D600 + WU-1b + DSLR Dashboard = AWESOME!!
Started May 10, 2013 | Discussions
Colorado CJ Contributing Member • Posts: 502
A few months ago I bough the WU-1B wireless adapter for my D600. After downloading Nikons App for Android, I was very sorely disappointed.
Nikon's app is VERY limiting and only features a shutter, there is no adjustment to the camera settings available.
Fast forward to today. I was doing some searching and found another App, called DSLR Dashboard. After installing the app, I was blown away! EVERY CAMERA SETTING is adjustable through this app. It is simple and straight forward to use. The interface is very well thought out and simple.
My Nexus 7 will now go with me on all my photo outing as the WU-1B is an incredible addition to the D600 with this software.
Nikon D600
EYeye Regular Member • Posts: 297
Re: D600 + WU-1b + DSLR Dashboard = AWESOME!!
Do you know if this will work with Windows 7 phones? Wu-1b does not.
 EYeye's gear list:EYeye's gear list
Nikon AF-S Nikkor 50mm f/1.4G Nikon AF-S Nikkor 24-85mm F3.5-4.5G ED VR Nikon AF-S Nikkor 300mm f/2.8G ED-IF VR Nikon AF-S 70-200mm F2.8E FL ED VR Nikon D80 +7 more
OP Colorado CJ Contributing Member • Posts: 502
I think it is only for Android and Apple based systems right now.  If your phone has an app store, you might try searching for it.  It is called, DSLR Dashboard.
JasonED Contributing Member • Posts: 945
Nice!
Please get them to make an iPad friendly version.
The sky is blue and there is nothing we can do..
windplr Forum Member • Posts: 53
I don't see anywhere that DSLR dashboard works with wireless.  it only mentions USB OTG.  But I guess that is not the case since you are using it that way.  Did you have to do anything special to get it to work?
It DOES work wirelessly.  All you have to do once it is loaded is hit the back button and it will give you the options of wu-1a/b or network, or USB.
You have to have the latest firmware installed on the D600 as well.
esanker Junior Member • Posts: 31
Thanks for the tip.  I was looking for an alternative app for the longest time.  This might be the answer I'm looking for.
 esanker's gear list:esanker's gear list
Nikon D600 Voigtlander 28mm F2.8 Color Skopar SL II Voigtlander 40mm F2 Ultron SL II +2 more
Excellent.  Thank you for the update!
rmiller85
rmiller85 New Member • Posts: 19
I didn't find this in the iOS app store, is it android only? It'd be great to have an alternative to the nikon app, which only barely works (at best).
atrhys Forum Member • Posts: 99
I've been thinking about getting the WU-1B adaptor but read lots of negative reviews regarding its connectivity. Does this app stay connected better than the Nikon app or is this issue not related to the apps?
 atrhys's gear list:atrhys's gear list
Nikon 1 AW1 Nikon D750 Nikon AF-S Nikkor 50mm f/1.8G Nikon AF-S Nikkor 70-300mm f/4.5-5.6G VR Sigma 24-105mm F4 DG OS HSM +2 more
I only played with it for about an hour last night.  I had excellent conntectivity during the whole time.
I DID have to uninstall the Nikon app to get it to connect and stay connected though as the Nikon App tried to connect when i plugged in the WU-1B
Dr Bob
Dr Bob Senior Member • Posts: 1,319
when you say it works with every camera setting, is that right?  Sounds a really good way to go. I don't suppose you can see Live View via the app can you. Keen to hear more about this. Can you update us on your experiences.
Ta
Andy
 Dr Bob's gear list:Dr Bob's gear list
Nikon D600 Nikon D800E Nikon AF-S Nikkor 28mm f/1.8G Nikon AF-S Nikkor 24-120mm f/4G ED VR Nikon AF-S Nikkor 80-400mm f/4.5-5.6G ED VR +1 more
Placation101 Regular Member • Posts: 455
Ta
Andy
Well this is good to hear, maybe I will have to get one after all.
the cam ranger is at the level all of this wireless and smart device functionality really should be. Check that out too because that is about the best I have seen. Live view and all.
Ta
Andy
Yes, it works with EVERY camera setting.  It even has built in settings that the camera doesn't have, such as focus stacking.  The focus stacking setting actually lets the app take over the camera and adjusts focus for each frame for as many frames as you want to shoot.
And it DOES do Live View, that was the main reason I wanted the WU-1B.
Here is a screen shot using my Nexus 7.  I was actually inside the house when I took this picture.  My camera was outside about 50 feet away as I was controlling the camera through my tablet
Red G8R
Red G8R Senior Member • Posts: 1,788
No DSLR dashboard found in the App Store.
Peter
Ontario, Canada
 Red G8R's gear list:Red G8R's gear list
Nikon D4 Fujifilm X-T1 Fujifilm X-T2 Nikon D500 Nikon AF-S Nikkor 14-24mm f/2.8G ED +16 more
Glen78 Senior Member • Posts: 1,411
This is EXACTLY what I have been looking for but is there an iOS version? Cannot find one in the apple app store
 Glen78's gear list:Glen78's gear list
Nikon D5500 Nikon D810 Nikon D850 Nikon PC-E Nikkor 24mm f/3.5D ED Nikon PC 19mm F4E ED +10 more
Michael Kaplan
Michael Kaplan Veteran Member • Posts: 4,258
DslrDashboard is an Android only application for controlling DSLR camera connected with USB to your Android device.
https://code.google.com/p/dslrdashboard/
Michael Kaplan
http://www.pbase.com/mkaplan
See my profile for equipment list
 Michael Kaplan's gear list:Michael Kaplan's gear list
Sony RX100 III Nikon D810 Nikon D500 Nikon D850 Nikon AF-S Nikkor 24-70mm f/2.8G ED +19 more
Anything similar for iOS. Mostly wanting to use it to be able to do live view with an iPad when using tilt-shift lenses.
Nikon2011
Nikon2011 Regular Member • Posts: 242
IS THERE APERTURE control for video ??
 Nikon2011's gear list:Nikon2011's gear list
Nikon D7200 Nikon AF-S Teleconverter TC-14E II Sigma 50mm F1.4 DG HSM | A Nikkor AF-S 300mm f/4E PF ED VR
Nikon2011
i have the same setup
d600+nexus7 now ordered the wireless thingie and already installed the android app + tested via cable, nice
