of a lens it probably won't affect the image.  It won't make a pattern or shape on the focal plane, and most of the scattered light will be directed away from the image sensor.  So I don't worry about it.
cdst New Member • Posts: 4
Re: Canon 24-70mm f/2.8L with cracked filter stuck on lense. Any ideas to remove?
Try to put it to a fridge for some time, if the thread is plastic it will do.
Michael Fryd
Michael Fryd Forum Pro • Posts: 16,059
Re: If you are so strangely clumsy, yes, use "protection" filters always.
Whether or not someone should use a "protective" filter is a different question then whether or not the filter will affect image quality.
Physics tells us that a filter will always affect image quality.  At best, it will be so little that the filter will cause no noticeable degradation.  At the worst, the filter will make  a very noticeable difference.  It all depends on the lens, filter, and shooting circumstances.  Anyone who tells you a filter "always" or "never" causes noticeable degradation is spouting superstition, not a rational opinion.
Physics also tells us that there are some circumstances where a filter can provide some useful physical protection.  Anyone who tells you that filters "always" or "never" save a lens is spouting a superstition, not a rational opinion.
The important questions to ask are how much image degradation and how much physical protection will you get in your circumstances.   Once you know this, you can make an informed decision if the protective benefits outweigh the image degradation in your circumstances.
Consider someone who will be running through the woods and feels uncomfortable with an exposed front element, but worries about missing a shot while removing a lens cap.  They have a choice of missing a shot due to lens cap use, or using a filter and risking a loss in image quality.
I am going to go out on a limb and suggest that an image with reduced image quality is preferable to an image of the back of your lens cap.
Where we get into trouble is the natural tendency for people to claim that their choices are the best choices for everyone else in all situations.  This is rarely the case.  My suggestion is that you ignore any filter advice that says you should "always" or "never" use filters.  Instead, look at discussions of what filters can and can't do, and then decide how that applies to your situation.
When you see conflicting advice, try to confirm on your own.  It's easy enough to put your camera on a tripod and take two images, one with and one without your filter.  Compare the two, and this will show you exactly how your filter affects your images in the tested circumstance.
 Michael Fryd's gear list:Michael Fryd's gear list
Nikon Coolpix AW130 Canon EOS D60 Canon EOS 7D Mark II Canon EOS 5DS Canon EOS 5D Mark IV +16 more
