Getting the best from Olympus TG2
Started Apr 26, 2013 | Questions
Heppyhooka New Member • Posts: 3
After some intense research I decided on the TG2 for home and holiday requirements. The daylight photos come out absolutely fantastic but I find that when shooting at night under artificial light in automatic or other modes, the quality is not what I was expecting. Is this a generic digital compact issue or is there any way to improve the quality of the pics? Any suggestions?
Jefftan Veteran Member • Posts: 3,501
Re: Getting the best from Olympus TG2
My experience is same as you.  I don't have all the answers but some suggestions
1. If you believe you have steady hands set ISO to 400 in not too dark shooting situation like indoor lighting.  IQ degrade a lot after ISO 400
2. The biggest problem of TG-2 is missed focus when there are lots of little light in a dark scene (such as street light).  The solution to this is to point the camera at other point, acquire focus with half press shutter than move the camera back to original street light scene and press fully down to shoot
But there are many times the camera just miss focus in low light for no obvious reason.  This is a big problem and happen very often in night time.  The green box confirm focus but image come out blur.
Right now my only solution is to use "spot" focus (central focus) which seem to help a bit but still lots of missed focus images.  I wish someone can offer other solutions.
Besides this problem this is a great camera in good lighting.  Some of my ISO 100 image can be confused with image I take with my NEX-5N
Mittskitts Contributing Member • Posts: 897
I have a TG-1. I use center focus and look for something with a high contrast edge to focus on that is at the correct distance, then recompose.
 Mittskitts's gear list:Mittskitts's gear list
Olympus Tough TG-1 iHS Olympus SH-50 Olympus Tough TG-3 Olympus TG-6 Nikon Coolpix P950 +12 more
Can you explain what is high contrast edge? So this missed focus thing also happen in TG-1?
Would disable the focus assisted beam help? any other solution?  This problem is the most severe among all cameras I have ever used
and I have used at least 7 cameras since 2006
I hadn't really noticed a big problem with missed focus with TG-1. I have gotten used to dealing with this on my E-PL1 which has a real problem finding focus in low light, and it hunts around and sometimes locks on a big blur. I look around for something at similar distance to my subject that has a sharp contrast between the dark and the light, like a door edge or furniture edge or lampshade edge or shirt collar, and let the camera lock on that and then recompose.
OP Heppyhooka New Member • Posts: 3
Many thanks Jefftan. I will try this out and let you know. We had the most fantastic moonrise the other evening and try as I might I could not get a good clear shot of this moonrise. Are my expectations too high with this camera?
Thanks Mittskitts. Also some good advice and I will play around with this for the next few days and let you know how this worked for me.
What about using a tripod for the moonrise than you can use ISO 100 which will bring out the best from the camera
This camera is indeed very good at ISO 100, no missed focus in good lighting and pics can look like taken from my NEX-5N (an APS-C camera 13 times the sensor size) This is no small achievement for a small sensor compact waterproof or not
Better than I expect before I buy this waterproof camera and certainly better than all waterproof camera that I used before Sony TX5, Panasonic TS1
If only I can solve the missed focus problem in low lighting, I will be very happy
But even if I can only use it in good lighting at ISO 100/200 and get excellent pics, I would still be happy and not regret buying this great camera
This may be due to the miss focus problem in poor lighting that I am also having great trouble with
Whenever light level fall, this camera has trouble focusing.
One solution is to focus somewhere else using spot (center) focus with some bright subject than recompose
another is to take multiple pics until you get a properly focus one.  My experience is if the first miss focus, the second one or third one may be OK
no perfect solution that I can find now.  Hopefully there will be a firmware update
jmac221 New Member • Posts: 2
My TG2 seems to have an intermittent focus problem.
Something focus seems to physically stick.
When this happens, I can sometimes get focus working with a gentle tap to the camera with the palm of my hand. When this does not work, i need to reboot the camera.
I have also noticed that this condition is more likely to happen after I try to make a change in zoom/focal length. Additionally, more likely to happen after sitting a few minutes with camera "on" (waiting for "the shot").
Anyone else with similar TG2 condition?
It is a great little camera and I like it a lot for whitewater kayaking. I'll observe the TG2 for a couple more days. It will prob be sent back to Olympus for repair...hopefully under warranty.
My missed focus problem is always happen in low light.  Very rare in good lighting
It happen very often to be a big problem in low light.  Way to work around it is to use central focus than point the focus point at a bright subject, half press shutter to lock foucs than recompose
but the remove the fun of photo taking
I think I also have to send it back for repair
Jmac221, are you also having lots of missed focus in low light (green focus confirmation box but image come out blur)
BorisK1 Veteran Member • Posts: 5,645
The TG-2 locks exposure together with the focus. If you lock focus on a bright object, then turn sideways and shoot a dark subject, the shot will be underexposed. You might be able to fix it with exposure compensation, but it will slow you down and, most likely, will take several tries for each shot.
 BorisK1's gear list:BorisK1's gear list
Olympus Tough TG-4 Olympus E-3 Olympus Zuiko Digital ED 50mm 1:2.0 Macro Olympus Zuiko Digital ED 40-150mm 1:4.0-5.6 Olympus Zuiko Digital 11-22mm 1:2.8-3.5
