Olympus E-PL5 or Panasonic Lumix G5
Started Apr 17, 2013 | Discussions
Aleo Veuliah
MOD Aleo Veuliah Forum Pro • Posts: 14,740
Re: Olympus E-PL5 or Panasonic Lumix G5
Both are good, but different form, depends on your taste and the features you need.
Simplicity is the ultimate sophistication.
Learn the rules like a pro, so you can break them like an artist.
Pure logic is the ruin of the spirit.
If plan A doesn't work, the alphabet has 25 more letters, keep calm.
Imagination is more important than knowledge.
God is the tangential point between zero and infinity.
Aleo Photo Site
 Aleo Veuliah's gear list:Aleo Veuliah's gear list
Panasonic Lumix DMC-ZS1 Panasonic FZ1000 Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-G2 Panasonic Lumix DC-G9 +7 more
JCB123 Senior Member • Posts: 1,274
 JCB123's gear list:JCB123's gear list
Sony RX100 Nikon D90 Nikon D7000 Olympus PEN E-PL5 Nikon D7100
Jorginho Forum Pro • Posts: 14,480
Re: I have EPl5 and Gh2
Oke...my take.
1) IBIS is very usefull. Don't know if it is equal to EPL3 or not. it seems so. here is what dpreview says about it:
"With image stabilization enabled, our experience shows the E-PL3 capable of delivering up to three additional stops of acceptable image sharpness. In other words, with IS mode 1 active, we found we could reasonably expect to use a shutter speed three stops slower than the 1/effective focal length minimum and retain acceptable image sharpness."
here is what Robin Wong says about EPl5
"....The ideal wish for everyone would be having that awesome new 5 Axis IS, but after using this E-PL5 for the whole day and night shooting the wedding, frankly the 2 Axis IS was no slouch either. There was not that many instances I employed slower shutter speed, but when I did, I slowed it down to 1/25sec (shots at the balcony overlooking KL skyline) to capture more ambient light. NONE of my shots (I have a thousand over) came out blurred, and that was very impressive. Using the OM-D's 5-Axis IS would allow you to push the limit and go slower in the shutter speed, providing that extra insurance, but for most practical shooting and watching the rules of thumb for minimum shutter speed = 1/focal length, I believe the old 2 Axis IS on the E-PL5 does its job very well."
My experience too. Just tried the 45-200 mm Panny at 200 mm with 13 sec exposre on EPL5. With IBIS, without IBIs but with OIS...Ois fared a little worse! On the 100-300 mm at 300 mm, the story changes, now the IBIS is a little worse.
So while I will have to carry a EVF and that flash with me, you'll need a tripod to get each and every lens on the G5 stablized. If you have one.
Flash: never use it. Such built in flashes are as usefull as ISO 12800: only when there is no other way. I rather have the Nissin 466 with me. That is a proper flash.
EVF: during winter I don't need one as there is no sun, mostly snow and rain and clouds In the summer it is not very sunny either. So I can carry the cam with me all the time. Why?
Its volume speaks volumes: a mere 267 cm3. Versus G5 = 707 cm3. According to camerasize comparison. Seems quite big to me and I think they they used the protruding EvF as a basis, so in reality the difference is not that big. But it is quite notable.
Is there a reason why I should not use the 14-42 X lens on the EPL5? I don't think so. Is there a reason why I need that lens? For having this camera being really pocketable in one pocket, the 20 mm 1.7 is what you really need. it is smaller. And oh yea: it is stablized on the Oly. Nice.
And the EPl5 IQ simply is better and it is not the noise, that is not suich a big difference. it is the DR, the tonality and the colourdepth and you do not need to have superlarge prints to see it. that is for noise. You see it immediaately ever when the difference is there.
JPEGS is personal, but even GH3 is considered to be inferior to Oly's.
I don't know, but you come across asd a bit overzealous to me when addressing these points. To my mind, you underplay the Oly strenghts and you upplay so to speak the Panny strrengths and weaknesses.
I stick to my conclusion, I have EPl5 and GH2 so I think I talk out of experience with both cams (even though G5 is not identical to Gh2, it is very close in each and every way).
 Jorginho's gear list:Jorginho's gear list
Olympus PEN E-PL5 Panasonic Lumix DMC-GH4 Olympus E-M1 II Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G 20mm F1.7 ASPH +8 more
Cheezr
Cheezr Senior Member • Posts: 1,173
You have to buy what works for you.
In my case the articulating display and IBIS were the deciding factors.
CZR
Life is uncertain, eat dessert first.
BigLoggerhead
OP BigLoggerhead New Member • Posts: 18
Well, my first impulse after weeks of reading and researching was to purchase the E-PL5. In fact, I really wanted the OMD but just couldn't justify spending $1200 for my first interchangeable lens camera. By purchasing the E-PL5 I have a camera I can learn with and will be a great travel camera and I still get that great sensor. Plus, now I can trick my wife into letting me upgrade later and pass the E-PL5 off to her. 😊
Linus M Regular Member • Posts: 176
Thanks Guy
Just had a look at your page.
I used to go there for my EPL-1 which I still think is the second best Pen for picture quality after the EPL-5.
I somehow had not realised that I can put My modes on the Mode Dial.
So after reading, thats the first thing I did. Really great to have it right there.
Keep up the good work.
Linus
 Linus M's gear list:Linus M's gear list
Olympus PEN E-PL5 Olympus Zuiko Digital ED 40-150mm 1:4.0-5.6 +3 more
2eyesee Senior Member • Posts: 2,210
Hen3ry wrote:
Jorginho wrote:
GH2 is virtually the same as G5. Same sensor, better video, a bit more controls, similar size.
I bought EPL5 not forthe better IQ, but mainly to have a cam with me all the time. Now someone says that with the EVF the EL5 is bigger. That is not true at all. The body of the G5 is really more bulky. Much more bulky. And it weighs more. You can have the EVF in one pocket and the cam body in another if it won't fit. This is not possible with the G5. Gh2 was a cam that was too bulky to take with me all the time and EPL5 really is not.
Jorginho
I'm sorry I have to say, that is nonsense. If you want to shoot eye level, you MUST have the VF2 fitted. Carrying it around in a separate pocket -- phooey!!!
Go and check the specifications! 320g for the E-PL5, 396g for the G5. Now add the VF2 to the E-PL5, then add the stupid little accessory flash and that takes the E-PL5 up to the same weight as the G5 -- but you are suffering the disadvantage of having three pieces of equipment instead of one.
That leaves the depth dimensions of the two cams. Add a standard lens -- hey! the depth is the same!!!
But add the X 14-42 to the G5. Hey! The G5 beats the E=PL5 on depth!!!
The G5 looks chunkier than the E-PL5 and it is a little larger if you don’t want to shoot at eye level (as I do nearly all the time) and if you are willing to sacrifice eye level shooting and quick operation to have fill-in or low power flash.
Pro's G5:
- electronic shutter (does not wear out, no shuttershock so no blurring because of that).
- Ergonomics
- Swiveling display that is fully used
- Better balance with larger lenses
- Better manual controls
- Better video
- Lenses with some aberations of Panny will be autocorrected in cam
That last SHOULD read
- In-camera auto correction for CA and distortion generally for Panny lenses --a significant advantage.
Then add:
- BUILT-IN, FLIP-UP FLASH for quick fill-in or a quick flash shot when you want it.
- Superior IS with OIS when using Panny lenses.
- Native Panny X lens implementation.
- Very superior ergonomics in the business.
Watch out for this:
- Oly lenses are not stabilsed, which for the greater focal lentghs or low light shooting is a clear disadvantage. So to me, the lens choice is more  a problem for Panny than Oly...but..
- BUT the IBIS on the E-PL5 is still pretty rubbish and can damage pix. E-PL5 users don’t dare use their IBIS unless they are working at distressingly low shutter speeds so this problem is rare.
Pro's EPL5
- Size and weight
- BUT only if you use the E-PL5 body as is and do not add the VF2 or VF3 and the silly little accessory flash. With these added and a lens, i.e. with nearly equal functionality, the dimensions are pretty much the same.
- IQ is notably better, a step you'd expect from a sensor that is one generation ahead
This is true at pixel peeping magnifications.
- JPEGS and art filters are very usable, fun to use and very good. I enjoyed these much more than I ever expected
Just like the G5. Frankly, I have no use for this stuff, though.
- IBIS, all  lenses are stabilised. Also: preference setting (if you do use a lens with stabilsation that will automatically be used instead of IBIS)
I have yet to see any published evidence that the IBIS in the E-PL5 is any better than the IBIS in the E-PL3. I see no mention of it in the Olympus announcements. The E-PL3 IBIS is rubbish. If it is switched on at shutter speeds higher than 1/10 second, you either get no useful effect or your risk damaging your pictures with double images. How often do you shoot at 1/10? The Panny OIS is much superior.
- Mysets lets you configre four buttons to you favourite settings. So yu can set the cam for a special purpose, just set it via that button and you can go ahead. Great!
True -- but you need these because of the terrible ergonomics and lack of controls. I haven’t investigated this specifically, but I believe the G5 also has some provision for presets.
Watch out for this:
- Some Panasonic lenses show banding in high ISO shots and are not corrected in the body. The first thing seems sensor related (also banding with GH3), the second thing can easily be dealt with in LR.
"Easily dealt with in LR"? Oh -- so you need to add LR to the E-PL5 to give you what the G5 gives you out of the camera?
AND the E-PL5 does NOT correct for CA with Oly lenses either! It does not correct CA with ANY lens!
- tiltable screen is 3"but only 2,5"is used. It is nice screen, but it is a bit strange also and not ideal.
Not nearly as useful as the G5's full articulated screen.
If you want a very portable camera with the best IQ there is in m43s, it is the EPL5 to my mind. If you want the best all round cam which still is extremely small compared to DSLRs and you don't mind a bit more size and weight I think the G5 is the better camera.
Ah, you got the summary right except you should have added for the G5, IQ which is as good or better than you would want for all practical purposes.
Cheers, geoff
Placing multiple exclamation marks at the end of your sentences doesn’t make your comments any more valid. What I see in your comments is you that you are making absolute judgements against the E-PL5 based on your personal preferences.
If you want a viewfinder, of course it doesn’t make sense to get an E-PL5 and add an expensive accessory. You would just get a camera with a built-in viewfinder.
For me, I was happy to leave a viewfinder behind years ago when I switched from DSLR to mirrorless. The same with a built-in flash. I don’t have much use for direct flash – if I want a flash I want a bounce flash. Having the built in flash and viewfinder on the G5 is added bulk for features that are of no use to me. But if they are important to someone then I certainly wouldn’t suggest getting an E-PL5 over a G5.
Your comments on IBIS on the E-PL5 being poor is fair, but you overstate the disadvantage of this. Remember, with a Panasonic body you don’t get any stabilisation at all with most of the prime lenses – and there’s nothing to stop you putting a stabilised Panasonic lens on an Olympus body. That’s what I have done - put a Panasonic 14-45mm on my E-PL5. I get the best of both worlds – great IS from the Panasonic lens, great IQ from the E-PL5 sensor.
Just clarify your comments about CA and distortion with Panasonic lenses on Olympus bodies - Olympus bodies do give you distortion correction with Panasonic lenses – just not chromatic aberration removal. But again, you overstate the significance of this. In my case CA is not really an issue – the Panasonic 14-45mm has CA pretty well controlled. But if it is present it is literally a 1-click in Lightroom to remove it.
Many of us on these forums already have Lightroom and it is part of their normal workflow. I’ve never made use of a photo that I didn’t do some post processing on – even if it is just bit of crop or levels adjustment. So no additional effort is required just to click a slider to remove CA if it’s a problem. You could even add it as a default preset to make it a no-click operation.
Your comments on the tilting LCD of the E-PL5 vs the fully articulating LCD of the G5 are again just a matter of personal preference. I’ve seen many comments from those who specifically don’t like swivelling the LCD out to the side of the camera to take a photo. The main advantage of the fully articulating LCD used to be that it was the only way you could get the LCD facing forward for self portraits. But the LCD on the E-PL5 – like the Sony NEX 3N and F3 – will tilt right up to face forward. So I don’t see much difference in the usefulness of the screens in this regard.
And finally, you seem to have a very grudging acknowledgement that the E-PL5 has better IQ than the G5 with your comments like “… true at pixel peeping magnifications” and that the G5 has “IQ which is as good or better than you would want for all practical purposes”. Surely you’re not suggesting that the E-PL5’s IQ is too good to be of any practical benefit?
