That "L" lens "look" - Canon v Sigma 35mm1.4
Started Apr 22, 2013 | Discussions
kipling Regular Member • Posts: 431
I have been looking for a used 35mm 1.4L because I tried one a few years ago and was impressed with the colour of the images. Now I read reviews of the Sigma 35mm 1.4 and the consensus seems to be that technically it is superior, or at least equal, to the Canon. And cheaper. Certainly seems to be sharper at f1.4.
But my experience with "L" lens is that their colour, contrast or whatever, is great, and maybe more important than sharpness. Sharpness can be measured but the "look" that I'm speaking of is a purely subjective thing. There would be plenty of room for disagreement.
So what do you think? Does any undefinable quality of the Canon lens overcome the technical superiority of the Sigma lens?
Cheers
Gearóid Ó Laoi, Garry Lee
Gearóid Ó Laoi, Garry Lee Veteran Member • Posts: 6,186
Re: That "L" lens "look" - Canon v Sigma 35mm1.4
The red ring?
Níor bhris focal maith fiacail riamh (Irish Gaelic)
A good word never broke a tooth.
 Gearóid Ó Laoi, Garry Lee's gear list:Gearóid Ó Laoi, Garry Lee's gear list
Canon PowerShot S90 Fujifilm X10 Panasonic FZ1000 Sony Alpha NEX-7 Canon EOS-1D X +26 more
rebel99 Veteran Member • Posts: 4,025
i am not a fan of 3rd. party lenses at all with the exception of may be zeiss lenses. from my experience, if you can afford the "L" lens, buy it. or wait till you can afford it
cheerz.
OP kipling Regular Member • Posts: 431
Gearóid Ó Laoi, Garry Lee wrote:
The red ring?
I am actually looking a bit further than the red ring.
MASTERPPA Contributing Member • Posts: 867
From what I have READ, Sigma for now, has beat Canon as far as look and sharpness.  I am sure if Canon releases a new version of that lens is will be better.
Here is MY issue with Sigma and Tamron AF lens. Canon lenses for some reason, as in they AF communication with their lenses, are better BY FAR then Sigma and Tamron.
The AF speed of a native Canon lens is always faster in most cases..
Cheers
MOD schmegg Veteran Member • Posts: 5,768
I have used both and settled with the Sigma. I liked it just a bit more - and value wise, in my personal opinion, it is a clear winner.
But, as you say, it is very subjective, and there certainly is room for disagreement (as there should be in any rational discussion about which of two fine lenses is better!)
I totally agree with you that sharpness isn't everything. And if I already owned the Canon, or the Zeiss, then I wouldn't consider trading for the Sigma. I'm fairly certain that all these 35's are more than capable of delivering top quality images.
photokandi
photokandi Forum Member • Posts: 97
If both lenses were the same price I doubt you would have the Sigma on your camera right now.
 photokandi's gear list:photokandi's gear list
Canon EOS 5D Mark II Canon EF 50mm f/1.2L USM Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F4L IS USM Carl Zeiss Distagon T* 2,8/21 +1 more
Perhaps - as I prefer to go for Canon glass usually - so maybe I'd have already gotten the Canon. But in this case, I wouldn't be so sure if I was you, particularly considering thispost of yours, where you talk about how much you rate sharpness! If you like the sharpness of the 24-70, then you'll definitely like the Sigma 35 - it's sharper.
sean lancaster
sean lancaster Veteran Member • Posts: 7,326
I am not married to Canon (I had a Nikon D70 for many years and a Sony for a spell after that). But I wanted to figure out lenses before I bought into my next system (I ended up going with the Canon 6D, fwiw). And, I spent hours comparing the Canon 35/1.4 to the Sigma 35/1.4 on Flickr looking at the shots I like to shoot (largely wide open using available light). My conclusion is that I liked the Sigma better. I did not compare these lenses at f/5.6 or f/8 so perhaps the Canon becomes the choice - I honestly don't know. But I don't buy a fast prime to stop down as there are plenty of good lenses at f/8 that are cheaper.
 sean lancaster's gear list:sean lancaster's gear list
Sony Alpha NEX-5N Sony a7R II Voigtlander 35mm F1.2 Nokton Sony FE 55mm F1.8 Sony FE 28mm F2 +4 more
(unknown member) Senior Member • Posts: 1,144
I recently sold my Canon 35 1.4 after acquiring a Sigma 35 1.4. Truth in advertising, I bought the Sigma to use on my Nikon D800.  Nonetheless, I was rather disappointed with the Canon's high level of CA especially at large apertures.  I had been hoping for an update before switching to Nikon.
So far, the Sigma hasn't let me down.  In addition to sharpness, it produces fantastic color and contrast.  I have no doubt that I'd choose it over the Canon 35 if I wanted a 35mm for my Canon photography (I still shoot Canon but only use 2-3 lenses).
gatorowl wrote: right now.
Thanks for that. Colour is seldom mentioned in reviews. From what you say it does seem that the Sigma is a real competitor for the Canon.
turbsy
turbsy Contributing Member • Posts: 905
ChCheers
None of that is true. How is the communication between first party lenses better by far?  And how can something always be faster in most cases. Mothers are many third party lenses  that are just as fast to autofocus as first party.
 turbsy's gear list:turbsy's gear list
Olympus XZ-1 Nikon D50 Nikon D300 Nikon D800 Nikon AF-S Nikkor 300mm f/4D ED-IF +11 more
Because the AF data is proprietary and Canon does not give it away. It has to be reverse engineer by Tamron, Sigma, etc.. Every 3rd part lens I have used, and it was the best of the group, I notice always was a little slower, or not as accurate as the Canon lenses. (when compared to the L lens)
Alastair Norcross Veteran Member • Posts: 6,414
I love everything about my 35L, except for the CA wide open. While it is easily fixed in post, it would be better not to have it in the first place. Does the Sigma have significantly less CA wide open? As for sharpness, I'm sure that the tests are correct, and the Sigma is slightly sharper, but I really can't imagine wanting or needing more sharpness than I get from my 35L. If I was choosing now between the Canon and Sigma, I might well go for the Sigma, but I don't think it's worth the trouble of selling my 35L to get the Sigma.
Alastair
http://anorcross.smugmug.com
Equipment in profile
 Alastair Norcross's gear list:Alastair Norcross's gear list
Canon G7 X II Canon EOS 7D Mark II Canon EOS M6 Canon PowerShot S100 (2000) Canon PowerShot SD450 +19 more
MAC Forum Pro • Posts: 13,825
agree, one buys these lenses to shoot f1.4-f2
http://www.the-digital-picture.com/Reviews/ISO-12233-Sample-Crops.aspx?Lens=121&Camera=453&Sample=0&FLI=0&API=0&LensComp=829&CameraComp=0&FLIComp=0&APIComp=0
 MAC's gear list:MAC's gear list
Canon EOS 6D Canon EOS Rebel SL1 Canon EOS 7D Mark II Canon EOS Rebel T7i Canon EF 70-200mm f/2.8L USM +8 more
yes, the sigma has less ca - you can see the diff here
the canon has the faster focus speed though
Alastair
turbsy
I know that engineer doesn't license the ef mount.  and I am aware of the reverse engineering  but In the last few years I have not seen any issues from higher end third party lenses.  Can you give me an example of a lens from a third party that is less accurate?
Schwany
Schwany Forum Pro • Posts: 10,129
Depends on whom one is disagreeing with. I wouldn't want to disagree with a moderator. Bad things could happen. he he
I neither agree nor disagree, or care really, but I wouldn't buy a Sigma lens under any circumstances. That is my narrow minded biased personal choice, which should be allowed with or without the proper charts and blog links.
 Schwany's gear list:Schwany's gear list
Canon EOS-1Ds Mark II Canon EOS 5D Mark II Canon EOS-1D Mark IV Canon EOS-1D X Canon EF 24mm f/1.4L II USM +14 more
carlk Forum Pro • Posts: 15,940
I remember some hot debates years ago on this subject but they ended with no one can tell in blind tests which has better color between L and non-L lenses.  There might be some differences in the old days but it's a non-issue this day and age with advanced coating not to mention pp software that can produce pretty much any color you want.
 carlk's gear list:carlk's gear list
Canon EOS 50D Canon EOS 7D Nikon D800E Fujifilm X-E1 Canon EF 85mm f/1.2L II USM +6 more
I also doubt the L myth can survive if both lenses can fetch the same price.
