Superzoom lens for Sony a-65
Started May 5, 2013 | Questions
kotsoskotsas New Member • Posts: 1
Hi, I'm looking for a general use lens (travel) for my a-65.
I'm cannot decide between the following 4 lenses..
Sigma 18-250mm F3.5-6.3 DC MACRO HSM
or the old version of sigma
Sigma 18-250mm F3.5-6.3 DC OS HSM
Tamron 18-270mm F/3.5-6.3 Di II PZD
Sony DT 18-250mm F3.5-6.3
The price is pretty much the same (except Sony) Any help? pros/cons?
Thanks a lot!
ps. I know there is a similar question but didn’t want to interrupt.
Rashkae Senior Member • Posts: 1,176
Well...
Well... You could red through the previous similar 20+ threads of people asking for comparisons of those lenses...
Edward Sargent
Edward Sargent Veteran Member • Posts: 4,693
Re: Superzoom lens for Sony a-65
The old Sigma, there have been several threads on this subject in the last week. Do a search probably for 18-250 or a specific lens.
Sarge
A99| A77| A700
|8mm & 14mm Bower|Sony 28-75 & 70-300 G|
|35-70 & 50mm 1.7 Minolta |
|Sigma 18-250 - 70-200 - 50-500 - 2X TC|
|Tamron 90 - 1.4X TC|
Albums at www.sony-snapper.com
 Edward Sargent's gear list:Edward Sargent's gear list
Sony Cyber-shot DSC-QX10 Sony Alpha a99 Sony a77 II Sony 70-200mm F2.8 G Sony 70-300mm F4.5-5.6 G SSM +33 more
falconsusi Contributing Member • Posts: 560
I have the new Sigma 18-250 macro version and I like it much more than the Sony 18-250 that I sold.  The new version Sigma is sharper and quiet!  In fact I liked it so much that I told my brother who also has the a57 and Sony 18-250 and he also traded his Sony for the newer Sigma.  I have never used the older version Sigma 18-250 so I can not compare.
 falconsusi's gear list:falconsusi's gear list
Sony a77 II
EXX Contributing Member • Posts: 829
There is one thing to consider: only in case of the Sony 18-250, the A65 will have a lens profile for in-camera lens correction.
If you are a raw photographer and do everything with post-processing, this is a non-issue of course.
 EXX's gear list:EXX's gear list
Konica Minolta DiMAGE A2 Sony SLT-A55 Sony a77 II Sony DT 18-55mm F3.5-5.6 SAM Sony DT 16-80mm F3.5-4.5 ZA Carl Zeiss Vario-Sonnar T* +14 more
dlkeller Veteran Member • Posts: 6,922
Really love my Tamron 18-270 PZD.  Comparisons with the Sigma macro are pretty much even with each having advantages in different part of range.  They are both much lighter and smaller than the older Sigma version.
6 year US Warrantee and possible Sigma compatibility problems with Sony in the future swung my decision to Tamron, but Sigma seems to be working on this issue and it may not become a problem.
Dave
lross Junior Member • Posts: 44
Thanks a lot!
None of the above...   I found that zooming past 135mm things tended to get soft and that I was just as good taking a shot at 135mm and cropping it.   So I use a Tamron 24-135mm zoom for my walk around and it's sharp zoomed all the way in.   If the lens can zoom past 135 your going to use it and just find out later it's too soft.  I ended up doing that so much and getting frustrated later, when reviewing the shots, that I sold the lens.   Why kid yourself.
Setter Dog Veteran Member • Posts: 5,606
I had the older image stabilized 18-250mm Sigma and really liked it. I appreciated the stable look through the EVF. I sold it and bought the newer model. Well, I miss the stabilized lens but I like the smaller and lighter new version. To my eye, they are equal in image quality. For a travel lens, the newer model is probably a better option.
Jack
MrIchiro Forum Member • Posts: 76
if you can live without the wide angle, the Sony 55-300 is great..  A few shots I took with it:
This one was in Ho Chi Minh City..
this one's all the way out at 300mm
I cannot agree. I use the Tamron 18-270 f/3.5-6.3 Di II PZD and although the lens is not supersharp at the long end, it is definitely better than cropping from 135mm. Note: you have to stop the lens down to f/8 of f/11 for optimal results. Forget about good low-light performance with any superzoom, it is just not up to it.
Speaking about 135mm, there is another nice alternative: the new Sony DT 18-135mm F3.5-5.6 SAM. It uses a Smooth Autofocus Motor (SAM) for quiet focusing, with Direct Manual Focus override. It will most propably also benefit from the in-camera lens correction function in the A65.
