Portrat lens for groom as well as bride
Started Apr 19, 2013 | Questions
Phillip Tornero Contributing Member • Posts: 601
No text.
 Phillip Tornero's gear list:Phillip Tornero's gear list
Sigma 30mm F1.4 DC HSM Art Tamron 15-30mm F2.8 Canon Pixma Pro9000 Mark II
OP Phillip Tornero Contributing Member • Posts: 601
Re: Portrat lens for groom as well as bride
Sorry I meant to add more to the post, but aside from the conventional 50mm prime which I have seen used for single portrait use, what would be a good fast lens to use for a pic of the bride and groom? thanks to all.
ThatsTheShot
ThatsTheShot Forum Member • Posts: 57
85mm ?
 ThatsTheShot's gear list:ThatsTheShot's gear list
Canon EOS 5D Canon EOS 5D Mark II Olympus OM-D E-M5 Canon EOS 5D Mark III Olympus PEN E-P5 +24 more
Duh! I just thought of the 85 as well ! lol!
SithTracy
SithTracy Regular Member • Posts: 360
Full Frame or APS-C?
 SithTracy's gear list:SithTracy's gear list
Fujifilm X-Pro1 Canon EOS 5D Mark III Fujifilm X100T Fujifilm X-Pro2 Canon EF 50mm f/1.4 USM +20 more
tonyjr
tonyjr Veteran Member • Posts: 5,281
I use the 17-55 and the 70-200 .
I want the cross behind them to be in focus , others want bokeh .
People use the 35 1.4 , 50 1.4 , efs 60 , 85 and 135 primes .
Other use the 15-85 , 17-55 , 24-70 , 24-105 and different versions of 70-200 .
You have not given much info . FF or crop ? Landscape or portrait mode [ sometimes I use the 10-22 in landscape mode .
 tonyjr's gear list:tonyjr's gear list
Canon EOS 400D Canon EOS 7D Canon EF 35mm F2.0 Canon EF-S 10-22mm f/3.5-4.5 USM Canon EF-S 17-55mm f/2.8 IS USM +14 more
Thorbard Contributing Member • Posts: 689
Many many other lenses will work too.
A picture of the bride and groom is not very specific or particularly difficult, unless there is something else you're trying to achieve.
 Thorbard's gear list:Thorbard's gear list
Canon EOS 7D Canon PowerShot G15 Canon EF 85mm f/1.8 USM Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 40mm f/2.8 STM +2 more
TristatePhoto Forum Member • Posts: 67
There is no right or wrong answer to this question as it depends on the look/style of the shot that you're going for.
Every lens is viable from a 8mm fisheye up to a 400mm with a tilt shift lens in between.
tonyjr
MP-E 65 ? Not trying to stir pot , just forgot to Subscribe to email updates .
But since I am wanting the mp-e 65 and I know the EFS 60 will work , just wondering
BAK Forum Pro • Posts: 23,797
probably a telephoto
You need to stand back quite a way, so the real photogrpaher can take the real pictures, without having amateurs standing in the way.
A 70-200 would work well on a so-called crop camera at the 70 mm end for full length two-person portraits, and the 100-150 range would be good for a horizontal upper body two-shot.
For a so-called full frame camera, you've probably got a normallens thatwouldworkfine for the vertical full length shot, and a focal lengthin the100-135mm rangeshouldlet you stay outof the way for the horizontal two-shot.
BAK
