Noise averaging handheld bracket
Started Apr 8, 2013 | Questions
markanini Forum Member • Posts: 75
What tools do you use?
 markanini's gear list:markanini's gear list
Sony RX100 II Canon EOS 600D Canon EF 50mm f/1.8 II Canon EF-S 18-55mm f/3.5-5.6 IS II
FrankieJ
FrankieJ Senior Member • Posts: 1,662
Re: Noise averaging handheld bracket
Let's clarify two things first.
1). Noise averaging is usually referred to by the name Image Stacking. Noise averaging is an effect of Image Stacking.
2). Image stacking utilizes multiple exposures of the same exposure value NOT bracketed   exposures, that's HDR.
Software of choice for this purpose: Photoacute
 FrankieJ's gear list:FrankieJ's gear list
Rokinon 8mm F3.5 Aspherical Fisheye (HD)
Sailor Blue
Sailor Blue Forum Pro • Posts: 13,893
Noise reduction can be done by stacking in Photoshop too.
The amount of noise reduction is by the square root of the number of exposures.  It takes 4 shots to double the noise reduction from 2 shots, 8 to double it again, then 16 to double it again.
If you are doing long exposures in low light situations where noise can become a problem then look into astrophotography software.  It is specialized software that allows for dark noise removal and stacking for noise reduction.
Living and loving it in Bangkok, Thailand. Canon 7D - See the gear list for the rest.
 Sailor Blue's gear list:Sailor Blue's gear list
Fujifilm FinePix Real 3D W3 Canon EOS 7D Tamron SP AF 90mm F/2.8 Di Macro +10 more
OP markanini Forum Member • Posts: 75
I'll grant you that a bracket refers to varying exposures. I contend that noise averaging is the right term as stacking can be for different purposes.
