Canon 15-85 USM + 60D or T4i with 18-135 STM
Started May 20, 2013 | Questions
mridulghosh12 New Member • Posts: 21
Hi
I have Canon XSi with 18-55 IS + 55-250 +50mm 1.8. The 18-55 is on my camera 95% of time, I occasionally miss a little more reach, mainly for portrait.
I am planning a lens upgrade soon (going to Yellowstone in July). I would like to carry fewer lenses but all-in-ones did not work for me as I bought andreturnedboth Canon 18-135 (older) and Tamron 18-270 due to image quality issues. I am also planning body upgrade later in the year or next year. I will sell Xsi with 18-55. Will keep 55-250 and 50mm
I am torn between these two choices :
  1. Canon EFS 15-85 USM with my XSi now and 60D/70D later in the year
  2. T4i with 18-135 STM
Please advise which of the above options people would prefer.
I do video also mainly with iphone 4s and Canon flash HD camcorder. Is manual focus on DSLR video too difficult ( 60D)?
My top subjects are my busy toddler, landscape, portrait. I cannot have too much lens with me as daughter keeps running and time is always short.
Thanks for helping out, this is my first post
Have a nice day
Mridul
Damoo Senior Member • Posts: 1,102
Re: Canon 15-85 USM + 60D or T4i with 18-135 STM
See if you can get a used 70-200mm f4L IS USM or if u can shoot handheld, the 70-200mm f4L without IS. Not only u will get better reach (upto 200mm), and f4 is one stop faster than f5.6
Keep ur 18-55mm, instead of 15-85mm, get the 70-200mm (the IS version used or the non IS)
Be it T4i or 60D, the 70-200mm will perform very well. All AF points on the 60D are cross types.
 Damoo's gear list:Damoo's gear list
Leica M Monochrom (Typ 246) Olympus OM-D E-M5 Canon EOS 6D Sony a7S Canon EOS 5D Mark IV +16 more
ggoldfarb Forum Member • Posts: 64
Hi,
What about the Tamron 17-50 (I use the non VC)? sharp, fast and the price is reasonable.
Since I don't do video, I cannot comment about it.
Good luck
Guy
davel33 Senior Member • Posts: 2,978
The 18-135 STM is a very fine lens.  Its the only lens Canon makes with dynamic IS, its great for video ( like a built in steady cam).  The focus is very fast and accurate plus silent.  The IQ is also very good.  You will have auto focus while in video mode that is smooth and silent with a 4ti,5ti or SL1.
Good luck
 davel33's gear list:davel33's gear list
Canon EOS R Canon EOS R6 Canon RF 35mm F1.8 IS STM Macro Canon RF 24-240mm F4-6.3 Canon RF 85mm F2 Macro IS STM +29 more
akustykmagmanetpl Senior Member • Posts: 1,363
15-85 hands down
I've had the older version of 18-135 and while not bad optically, it wasn't really great at wide angle, plus its AF is quite slow.
15-85 gives significantly wider view with less distortion, much better sharpness, faster AF and is also better built. to me this choice is easy.
 akustykmagmanetpl's gear list:akustykmagmanetpl's gear list
Canon EOS 10D Canon EOS 80D Canon 6D Mark II Canon EF 24mm f/1.4L II USM Canon EF 50mm F1.4 USM +9 more
SeaScout851 Veteran Member • Posts: 6,342
Use this tool to compare the 15-85 and the 18-135 STM.  You can change the focal length and f stops and then compare quality.  Be sure and look at all the parts, not just the center.
By the way I shoot with 15-85 on a 7d and my wife uses 18-135 STM on a t4i.  Both are excellent.  But for me when shooting with the 18-135 I miss the extra width more than the extra length when using the 15-85.
Were I going to Yellowstone this summer I'd be using the 15-85 and 100-400.
Andy
OP mridulghosh12 New Member • Posts: 21
Andy
Thanks Andy : which tool ? link?
Andy
Thank you and good luck with Yellowstone, I will be there the week of 4th July. Have you tried 15-85 on t4i ? the reason I ask is I am waiting fro next 70D which may have auto focus video so wanted to see if 15-85 will be loud for autofocus video.
Gunzorro Senior Member • Posts: 1,892
Depends on your priorities:
Stills -- 60D and 15-85 IS
Video -- T4i and 18-135 STM IS
Either will overlap into the other in a pinch, but those are the areas that will work best. I shoot mainly stills and have a the first combination as a travel set-up with excellent results.
englishman
englishman Senior Member • Posts: 1,018
Re: 15-85 hands down
The old 18-135 and the new 18-135 STM are different lenses . . . here's a good article that describes it and compares it to the 15-85.
http://www.lensrentals.com/blog/2012/07/canons-18-135mm-is-gets-an-stm-makeover
The difference between stupidity and genius is that genius has its limits.
 englishman's gear list:englishman's gear list
Sony a7 III Sony FE 55mm F1.8 Sony FE 24-105mm F4 Apple iPhone 12 Pro Max
Andy
Sorry here it is:
http://www.the-digital-picture.com/Reviews/ISO-12233-Sample-Crops.aspx?Lens=675&Camera=736&Sample=0&FLI=0&API=0&LensComp=809&CameraComp=0&FLIComp=0&APIComp=0
Andy
Andy
Sorry here it is:
Andy
Mridul
I bought 15-85 to be used with my XSI for now. will wait for 70D. Will let know how was the quality soon
stratobill Senior Member • Posts: 2,081
I think you made the right decision, the 60D is getting older, and the XSI sensor is similar.
I would wait and see what's coming up for Canon. Particularly whether new sensor technology is on it's way.
The 15-85 is great, just a bit slow on the long end, but thought the IQ was very good and the range is perfect for travel.
 stratobill's gear list:stratobill's gear list
Canon EOS 6D Canon EOS Rebel SL2 Canon EF 70-300mm f/4-5.6L IS USM Canon EF 24-105mm f/4L IS USM Canon EF 40mm f/2.8 STM +4 more
lexar123 Forum Member • Posts: 73
I have the 15-85 and also think it perfect for travel.
I bought it because I wanted better image quality then the 18-55 and I found the range too narrow and would always want to switch lenses. (not wide enough, and not long enough)
I think the 15-85 range is perfect and I don't feel the need for a UWA. Also 85 is perfect in general walk around.. if I need longer then I really need long and don't mind switching lenses.
The image quality is better but I would not say night and day.. the kit lens is actually pretty good.
However the 15-85 range is great, the lens feels very solid, the focus is very fast and accurate.
I think the 15-18 is a lot more important then the 85-135.. You can always crop a little but you can get wider sometimes.
 lexar123's gear list:lexar123's gear list
Canon EOS 70D Canon EF 100mm f/2.0 USM Canon EF-S 15-85mm f/3.5-5.6 IS USM Sigma 30mm F1.4 EX DC HSM Sigma 17-50mm F2.8 EX DC OS HSM +4 more
Re: Canon 15-85 sample shots
Thanks everyone. I went with 15-85 for my Xsi and happy with the lens so far. Did some comparison with 18-55 ( which is good too) and found to have better sharpness, better contrast and color. You can find which lens was used in the pic text
Kasper FC Regular Member • Posts: 238
are you considering dumping your 60d for a T4i?
Get the 60d any day. Much more comfortable body design. I had the T4i, and got the 6d mainly because of the ergonomics and of cause FF sensor.
I think that you will get as sore hands and fingers from handling the T4i as i did, if your using proper lenses. (not a little light kit lens)
 Kasper FC's gear list:Kasper FC's gear list
Canon EOS 6D Canon EF 135mm F2L USM Canon EF 17-40mm f/4.0L USM Samyang 14mm F2.8 ED AS IF UMC Tamron SP 24-70mm F2.8 Di VC USD +3 more
Hi Kasper : I have neither still using Xsi with 15-85. I like it so far. I am waiting for next 70D or something like that. Want to explore DSLR shallow DOF video. But no more rebel. BTW I checked SL1 in Costco and its horrible....no grips whatsoever!
Re: Canon 15-85 USM goes to Grand Teton and yellowstone
Very happy with my 15-85 on xsi. Pl see sample shots from Grand Teton and Yellowstone last week.
Limburger
Limburger Veteran Member • Posts: 7,841
Looks like you had some fun over there
The 15-85 is a very nice walkaround and even portraitlens.
Cheers Mike
 Limburger's gear list:Limburger's gear list
Fujifilm FinePix X100 Canon EOS 7D Sony a7 Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 70-200mm F4L USM +3 more
