Owl in Flight with GH3 and 100-300mm
Started May 20, 2013 | Discussions
JamieTux Veteran Member • Posts: 4,159
6
I got a bit too close and cropped part of the wing - but overall I was pretty impressed with the AF-C mode on the GH3 (it's not the best I've ever taken - but I am sure that it will get better as I practice more):
 JamieTux's gear list:JamieTux's gear list
Canon EOS R5 Canon RF 35mm F1.8 IS STM Macro Canon RF 100-500mm F4.5-7.1L IS USM Canon RF 50mm F1.8 STM Canon RF 70-200 F4 L +6 more
Tony Rogers Senior Member • Posts: 2,201
Re: Owl in Flight with GH3 and 100-300mm
Nice picture.
It may be that you could get a crisper image by stopping down to f/7.1. At the long end, this lens goes a bit soft when wide open. I have done some tests that show it improves at f/6.7 and is best at f/7.1. f/8 is good also but not an improvement so I think f/7.1 is best to use.
Obviously you need to keep the shutter speed up for this kind of shot so I would shoot in A mode and set the Iso manually to get in the right speed range for the conditions of the day and type of subject. This is where it would be nice for Panasonic to provide auto-iso in manual mode because then you could set the shutter speed and aperture and allow the camera to set the correct Iso for optimum exposure. But it seems they never will...
 Tony Rogers's gear list:Tony Rogers's gear list
Sony a1 Sony 1.4x Teleconverter (2016) Sony FE 50mm F1.8 Sony FE 85mm F1.8 Sony FE 200-600 F5.6-6.3 +1 more
djbrom
djbrom Senior Member • Posts: 1,324
very well done.  Its not the easiest to capture BIF with CDAF cameras and the AF on the 100-300mm isnt exactly fast, so you did well considering it was flying toward you
 djbrom's gear list:djbrom's gear list
Olympus OM-D E-M5 Olympus E-M1 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G Vario 100-300mm F4-5.6 OIS Olympus M.Zuiko Digital 45mm F1.8 +11 more
djbrom
Tony Rogers wrote:
Nice picture.
Good info Tony.  I did some testing of my own comparing it against a few lenses and whilst I only tested it at 1 stop intervals, i found that wide open it aint the best at 300mm.  I am thinking that the Oly 75-300mm (at least the original version) may be a tad better but that is just based on one link (that i have lost of course lol) wher a guy compared them both and the Oly wide open at 300 certainly had better contrast and appearance of detail.
grumpyolderman Senior Member • Posts: 1,085
Very impressive shot, the clipping does not really matter to me.
I am sure there is not much "you" can do over the slightly soft look, I am sure it comes from a tiny bit of movement and/or the shutter, try your lens on a tripod with the e-shutter on a static object, I am sure it will be tack sharp!
JL
19andrew47
19andrew47 Forum Pro • Posts: 45,413
While not perfect it is very nice indeed and I would be thrilled to have captured this image.
Andrew
howardfuhrman Veteran Member • Posts: 4,153
This is a very good photo.  The difference between very good and excellent is that at 100% it is a bit soft. I am not sure what you could have done as you shot it at 1/1250 of a sec.  I am not sure that increasing the f stop would have worked.
OP JamieTux Veteran Member • Posts: 4,159
Thanks for the feedback everyone
Sorry that I've not responded!
I agree it might have been sharper had I closed the lens down a bit - but then I'd have had a slower shutter speed or a higher ISO so that might have added blur anyway.
But I'm pleased with the result - better than I was expecting before I bought into the system!
It's pretty sharp anyway, I've got a handheld shot of the moon on the OM-D (with no e-shutter) that looks amazing - of course I have tripod mounted e-shutter shots of the moon too - taken from the luxury of an arm chair using LUMIX LINK
I agree, an amazing shot to be proud off. I was more responding to the other guys...It is very tricky to get the long focal length sharp, even with image stabilisation. I just got myself a "monster" of a lens, a Pentacon 300mm F4, see how that goes, see if I can lift it!
How do you take shots of the moon from our armchair, have you got a mount with sideral drive? The moon goes through my viewfinder in a minute, I would love to get a mount for at least 2-3 min exposures (not hte moon, obviously).
JL
schirmer Regular Member • Posts: 443
Re: Thanks for the feedback everyone
1/1250s is quite fast for an owl (Bubo bubo I guess). Ignore the ISO and the noise, first stop motion blur and get enough DOF. You can fight noise in PP, but you can't add DOF or freeze later.
PS: Just checked my Bubo bubo shot (see gallery): 1/250 f5.6, G1 @ ISO200, quite slow birds
Sorry I meant the lens, not my owl shot - but thank you
I loved the Nikon 300mm f4 - if the Pentax is similar you'll be very impressed.
I was playing more than anything I actually lined up ahead of where the moon was going - but I'm sure it take a few minutes to go through - but I've never timed it!
As for mounts - I bout my father an AstroTrac for his 60th, a couple of years ago (I asked advice from a Sony forum member, Nordjsterm I think is how you spell it) and Dad loves it - he thinks it's accurate enough for about a 5 minute exposure, then he resets and takes the next - then stacks at the end - here's a link to the results he gets with that http://www.t2landscapes.co.uk/p983829945
I'm sure he'd recommend it if you asked him.
He recently bought a ridiculously stable Arca Swiss head - he think that's made quite a difference too - but none of the photos on the gallery are using that yet.
JL
Nice shot!
I've practiced with the same birds a lot  At around 300mm I find 1/1000 and higher gives the best results even if you have to open the aperture or increase ISO, here's a link to one:
http://www.flickr.com/photos/jamestux/5726154328/
It was a different class of lens of course....
Thanks for the tip, and your dad has some very nice photos on his webpage!
JL
