Can the battery for the EX1 also be used in the EX2F?
Started May 5, 2013 | Discussions
Mr Tudor
Mr Tudor Regular Member • Posts: 264
Specifications are as follows:
EX1 (SLB-11A) | 3.8V | 1130mAh (4.2Wh)
EX2F (SLB-10A) | 3.7V | 1030mAh (3.81Wh)
If it can be used, that would be good news as I have a few SLB-11As floating around.
Thanks in advance.
(unknown member) Veteran Member • Posts: 6,192
Re: Can the battery for the EX1 also be used in the EX2F?
I had a similar situation and I have been using the SLB-11A in the EX2f. As you show the voltage is slightly higher but it has not caused a melt down in the camera. I believe other people have have substituted the 11A with no adverse effects.
You do it at your own risk of course.
Thanks in advance.
Mr Tudor
OP Mr Tudor Regular Member • Posts: 264
Thanks for the reply. Interesting. I can't imagine that it would do any harm, but better safe than sorry. I have contacted Samsung for an answer. Will get back as soon as I have received a reply.
BTW the SLB-10A battery is not even listed on the Samsung site, only the SLB-11A is, which is somewhat strange.
Thanks in advance.
It has been discussed before as below and on other occasions I seem to remember.
http://www.dpreview.com/forums/post/50415486
If you do get a reply it would be interesting to see, I doubt if you will but hope springs eternal.
Thanks in advance.
Mr Tudor
Interesting that you found that link. I did not succeed there. Thanks.
quote: "I have heard that people have used the SLB-10A in EX1 model, so most likely they are interchangable.  The SLB-11A has four terminals but no one knows what the forth terminal is for, maybe samsung didn't either so they went back to the SLB-10A for the EX2F."
The poster talks about Samsung going back to the 10A, and yet, the only battery they offer is the 11A
So far I have not had a reply yet. Early days. Erm... I will keep you "in the loop"
Thanks in advance.
Thanks. If my EX2f self destructs using the 11 I will advise soonest.
Mike
Thanks in advance.
