Lenses for photographing people...
Started Apr 8, 2013 | Discussions
OP richj20 Veteran Member • Posts: 5,893
Re: Lenses for photographing people...
LMNCT wrote:
Very nice work. It seems that any lens can be a "people" lens in the hands of a good photographer.  Good for you!
Thanks for the compliment!
- Richard
 richj20's gear list:richj20's gear list
Panasonic Lumix DMC-GX8 Panasonic Leica 100-400mm F4.0-6.3 ASPH Panasonic FZ1000 Sony Alpha a7R II
OniMirage Contributing Member • Posts: 990
clengman wrote:
clengman wrote:
The full frame equivalent of ideal focal length for portraits is < 50mm. It has only to do with rendering the subject accurately without distortion. That's it.
This is bull. First, where do you come up with "less than 50mm?" Second, what's your definition of rendering accurately? If you take a head shot with a 14mm lens, the camera just recorded exactly what that subject looks like from that distance. That is an accurate rendering. The features may appear distorted relative to the image you have of that person in your mind's eye, but if you put your eye at the same distance that the camera was when you took that head shot at 14mm, your eye will see the same "distortion" that the camera did.
You're talking about aesthetics, not accuracy. The camera is always accurate. The human eye/brain combination applies all sorts of non-optical a priori information before presenting the "perception" that you think you are "seeing".
Um the opening in the symbol is greater than.
http://www.mathsisfun.com/equal-less-greater.html
Distortion...
http://en.wikipedia.org/wiki/Wide-angle_lens
The camera captures a flat plane, a lens adds focal length, a lens is not perfect and can add distortion. In the case of wide angles this can be bad up close for portraits if you intend to be try and capture a faithful head shot for instance.
Sorry buddy that's a "less than" as in 5 < 10.
Quote from the link I gave you, math is fun:
Changing Sides
We saw in that previous example that when we change sides we flipped the symbol as well.
This:   Becky Spends > $0 (Becky spends greater than $0) is the same as this:   $0 < Becky Spends ($0 is less than what Becky spends)
Focal length doesn't add distortion.
Wikipedia:
The focal length of a lens determines the magnification at which it images distant objects. It is equal to the distance between the image plane and a pinhole that images distant objects the same size as the lens in question. For rectilinear lenses (that is, with no image distortion), the imaging of distant objects is well modelled as a pinhole camera model.[3] This model leads to the simple geometric model that photographers use for computing the angle of view of a camera; in this case, the angle of view depends only on the ratio of focal length to film size. In general, the angle of view depends also on the distortion.
Rectilinear lens
In photography, a rectilinear lens is a photographic lens that yields images where straight features, such as the walls of buildings, appear with straight lines, as opposed to being curved. In other words, it is a lens with little or no barrel or pincushion distortion. At particularly wide angles, however, the rectilinear perspective will cause objects to appear increasingly stretched and enlarged as they near the edge of the frame. These types of lenses are often used to create forced perspective effects.
So I suppose a stretched face isn't distorted?
The camera's position relative to the subject can give the appearance of distortion. People think that focal length adds distortion because you have to move closer to the subject for equal framing with a wider lens compared to a longer lens. That's it.
And this is different. Your distance relative to the subject while keeping the same framing gives a different look to the image. Wider angles tend to distort the image more and more the wider it gets. 50mm and above are typically less likely to exhibit this behavior giving a more accurate representation of your subject.
clengman
clengman Senior Member • Posts: 1,964
Distortion...
Changing Sides
... I added no value less than 50 the symbol to represent nothing is 0 therefore anything between 1 and 49.
Just make sure the small end points to the small value!
This: < is a "greater than" symbol in the same way that this: p is a "lower case Q".
Let 's take the example that you provided above. The statement is comparing two values. The first is "the amount of money Becky spends." The second is "$0." Let's assume that the first statement is true ("Becky spends > $0" OR "Becky spends greater than zero dollars."). If we reverse the statement and reverse the symbol this new statement will also be true ("$0 < Becky spends" OR "$0 is less than the amount Becky spends."), but please note that reversing the direction of the symbol also changes the meaning of the symbol.
In your original statement, "The full frame equivalent of ideal focal length for portraits is < 50mm," you are comparing two values. The first value is "the ideal focal length for portraits." The second value is "50mm." The only correct way to read your statement is "the ideal focal length for portraits is less than 50mm."
You're right that you should just be sure the small end points to the smaller number. In your case the small end pointed to "the ideal focal length for portraits" implying that this number was smaller than 50mm. I hope that clears that up.
Wikipedia:
Rectilinear lens
Distorted relative to what? Like I said already, if you take a head shot using a 14mm lens (For the purposes of this thought experiment, place the subject's nose in the center of the frame.) then replace the camera with your head, then look straight ahead with the subject's nose centered in your field of vision. (You will have to use your peripheral vision to see the same angle of view captured by the camera.) the perspective you see with your eye will be the same as the perspective captured by the camera.
If you took the image captured by the camera and printed it and displayed it so that the print covered the same real angle of view in your field of vision as the angle of view represented in the print, it would look almost identical to your perception of the subject when you put your face all up in your subject's face. (I say almost identical because there are aspects of your perception resulting from parallax and binocular vision that obviously wouldn't be present.)
The reason that people think that wider angle lenses introduce "perspective distortion" is that the the image that you have in your mind of a particular person is a composite, an average. You see faces from varying distances, and your mind sums up all these views with all the accompanying changes in perspective and averages them out. When most people recall a face, they see the face as it would appear from maybe 10 or 15 feet away. (Ken Rockwell has a little article that discusses this briefly here. I don't know if I agree necessarily with a specific number of "15 feet" as he states, but the general idea is valid. I think it'd be interesting to learn if someone has studied this. It would certainly be possible to design an experiment to arrive at an average "natural viewing distance" for a group of individuals.)
Anyway, you don't commonly look at faces from a distance of less than around 3 feet, so when you get into focal lengths that require a subject distance of less than this for head and shoulders framing, the subject starts to look a little unusual, but like I said already, this has nothing to do with "accuracy of rendering" or any kind of optical distortion introduced by the lens. This is only a result of the subject distance and angle of view. A rectilinear lens (with no barrel distortion) records an accurate rectilinear projection of a scene. When you "see" (and I'm speaking here of your field of vision, including your peripheral vision, as you look at a point straight ahead) what you are seeing is essentially a rectilinear projection. If you spend some time trying to see this way (Look straight ahead as you're walking around town, but try to pay attention to the appearance of objects in your peripheral field of view as you pass them. Try not to actually direct your gaze upon them.) you'll realize that things at the edges and corners of your visual field really do start to look stretched out as they come closer to you.
As I tried to explain above, it really isn't different.
A rectilinear lens with no barrel distortion just records a rectilinear projection of the scene in front of it.
Perceived "perspective distortion" is purely a result of 1) recording an image from a vantage point closer than what one is accustomed to seeing, or 2) including subject matter from a wide field of view that one might not normally pay attention to because it is at the extreme periphery of the individual's field of vision.
 clengman's gear list:clengman's gear list
Olympus PEN E-PL1 Olympus E-M1 Olympus M.Zuiko Digital ED 14-42mm 1:3.5-5.6 Olympus Zuiko Digital ED 70-300mm 1:4.0-5.6 Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 +6 more
Distortion...
Changing Sides
A math class would be good, not for me though. Your just stretching the reach at this point, though I suppose I was at fault assuming you would know a numerical character would represent focal length measured in MM.
Wikipedia:
Rectilinear lens
Fine but does this distort the features of the subject? For 4/3 sensors (7mm) 14mm would distort features.
Only if the exact focal length is used matching the field of view via two iris's to create a single image.
Would need perfect vision for something like this. Glasses or contacts may introduce variables that would make it hard for such an experiment to be consistent.
Does it not distort? We know an object doesn't look a certain way when we look at an image, our brain knows there is something abnormal about what we are seeing.
clengman
Distortion...
Changing Sides
Look, I explained it the best I could using language from your own example. If you still don't get it, I'm sorry. I certainly don't need any help with this. I learned it just fine in third grade. The short answer is, "<" always represents "less than," ">" always  represents "greater than."
Wikipedia:
Rectilinear lens
No. In fact the human visual field (including peripheral vision) covers a similar angle of view as a rectilinear lens in the neighborhood of 6 or 7mm focal length in terms of a 35mm film format. Objects at the periphery of your vision will appear similarly "stretched" as objects at the periphery of a photo taken with a 6 or 7mm lens on a 35mm sensor.
The perspective effects are entirely due to subject distance.
It doesn't matter if you use a single wide angle image, or several longer focal length images stitched. If they are both created from the same point in space and they both cover the same angle of view, they will look the same.
No. It's got nothing to do with visual acuity. I realize that no one can see with the same detail in the periphery of the visual field that they can in the central portion of the visual field. That's not the point. What you can see is the general shape of large objects on the periphery. I think if you try the experiment I described that you will be able to see what I mean. For instance, walk on a sidewalk next to a high wall and notice the "perspective effect" on the wall immediately to your side.
No it doesn't distort. Our brain tells us something doesn't seem right because it is not accustomed to seeing the object from so close, or because it's not usually as easy to see what is in the extreme corners of the visual field. If you could freeze your entire field of vision, print it out, hang it on the wall and look at it, you would see that it looks very much like a photo taken with a very wide angle lens. Only the central few degrees of the image would be sharp, but the "distortion" would be the same.
Sunny Caribe
Sunny Caribe Contributing Member • Posts: 680
I just want to interject my thanks to you two for the funniest DPR exchange I have read to date.
Rick
Cornmeal, gunpowder, hamhocks, guitar strings.
 Sunny Caribe's gear list:Sunny Caribe's gear list
Olympus Tough TG-3 Olympus Stylus 1s Olympus E-M1 Nikon D750 Nikon AF Nikkor 50mm f/1.8D +11 more
clengman wrote:
Distortion...
Changing Sides
Wikipedia:
Rectilinear lens
Rick
clengman
Yup. I feel for you. It can be exhausting to be so, so wrong. Sorry if your brain hurts.
I like this link from the other thread,
http://www.journalofvision.org/content/12/5/8.full
clengman
I like it, too. But you didn't really read it did you? It has a lot to say about the differing perspective effects that result from varying subject distance, and how it's important to match the viewing distance to the perceived subject distance in order to create a "normal" viewing experience.
I like this quote from that article:
"The apparent expansions and compressions in depth are often called                perspective distortion, as if these effects are due to a distortion in the physical projection from the scene to the film plane. The effects occur, however, when the projections are geometrically correct."
This one too:
"If the viewer's eye is positioned at the picture's COP (center of projection), the image cast by the picture onto the retina matches the image that would be cast by the original scene."
It's similar to what I was trying to explain to you here:
"If you took the image captured by the camera and printed it and displayed it so that the print covered the same real angle of view in your field of vision as the angle of view represented in the print, it would look almost identical to your perception of the subject when you put your face all up in your subject's face. (I say almost identical because there are aspects of your perception resulting from parallax and binocular vision that obviously wouldn't be present.)"
and here:
"If you could freeze your entire field of vision, print it out, hang it on the wall and look at it, you would see that it looks very much like a photo taken with a very wide angle lens. Only the central few degrees of the image would be sharp, but the "distortion" would be the same."
This one too:
and here:
For that same reason you ignore that they agreed with the affects wider angles give and the fact that 50mm and above tends to be more pleasing/ideal/correct
rkhndjr Forum Pro • Posts: 13,082
Thanks for these fine portraits. What metering mode do you use?
Russell Smith
Eternity was in that moment.
You are welcome, Russell! Normally I use center weighted, sometimes spot metering. All of the m4/3 images here were taken with center weighted metering. I'm not sure about the Canon images -- I don't have the RAW files right at hand to check.
- Richard
"Careful photographers run their own tests." - Fred Picker
clengman
This one too:
and here:
I didn't ignore anything. There's nothing I have said that contradicts anything in that article. I never said that wide angle shots don't often appear "distorted" (I don't like to use "distorted" here. I prefer to think of wide angle shots as having an unusual perspective.) I never said that wide focal lengths are ideal for head and shoulders portraits.
I had two quibbles with your first post that I responded to. One stemmed from your poor grasp of symbolic math. Secondly I disagree completely with your wording "It has only to do with rendering the subject accurately without distortion." As I've been trying to explain (and the article backs me up) 1. A rectilinear wide lens renders a scene accurately, 2. "Distortion" is subjective and  3. Perspective effects result from subject distance and angle of view.
"Perspective distortion" is not an inaccurate rendering of the scene and it's not due to any aberrant properties of wide lenses. The perspective effects that you notice are a result of a completely accurate rendering of a scene using a) a closer than normal subject distance or b) a wider than usual angle of view or both. I tried to point out that you can see the same perspective effects without a camera if you put your nose really close to an object, or if you really pay attention to the appearance of large objects at the periphery of your visual field.
If you had instead written "It has only to do with rendering the subject in a pleasing fashion with perspective that corresponds with that of comfortable interpersonal standing distance." (Or something like that...) I would have had nothing to argue about. (Except I still would have wondered why you thought the ideal portrait focal lengths were less than 50mm.)
I feel like this is getting repetitive. I can't really think of any better way to explain this or I would try. If you still don't understand, I guess I'm sorry I wasn't able to make it more clear.
This one too:
and here:
How about I just leave this here then, it confirms without words, it animates it for you and you can come to your own conclusion.
Lindsay D Contributing Member • Posts: 630
There are a number of factors which govern the suitability of lenses for people photography. For example, how much working distance we might have, whether we intend to capture a headshot or a photograph of a group of people, how much light is at our disposal, what the background looks like, and so forth. I've been a professional portrait photographer for a number of years, recently adopting the OMD for most of my assignments. Historically I have almost always used a Canon DSLR and the 70-200 f2.8 IS lens, a massively heavy beast but absolutely ideal for how I work. So there is also an element of personal preference and personal style. I tend to favour longer focal lengths since they are more flattering to the subject and are useful for compressing perspective and are good for "losing" or minimising untidy backgrounds which I will often encounter on location. I normally have sufficient room to move around, since I am usually outside. Moving indoors I would tend to swap to the Canon 24-70 f2.8, but for the tighter shorts I would always favour the longer lens.
So in Micro 4/3 terms I will now spend most of my working life using the 35-100 f2.8 which I think is spectacular for environmental portraiture. When I need a wider view when I have less space then the 12-35 would be ideal - I don't own that one as yet so instead (presuming my subjects are controllable) I will tend to grab my Fuji X100 which has approximately a 35mm field of view.
Examples of the usage of both are here: http://lindsaydobsonphotography.com/blog/location-portraits-hampshire/
If I have time to swap lenses (or I'm in dim light) then I will also use the PL25 f1.4 and the 45 f1.8 - but my overwhelming preference will always be for the longer zooms because I tend to move around a lot and reframe quite a lot, as I will normally shoot concepts and storyboards.
clengman
This one too:
and here:
Fine, it's a good illustration of how perspective changes as the camera to subject distance changes. It also confirms that you still don't really even understand what we're arguing about and that you completely missed the point of the article you linked to.
Now, back to the original argument. In this animation, perspective effects are only changed by changing camera to subject distance, and the only effect of changing focal length in this example is to change the angle of view.
In other terms (camera-subject distance in first frame) < (camera-subject distance in last frame) AND (angle of view in first frame) > (angle of view in last frame). These two facts along with fact that the viewing distance (or output magnification or however you want to think about it) is constant for the whole animation, account entirely for one's perception that in the first frame the cube appears to be stretched and in the last frame it appears to be compressed front to back.
A short focal length rectilinear lens does not distort. It creates a correct rectilinear projection of whatever scene you point it at.
Thank you. I use spot a lot and had a feeling you did.
- Richard
Russell Smith
clengman wrote:
This one too:
and here:
We are only even arguing because you had an issue with the words used and the fact I used a number with a symbol which you disagreed with.
Which can make a persons face appear distorted.
The shorter focal lengths don't look less accurate to represent the model at all, nope.
