Olympus 45mm v. Olympus 75mm
Started May 8, 2013 | Discussions
ArthurG1987 New Member • Posts: 15
Hey there kind dpreview.com forum folk!
I'm in a bit of a situation. granted, nice situation, but a situation nonetheless.
I'm torn between getting the olympus 45mm f/1.8 and the olympus 75mm f/1.8. Yes, the 75mm has its seductive claws in me. That front element and the all-metal construction are sexy as hell. But My main concern is the focal length: specifically, does an effective focal length of 150mm excessively flatten someone's face as compared to a 90mm effective focal length?
I'm especially interested in feedback from people who have experience with both focal lengths, or preferrably, both oly lenses.
Thanks, and keep it real.
ju_ju
ju_ju Senior Member • Posts: 1,077
Re: Olympus 45mm v. Olympus 75mm
Arthur, yes I have both of these lenses. I certainly do not worry about the foreshortening in portraits. I would suggest if you can afford the 75mm maybe you could afford both?  An assumption of mine.
A couple of examples but you would never know not seeing the person in the flesh. The last image is 400mm on FF. I suspect you ay be looking for more studio taken photos, but hope these help a little.
OLY 75MM
OLY 75MM
OLY 45MM
Induster 50mm f2 on OM-D
400MM
 ju_ju's gear list:ju_ju's gear list
Sigma DP1 Merrill Sigma DP2 Merrill Sigma DP3 Merrill Canon EOS 5D Mark II Canon EOS 30D +25 more
James A Rinner
James A Rinner Senior Member • Posts: 1,611
:-DI have neither lens but I do own the 50mm 2.0 macro with the MMF-3 adapter and a really sweet Minolta 85mm 1.7 that I converted (by machining) to 4/3.  I have used both of these for portrait settings and though I prefer the bokeh of the 85mm yet.  I didn't like the distance from subject with the 85mm in the studio.  I use manual focus for both.  I would buy both so my answer probably doesn't help much.
Sincerely,
James A. Rinner
 James A Rinner's gear list:James A Rinner's gear list
Olympus E-10 Olympus E-20 Olympus OM-D E-M10 Olympus PEN-F Olympus E-M1 II +15 more
David Kieltyka
David Kieltyka Veteran Member • Posts: 6,450
I like both...
IME 45 & 75mm lenses both work well for portraits in M43 format. I can't say I notice flattening effects until I go beyond 100mm or so. Although your definition of "flattening" might differ from mine...I like a bit of perspective compression but not so much that the subject looks like a cardboard cutout. Wide open the Oly 75 has more bite than the 45, so if you prefer a less clinical portrait approach w/ shallow DOF the latter lens would be your best option. The 75 is pretty amazing, though...one of the best lenses I've ever owned, and not just because it's sharp. It is that, but it doesn't sacrifice broad tonal range or rich color response to the god of resolution.
-Dave-
 David Kieltyka's gear list:David Kieltyka's gear list
Leica M9-P Leica M8.2 Pentax 645D Pentax 645Z Panasonic Lumix DMC-GX8 +9 more
Neurad1
Neurad1 Senior Member • Posts: 2,498
If I could only have one, it would be the 45. I have both, but even thought the 75 is sharper, I use it less as I typically find myself too close to the subject and tire of backing up over things
The 45 is on sale right now on the Olympus web page for $349. I'd call that a no-brainer. Oh, B&H also has the lens for the same price. I like to support them because they're awesome.
http://www.getolympus.com/us/en/lenses/pen-omd.html?utm_content=popular_primes_title&utm_campaign=md_lenses&utm_source=em_md_lenses_omd_fn&utm_medium=email
 Neurad1's gear list:Neurad1's gear list
Sony RX1 Sony RX100 III Olympus OM-D E-M5 Olympus PEN E-PL5 Olympus E-M1 +44 more
BingoCharlie Contributing Member • Posts: 849
The 75mm is brilliant but it is a truly weird focal length.  I rented it recently and the sharpness blew me away.  Definitely a specialty lens and priced accordingly.  I suspect the 45mm will be a lot more versatile.  Of course, if you can afford both, get both!
Anders W
Anders W Forum Pro • Posts: 22,144
I simply wouldn't be torn between them. There is no reason to be. Get them both. That's what I did and I don't regret it. Nor would I worry about flattening people's faces too much with the 75. I consider it well within the range of appropriate portrait lenses.
So the only question is really which to get first if you can't or don't want to buy them both at the same time. Here, I would certainly go for the 45 to begin with for a number of reasons. First, this is the focal length you are likely to use more often. The 45 works even in a room of ordinary size. For the 75 you need to be in a hall or outdoors. Second, it is smaller and lighter so that you can easily have it with you most of the time. Third, it is significantly less expensive while very nearly as good optically.
The 75 is more of a niche product. Fine for stage performances, stealthy street shooting, and outdoor portraits where you really want to blur the background as much as possible as well as a number of other things but still not as much of a must-be-there tool as the 45. It's no coincidence that FLs of about 45 mm are included in the range of kit zooms. The kit zoom gives you the FL but not the speed and shallow DoF that I would often want for a FL like this.
Panasonic Lumix DMC-G1 Olympus PEN-F Olympus E-M1 II Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G Vario 7-14mm F4 ASPH +20 more
5
I would note that the 75mm is outstanding for distant landscapes.  It's sharp edge-to-edge and distant objects still have great micro-contrast and dimensionality.  So many lenses seem to flatten everything at infinity.  This lens is good enough to retain the subtle gradations of color, light, and shadow that make landscapes stand out.
Of course, for nearby landscapes the lens is crap because you can't fit much into the frame.
Savas Kyprianides Veteran Member • Posts: 3,650
Get the 75mm.
OP ArthurG1987 New Member • Posts: 15
Thanks Anders. That's exactly what I wanted to know: what actually using the lens is like. I appreciate your feedback.
Prairie Pal Senior Member • Posts: 2,912
I have experience with neither of these two lenses , but today I chose to order the 45 for exactly the reasons others have already stated.  In case you don't already know; the compression of a focal length is the same in any format, ie 75mm has the same compression effect on MFT as it does on FF.  It's when you add a "tele-extender" that the compression is multiplied by the x-factor.
As you, I'm really drooling over the 75 because it creates the "whole package" that I'm looking for in an expressive art type lens.  However, I have similar focal lengths in Nikon glass that I have been using with an adaptor, to much the same effect, albiet manual focus.  Which is mostly okay with me because the type of composing I do at that focal length are usually static sceness that I can tolerate manual focusing.  I chose to get a dedicated AF 45mm lens for family and portraits where I don't want to risk mis-focusing by eye.
Still...man oh man, the 75 is a sweet package and would be so nice to hold.
 Prairie Pal's gear list:Prairie Pal's gear list
Nikon D600 Nikon D7200 Olympus OM-D E-M10 II Olympus E-M1 III Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II +6 more
Anders W
I haven't used mine for landscapes much yet. Nevertheless, I am sure you are perfectly right. I know that the focal length as such is sometimes just perfect when you want to cut out a particular area from a broader scene. And its micro-contrast as well as edge-to-edge sharpness are outstanding, which of course is a particular asset for scenes like this.
Sergey Borachev Veteran Member • Posts: 5,338
I am still saving for the 75mm, but based on years of experience using prime lenses, I have never found perspective distortion to cause a concern with faces except when the FL is less than 80mm equiv and over 300mm equiv.  When there is any problem, it is invariably the operators' fault rather than the lenses', usually because the operators were too close to a face.  With zooms, there are more problems due to barrel or pincushion distortions, but you are talking about primes.  Given the cost of the 45mm, the best answer would seem to plan to also get the other one at some time.  Then, it would seem the 45mm can provide more uses and give you something to use and play with and more time to act on the other.
tedolf
tedolf Forum Pro • Posts: 29,547
Yes......
Yes.
But that can be an advantage depending on your model.
If your model has Middle Eastern or Northern European features (big nose, big ears) this works well.
If your model is Asian the longer focal lenght will make her look like a child.
I have both focal lenghts (essentially, 40mm and 90mm) in manual lenses and the difference is subtle but noticable-exaclty what you want.
Tedolph
 tedolf's gear list:tedolf's gear list
Olympus PEN E-P5 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R Samyang 7.5mm F3.5 Fisheye +9 more
Skeeterbytes Forum Pro • Posts: 23,186
I have the 45 and not the 75, but use a fast legacy 85 from time to time, so can make a bit of a comparison. The 45 is an excellent resource inside and out, while I tend to only use the 85 outdoors. It requires working space that's sometimes just not available indoors, despite the lens' fast speed (f:1.4).
Doens't mean I wouldn't make space in my bag for the 75--I would gladly welcome it--but at twice the price of the 45 it has to justify the investment and so far, I've been able to resist. I consider the 45 to be the best prime for the money currently available to us.
BTW, 135mm has long been a mainstay for tight portraits (head, head and shoulders) in the 24x36 fomat world for decades. It's close enough to 75/150 that I think you can set aside any concerns of it producing odd results.
Rick
"Whiskey is for drinking, digicams are for fighting over."
—Mark Twain
eques Veteran Member • Posts: 4,115
A small point: just the shell is metal, inside it is all plastic and some glass, I suppose.
Some people say that the 75 is too sharp for portraits. I have neither, so I can not tell from my own experience. But I have to say, that legacy lenses with 50mm and 100mm give very nice portraits. SO the FL should not be a problem.
Peter
 eques's gear list:eques's gear list
Panasonic Lumix DMC-GX8 Panasonic Lumix G 20mm F1.7 ASPH Olympus 12-100mm F4.0
tedolf
Sharpness is not the issue.....
Peter
it is the change in perspective and how that effects facial features that the OP is asking about.
TEdolph
DLBlack Forum Pro • Posts: 15,865
I have both the Oly 45/1.8 ad the 75/1.8.  I like them both.  Still there is something a little bit special with the images the 75/1.8 produces.  Here is a photo from my first and only studio outing.
Since it was a photo club setting I really didn't have any control of the light output and had to shot at a smaller f-stop that I would have done if I had control of things.  I did have to get back to the far wall for my shots.
Dave
 DLBlack's gear list:DLBlack's gear list
Pentax K-7 Pentax K-5 Olympus E-M5 II Olympus PEN-F Olympus E-M1 II +46 more
5
Dave
Is she screwing her head on or off?
Russ Houston
Russ Houston Veteran Member • Posts: 6,377
I have both
They are both outstanding (equally so IMHO in terms of image quality).  The 75 feels great, but then the 45 feels fine to me as well.  I never got that "plastic" feeling some people talk about with the 45.
I had the 45 first, and was amazed at how well it performed.  The 75 is amazing in it's own right.  I use the 45 more often though.  I guess it's because of the focal length.  The 75 is a little more specialized since you have to have the room to use it.  It's a great concert lens.
One thing to keep in mind.  You'll need a good ND filter if you want to shoot it wide open during the day.  ISO200 as a minimum isn't your friend if you want shallow DOF on a bright day.
 Russ Houston's gear list:Russ Houston's gear list
Olympus OM-D E-M5 Olympus PEN E-P5 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital ED 14-42mm 1:3.5-5.6 Olympus M.Zuiko Digital ED 14-150mm 1:4-5.6 +7 more
