Image quality NX210/200/1000 to Canon G1X, Olympus E-PM3 and others
Started Apr 28, 2013 | Discussions
miku84 New Member • Posts: 9
I am planning to buy the NX1000, which seems to be pretty much the same as the NX200/210 image quality wise.
I compared the RAW quality (using the dpreview compare feature) NX210/200 to the Canon G1X and the Olympus E-PM3 (and many others), and almost always the pictures of the NX210/200 look much more washed out, soft and low contrast compared to other cameras that I would expect to be worse (of course the E-PM3 has more noise, but apart from that).
Is the RAW image quality (and JPEG as well) of the NX210/200 really that much worse than the G1X, the E-PM3 or most other cameras I compared it to? Or is something wrong with the NX200/210 test setup? Or is the 60mm 2.8 macro lens used in the NX210/200 setup that bad?
thx in advance!
http://www.dpreview.com/reviews/samsung-nx210/6
Samsung NX1000 Samsung NX200 Samsung NX210
viking79
viking79 Forum Pro • Posts: 14,157
Re: Image quality NX210/200/1000 to Canon G1X, Olympus E-PM3 and others
thx in advance!
I find the RAW quality pretty close to Sony 16 or 24 MP sensor, maybe a bit worse high ISO but comparable at base ISO.
Part of the problem is the RAW converters might not have as good of default values for the Samsung cameras (for Sony, Nikon, Canon, etc) they have good profiles that match in camera profiles pretty closely.
DXO Mark has ratings for the NX20.  It rates very well.  I also think the 60mm lens might be questionable as the top half of the NX image looks a bit soft, maybe some lens alignment issue or something else.  The lens is very good overall, not my favorite lens for the system but very nice.
Eric
I never saw an ugly thing in my life: for let the form of an object
be what it may - light, shade, and perspective will always make it
beautiful. - John Constable (quote)
See my Blog at: http://www.erphotoreview.com/ (bi-weekly)
Flickr Photostream: http://www.flickr.com/photos/28177041@N03/ (updated daily)
Sony a7R Samsung NX1 Samsung NX 30mm F2 Pancake Samsung NX 85mm F1.4 ED SSA Samsung NX 60mm F2.8 Macro ED OIS SSA +5 more
OP miku84 New Member • Posts: 9
thx in advance!
Eric
Thank you very much for your insight. Also the lens really seems to be a bit soft in some areas, because i realized what I said above is only true for some parts of the image (middle-top).
thx
ChuckTa Senior Member • Posts: 1,492
I think DPR did a very poor job on the test images for the NX cameras. I suggest you look at other testing sites like IR. Use the image compare tools and look at the resolution chart and you'll have it has better resolution than the Nex 6 and comparable to Nex 7.
http://www.imaging-resource.com/IMCOMP/COMPS01.HTM
 ChuckTa's gear list:ChuckTa's gear list
Sony a7 Samsung NX500 Fujifilm X-T20 Panasonic Lumix DC-GX9 Panasonic Lumix DC-GF10 (GF90) +8 more
tecnoworld
tecnoworld Veteran Member • Posts: 7,232
I hope they'll do a better job with nx300, which is such a good camera.
 tecnoworld's gear list:tecnoworld's gear list
Samsung TL500 Samsung NX100 Samsung NX200 Samsung NX300 Samsung NX1 +15 more
(unknown member) Veteran Member • Posts: 6,192
E-PM3?
miku84 wrote:
I am plannig to buy the NX1000, which seems to be pretty much the same as the NX200/210 image quality wise.
thx in advance!
Mr.NoFlash Senior Member • Posts: 2,374
avoid NX210/200
see http://www.dpreview.com/forums/post/51300666
nx1000 is better,nx20 +nx300 much better
 Mr.NoFlash's gear list:Mr.NoFlash's gear list
Fujifilm FinePix Real 3D W1 Leica Digilux 3 Samsung NX300 Fujifilm X-M1
Thanks, it's very good to know that I am not the only one thinking that. And thanks for the link, much better!
Greynerd wrote:
E-PM3?
Sorry, I meant E-PL3 or E-PM or whatever, they all have the same sensor. You are right, there is no E-PM3
