Bokeh samples from same dist. between 200mm @2.8 and 135 @2.0
Started Apr 11, 2013 | Discussions
yoms
yoms Forum Member • Posts: 99
Hello,
There are some test shots out there that compare the bokeh between the Canon EF 70-200mm f/2.8L IS USM II and the Canon EF 135mm f/2.0L USM, but so far I did not find any that compare them from the same subject distance.
Just to clarify: by bokeh I do NOT mean DOF. I can use http://dofmaster.com/dofjs.html to calculate this. It appears that DOF is thinner at 200mm @f/2.8 than 135mm @f/2.0 if subject distance is the same. I am only interested by the look of what is actually OOF in both cases, not in technical/math aspects.
Also, I know that if subject distance is the same, the FOV of a shot at 200mm is narrower than at 135mm. But in real life, this happens too (can't get closer, avoid too much intrusion, etc.) so I really stick to a fixed-distance-from-subject scenario.
Could anyone post or give some links of the "same" photograph taken from the same subject distance at 200mm @f/2.8 with the Canon EF 70-200mm f/2.8L IS USM II and then at 135mm @f/2.0 with the Canon EF 135mm f/2.0L USM ? Just to appreciate the amount and quality of what is actually OOF, that is to say the bokeh.
Many thanks,
Schwany
Schwany Forum Pro • Posts: 10,169
What is the distance?
Bokeh looks best (obliterates the background) near minimum focus distance, but these lenses have different minimum focus distance values. The 135f/2L will focus down to 3 feet whereas the zoom only focuses down to 4 feet. The 135 wins at 3 feet for sure, and probably wins at 4 feet as well, because the zoom has slightly nervous bokeh. It's good, but a little nervous. You don't have to take my word for it even though I have both lenses, but my gut feeling says the 135 is going to be better in the bokeh department.
Anyway, what is the distance to subject you are interested in?
I'm not going to do the test, because I'm not swapping lenses back and forth on the camera I have with the zoom on it. I put the zoom on there so I wouldn't have to swap out primes anymore on that body. It's a dust magnet.
Good luck on your bokeh quest
 Schwany's gear list:Schwany's gear list
Canon EOS-1Ds Mark II Canon EOS 5D Mark II Canon EOS-1D Mark IV Canon EOS-1D X Canon EOS 5D Mark IV +14 more
Kasper FC Regular Member • Posts: 238
Re: What is the distance?
Sounds to me like you don't have the lenses. Are u living in a dessert or something since you can't change lenses without getting the sensor dirty ?
Kasper
 Kasper FC's gear list:Kasper FC's gear list
Canon EOS 6D Canon EF 135mm F2L USM Canon EF 17-40mm f/4.0L USM Samyang 14mm F2.8 ED AS IF UMC Tamron SP 24-70mm F2.8 Di VC USD +3 more
Schwany
Here you go Kasper
Kasper
Does it really sound like that? I don't live in the desert. I just don't feel like doing it, Kasper.
Like it or not, I have every one of those lenses and cameras listed in my gear profile.
Biosphere Regular Member • Posts: 208
Re: Bokeh samples from same dist. between 200mm @2.8 and 135 @2.0
Not exactly what you ask for I know but Photozone compare them at 135mm and 140mm. You don't say what you have seen so at least you know now if you didn't.
yoms
OP yoms Forum Member • Posts: 99
Hi !
Thanks for your reply. I did not specify any distance since I would love to see the results at different distances to make up my mind. If  I had to choose but one distance, let's say in the 10-15 metres range. But again, any link / photos at any distance are welcome.
Thanks you.
misolo Contributing Member • Posts: 945
Just want to add a note regarding DOF and calculators: If you shoot the 135mm at f/2.0, and then crop to about half the pixel count you will get the same DOF as if the image was taken with a 200mm lens at f/2.8 (well, more precisely 190mm f/2.8).
The reason the calculator gives you different results is that it asumes the printing magnification is the same. When you crop and magnify, you increase the radius of the circle of confusion, which decreases the perceived depth of field.
I'm not sure I understand how you plan to use the lens, but if you're going to use the 135mm in a way that you'll be regularly cropping images (in order to get the field of view of a 200mm), the results from the calculator based on 200/2.8 give you a better sense of the DOF you'll be getting than based on 135/2.0.
 misolo's gear list:misolo's gear list
Canon EOS 5D Mark III Panasonic Lumix DMC-GM1 Canon EF 50mm f/1.2L USM Panasonic Lumix G 20mm F1.7 ASPH Sigma 24mm F1.4 DG HSM Art +13 more
MASTERPPA Contributing Member • Posts: 870
I THINK this is what he is asking.
Imagine this. At 200 you are 20 FT from subject and using 2.8. You bokeh will look a certain way..etc.
NOW, take the 135 and place the same subject at 13.5 feet BUT at 2.0.
This way you can see at the same FIELD OF VIEW, how different the bokeh looks at the same feild of view.
I can tell you this, when I shot with my 2.8 100MM from 20 feet, and then shot with my 70-200 F4 at F4 at 40 feet, the bokeh looked VERY different.
But I will also say this, I prefer the get further back, to compress the image as MUCH as possible.
I try to tell this to people all the time, DO NOT SHOOT wide and think you can just CROP the image in and get the same results. Shoot as far away as you can, and zoom in as much as possible.
In my teachings, I shot the same portrait at 45mm, at 15 feet, and then 105mm at 35feet, and the image was A LOT better.
yoms wrote:
Hello,
Many thanks,
This way you can see at the same FIELD OF VIEW, how different the bokeh looks at the same feild of view . . . .
Not really
yoms wrote:
Hello, . . . .
. . . .. Also, I know that if subject distance is the same, the FOV of a shot at 200mm is narrower than at 135mm. But in real life, this happens too (can't get closer, avoid too much intrusion, etc.) so I really stick to a fixed-distance-from-subject scenario.
Could anyone post or give some links of the "same" photograph taken from the same subject distance . . . . .
Schwany
Still no samples
yoms wrote:
Hi !
Thanks you.
No samples for you, but in a 15 meter scenario, I would think the 200mm will have a slight advantage over 135mm due to background compression. I know, seeing is believing...
I looked through some old stuff yesterday out of curiosity, and I don't have much of anything shot wide open with either lens. And I wouldn't have two shots taken with the same camera body of the same subject shot at the same distance with two different lenses wide open. I don't do a lot of comparative lens testing, and that would only be something I would do if I were testing.
"Could anyone post or give some links of the "same" photograph taken from the same subject distance . . . . ."
What is the point of that? 1st, at 200MM the field of view will be different. AND you have the difference between F2.8 and F2.0
So now you have 2 variables. FOV and Fstop.
Not really
yoms wrote:
Hello, . . . .
yoms
I know that. But that is what I am asking for. Then, I know that I can crop after. But that is post processing that I can always do after.
candleJack Senior Member • Posts: 1,453
Re: Nor what you want, but..
I can give you my opinion as a former owner of both these lenses. The 135L bokeh is excellent at any aperture and any shooting distance (according to memory), better that the 85/1.2 at full body shots.
If there was one thing that jumped at me about the 70-200/II as being bad, well, it was the bokeh. Transition areas are quite disturbing in my opinion. It was one of the reasons I decided to sell it. But, of course, this is just one man's subjective opinion.
Best regards,
Alex
>>> /We make a stand now, or there will be nobody left to go to the chopper../
 candleJack's gear list:candleJack's gear list
Canon EOS-1D Mark II N Canon EOS 350D Canon EOS 6D Canon EF 35mm F1.4L USM Canon EF 50mm F1.8 II +5 more
yoms
Best regards,
Alex
Thanks for sharing your point of view. Since bokeh and the look is my main concern I'll probably go for the prime. Better for my budget too. I already own the 70-200 f4 IS.
Schwany
Just when I was about to do the test for you. Kidding
Wise choice if bokeh is what you want.
yoms
No please go for it I would still appreciate to see the result before paying for a lens...
But just just heard about the latest Sigma rumor and since my purchase would occur by october, might worth see what happens...
Schwany
I don't have the street photography gene and I don't do portraits, so I'm not sure how examples from anything I would photograph would help. I'm surprised that some of the street photographers that occasionally post here haven't offered to help you out with this. Whatever I would do as a test would be contrived junk hardly worth looking at.
I have some recent wide open examples of off road bicycle racing from the 70-200f/2.8 II, but the backgrounds aren't real pretty. As has been mentioned by myself and some others, the bokeh from the zoom is a bit nervous unless you are taking a shot at near minimum focus distance. Then it looks alright, but not even close to as good as what comes out of the 135f/2.
This shot might be about the right distance (10 - 15 meters) at f/2.8 at 200mm with the 70-200f/2.8 II. I suspect the 135f/2, which I seldom use anymore and the reason I have no examples, would have a creamier look.
