NX300 + 60mm Macro - NO OIS!
Started Apr 5, 2013 | Discussions
timedrun Contributing Member • Posts: 683
Re: NX300 + 60mm Macro - NO OIS!
woah, ex-despot saddam husain's actual yellow leica?
i always liked his gold plated ak47, but this beats even that.
A little green rosetta......a tiny green rosetta........
 timedrun's gear list:timedrun's gear list
Samsung NX20 Samsung NX 30mm F2 Pancake Samsung NX 50-200mm F4-5.6 OIS Samsung NX 16mm F2.4 Pancake Samsung NX 45mm F1.8
OP chrisrabe Senior Member • Posts: 1,591
Turns out that method does not work all the time... Oh well, just going to have to wait for a proper fix...
 chrisrabe's gear list:chrisrabe's gear list
Sony FE 55mm F1.8 Sony FE 90mm F2.8 macro Sony a7R II Sony a7R III Sony FE 35mm F2.8 +5 more
is your lens fw up,to date?
Good question...
Am on firmware version 1 for lens - is there an update somewhere?
viking79
viking79 Forum Pro • Posts: 14,148
chrisrabe wrote:
Good question...
I don't think there are any 60mm macro firmware updates.  For some reason the lens firmware updates are really hard to find on Samsung's site, they are under the NX10.
http://www.samsungimaging.net/firmware-updates-for-the-nx-lenses/
Eric
I never saw an ugly thing in my life: for let the form of an object
be what it may - light, shade, and perspective will always make it
beautiful. - John Constable (quote)
See my Blog at: http://www.erphotoreview.com/ (bi-weekly)
Flickr Photostream: http://www.flickr.com/photos/28177041@N03/ (updated daily)
Sony a7R Samsung NX1 Samsung NX 30mm F2 Pancake Samsung NX 85mm F1.4 ED SSA Samsung NX 60mm F2.8 Macro ED OIS SSA +5 more
Knallberto Veteran Member • Posts: 5,478
wrong! read skill necessary, Sultan of Brunei.
tjobbe
tjobbe Senior Member • Posts: 1,430
chrisrabe wrote:
Just a warning to those who may be needing to use this lens with this camera - you are going to have to wait for some firmware updates, as OIS does not engage on this camera.
Works perfectly on trusty NX1000, so not a lens problem.
tested that on mine and I cannot confirm that. It worked as expected.
Did you first used a Non OiS lens on the NX300 ? As my fear is that the firmware is a bit buggy and potentially only activates a menue item when the the lens attached allows that feature first.
 tjobbe's gear list:tjobbe's gear list
Samsung NX300 Samsung NX30 Samyang 35mm F1.4 AS UMC Samsung NX 85mm F1.4 ED SSA Samsung NX 12-24mm F4-5.6 ED +18 more
hehe, q.e.d.  ... thanx
tjobbe
what it demonstrates is that the FW sometime gets a non defined state(which I can confirm mine had shown as well with the peaking), that could lead to the impression that some feature cannot be enabled...and I believe I had something like that before on the NX20 as well as that depends on the Lens&Body combination as well the sequence of activation.
Please have in mind that not all lens/body combinations allow each feature to be use so you can put Software into some strange state if you use it in a way the QA guys at Samsung did not test that... and I can tell you how Software gets tested....;-)
