nx210 Flash help (radio transmitter aftermarket flash?)
Started Apr 22, 2013 | Discussions
rminkes New Member • Posts: 2
got myself a "new" second hand camera to replace my Cannon 400d. at 500 euro for the nx210 with a 18-50mm, 30mm lens and  50-200mm lens i thought it was a steal. but now I’m trying to use my old flash (a really old vivitar 2800) on i was using with my cannon camera to work and it does not. im using a cheap aftermarket radio transmitter to bounce the flash upwards in mu miniature home studio. but it seems  they nx210 doesn't want to work with any with it.
does any one know of a cheap radio transmitter that will work? or do i need to get also a newer flash with it?
(if not it seems that the i will just put the nx210 on the marked again and get another camera)
Canon EOS 400D (EOS Digital Rebel XTi / EOS Kiss Digital X) Samsung NX210
dlacoutu Contributing Member • Posts: 811
Re: nx210 Flash help (radio transmitter aftermarket flash?)
From memory, Samsung prevented dumb flash firing since the NX200. You have to plug a Samsung-compliant flash...
 dlacoutu's gear list:dlacoutu's gear list
Samsung NX100 Pentax K-5 Samsung NX200 Pentax smc FA 50mm F1.4 Samsung NX 30mm F2 Pancake +6 more
Bryan M
Bryan M Contributing Member • Posts: 956
The first thing I would suggest is playing with the physical location of the transmitter in the hot shoe. In my case I have to move the trigger back slightly for it to make proper contact. I happen to use the Yongnuo RF-603n trigger and have no issues with them beyond having to re-position them slightly. I use the NX210 as well.
Bryan
www.bcmcue.com
 Bryan M's gear list:Bryan M's gear list
Nikon D750 Nikon Z6 Tamron SP 70-300mm F4-5.6 Di VC USD Tamron SP 70-200 F2.8 G2 Nikon Z 14-30mm F4 +2 more
viking79
viking79 Forum Pro • Posts: 14,157
I have no issues with my cactus V2 on my Samsung NX20 or NX300.  Some triggers work and some don't.  A point is Samsung paints the sides of the hot-shoe contacts, you might have to scrape the paint off that fine edge so the flash/transmitter can make a good ground contact.  This assumes the hotshoe is grounded, it might not be.  As I said, my trigger was no issue.
http://www.dpreview.com/forums/post/50898060
Not sure if that will help or not.  It might be your trigger has contacts that are annoying the Samsung camera.  Could try masking off the ones except the center.
Eric
I never saw an ugly thing in my life: for let the form of an object
be what it may - light, shade, and perspective will always make it
beautiful. - John Constable (quote)
See my Blog at: http://www.erphotoreview.com/ (bi-weekly)
Flickr Photostream: http://www.flickr.com/photos/28177041@N03/ (updated daily)
Sony a7R Samsung NX1 Samsung NX 30mm F2 Pancake Samsung NX 85mm F1.4 ED SSA Samsung NX 60mm F2.8 Macro ED OIS SSA +5 more
WMT Junior Member • Posts: 40
I`m using cheapo CTR-301P radio trigger with two recievers on my nx200 and it works fine. You can grab it on ebay for 20 bucks or so. Nothing fancy but good enough for messing around when I feel like it (:
Paul Panetta Regular Member • Posts: 327
I assume that you are not including the NX200 in that statement as my NX200 works fine in Manual mode with an Olympus FL-36R flash (also in manual mode).  The camera has the last available firmware.
 Paul Panetta's gear list:Paul Panetta's gear list
Pentax Optio A20 Ricoh Caplio G3 Ricoh Caplio GX100 Pentax K-x Samsung NX100 +5 more
OP rminkes New Member • Posts: 2
Thank you for the reapply.
order a set of Yongnuo RF-603n from ebay hopefully they will work. what firmware are you running?
Kaziklu Senior Member • Posts: 1,301
using the Yongnou flash a Cactus transceiver has worked just fine.  The Yongnou transceivers (the 603's you ordered) have worked as well. I have not used but have seen a pocket wizard fire the flash. I have also used the Yongnou on camera just fine.
Sadly I haven't tried anything older then the Yongnou 560exII flash.
 Kaziklu's gear list:Kaziklu's gear list
Samsung NX20 Samsung NX1 Samsung NX 30mm F2 Pancake Samsung NX 18-55mm F3.5-5.6 OIS Samsung NX 50-200mm F4-5.6 OIS +1 more
Bryan M
I am using the 1.11 body firmware and 1.0 lens firmware.
Bryan
www.bcmcue.com
