Email and windows 7
Started Apr 14, 2013 | Discussions
Philip Veteran Member • Posts: 4,009
Email and windows 7
When I upgraded from Windows XP to Windows 7 Ultimate I installed Thunderbird as my email software.
I do not like it at all. Outlook Express runs rings around it.
Can anyone give me a good alternate to Thunderbird; one that you yourself are using?
Thank you,
Philip
Zone8 Forum Pro • Posts: 17,276
Re: Email and windows 7
Hola Philip (also from Andalucia)!
I use Thunderbird and it is, imho, excellent PROVIDED you set it up correctly.  I can only assume you have not done that as once accomplished, it replicates exactly all the mail and folders on all my online mail accounts (so as I opted to download but as copies, leaving mail in their online folders, it produces a secure backup procedure).  Have never been more satisfied with an e-mail client - and I used both Outlook and OE for many years, with Mailwasher as the barrier.
Check your Thunderbird setup - if you spend a little time doing that I am sure you will find your observations are based on not so doing.
Zone8: Although I am a handsome genius, when I stand in front of a mirror, I vaguely recognise the ugly idjit standing on the other side!
LINK: For B+W with Epson 1400 (and other models) using black ink only PLUS other useful tips:
http://www.photosnowdonia.co.uk/ZPS/epson1400-B&W.htm
Cleaning DSLR Sensors, including Kodak DSLR Factory Cleaning method:
http://www.photosnowdonia.co.uk/ZPS/KodakDCS-sensorcleaning.htm
Solving back/front focus problems on Sigma and most other DSLRs
http://forums.dpreview.com/forums/read.asp?forum=1027&message=35565277
PDF format list of lenses you can print or download - covers Italian Flag YES/NO for DCS 14n but applies to others. http://www.photosnowdonia.co.uk/ZPS/ItiFlagLensList.pdf
skyglider Veteran Member • Posts: 4,735
+1.  Totally agree.
I used Outlook Express when I was running WinXP.   When I moved to Vista and Win7 I started to use Thunderbird and in my view, it's a lot better than Outlook Express.
Thunderbird can:
  • Setup all the same folders that Outlook Express can.
  • It has a user profile folder that holds everything.  That user profile folder is easy to setup in any partition or hard drive.  My Thunderbird user profile is on my data hard drive so when I do a data backup, I also backup all of my emails, contacts, and settings.
Sky
OP Philip Veteran Member • Posts: 4,009
The worst thing it did was update itself with a new version and doing so erased all the information that I had saved in the folders that I created.  It left the folders but they were empty.
Philip
Not sure why that happened to you but I've done every Thunderbird update for years on both my laptop and tower PCs and never lost a single file in any folder.
Sorry for your troubles,
Sky
filibuster
filibuster Veteran Member • Posts: 3,771
Without logical explanation I was losing emails from a folder of ‘saved emails’ with Thunderbird so I made the switch to ‘eM Client.’
The free edition only permits 2 email addresses, so if you haven’t got the problem of multiple email addresses, this is not an issue.
Very easy to configure and make it look how you want it to look. Best email client I have found, ever.
Quote hhgttg: Life is wasted on the living.
filibuster (Bromsgrove, Worcestershire, UK)
http://picasaweb.google.com/scenic.filibuster
Filibuster,
Thank you for the tip.
Philip
skyglider wrote:  Not sure why that happened to you but I've done every Thunderbird update for years on both my laptop and tower PCs and never lost a single file in any folder.
Me neither.  Cannot understand that unless one of the settings is not correctly setup?  Mine has been working faultlessly for yonks and with 4 e-mail accounts online.  My updates are done automatically too for Thunderbird.
willvan Senior Member • Posts: 2,129
Thank you,
Why not Windows Live Mail?  Works as good or better than Outlook Express and has spell check.  Seems just fine on my Desktop and Laptop using Windows 7 with Windows Pro 64 on Desktop and Home Premium 32 on Laptop.  Seems that anything remotely related to Windows on this forum is a no no.....perhaps with good reason but still used by millions.
Bill
digitalshooter
digitalshooter Forum Pro • Posts: 19,604
cant you use shadow restore to get back? (nt)
Thanks,
Digitalshooter
PS: all posts are just my opinion!
 digitalshooter's gear list:digitalshooter's gear list
Sony Alpha DSLR-A700 Canon Pixma Pro9000 Mark II
Re: cant you use shadow restore to get back? (nt)
In reply to skyglider,
46 min ago digitalshooter wrote:
Hi digitalshooter,
I think you posted to the wrong person.
Sky
