What size step-down ring?
Started May 18, 2013 | Questions
DCAJ2 New Member • Posts: 2
Hi, I've got a M.Zuiko Digital 75-300mm f4.8-6.7 II Telephoto Zoom and M.Zuiko Digital 12-50mm f3.5-6.3 Standard lens for my OM-D and have bought three 58mm Hoya filters which fit fine with the telephoto lens. For the 12-50, I bought a 58-52mm step-down ring wrongly thinking that filter size is the same as I needed for the 52mm step-down. The 58-52 is too big for the 12-50 lens as it is the same diameter as the front of the lens, not the size of the thread to screw the step-down ring into.
Can someone please advise on what size step-down ring I should purchase to go from my 58mm filters to fit on the front of the 12-50 lens?
Thanks...David
hindesite Veteran Member • Posts: 4,893
Re: What size step-down ring?
You need a step up ring - 52mm - 58mm.
The ring you have probably looks like this:
But the ring you need looks like this (for example):
http://www.ebay.com/sch/i.html?_trksid=p2050601.m570.l1313.TR0.TRC0&_nkw=52+58+step+up+ring&_sacat=0&_from=R40
