Everybody's first prime lens should be this
Started Apr 2, 2013 | User reviews
gajuambi New Member • Posts: 12
Whoever wants to buy a prime lens must choose this over others if they are buying their first. compared to 50mm f/1.8 it is a bit pricey but it is worth it when compared to the quality that you will get. At its wide open f 1.4 it gives is soft but cheesy sweet pics but its sweet spot is f 5.6 and f 8 where it is the sharpest. AF is fast and accurate, build quality is nice and sterdy. too bad it doesnt have an IS (image stabilization) but canon 50mm f 1.2 IS may cost an average photographer his kidneys and liver. no problem with the metering, motor, focusing, sharpness or vignetting. a money well spent if know what a prime is for...
 gajuambi's gear list:gajuambi's gear list
Canon EOS Rebel T4i Canon EF 50mm F1.4 USM Canon EF 24-105mm f/4L IS USM
Prime lens • Canon EF • 2515A003
gajuambi's score
3.5
Average community score
3.7
highland58 New Member • Posts: 9
Re: Everybody's first prime lens should be this
I was actually just looking at a used one of these for 259.95 and thinking about ordering it. I have a 18-135 IS STM and a 55-250 IS that I bought with my new T4i, this seems like a good addition considering that it is f1.4 and the others are substantially slower.
pixseal
pixseal Veteran Member • Posts: 4,061
I sold mine after the second repair for the focus mechanism binding and preventing AF.  The lens shaft that extends (when you focus close) is subject to being distorted when even lightly impacted - this will cause it to bind within the main lens body.
I did like the optical quality, focal length and speed.  It's a shame that Canon didn't design it at an internal focus lens.
 pixseal's gear list:pixseal's gear list
Canon EOS R7 Canon EF 100mm F2.8L Macro IS USM Canon EF-S 10-22mm F3.5-4.5 USM Canon EF 500mm f/4.0L IS II USM Canon EF 100-400mm F4.5-5.6L IS II +14 more
wildwilly
wildwilly Senior Member • Posts: 1,297
I don't think so
My primes include 100mm, 300mm, and 400mm. I don't have nor do I want a 50mm. I guess I am not included in "everybody"
Scott Larson Veteran Member • Posts: 7,505
I've also broken two of them. I guess it would teach a beginning photographer to be very careful with their equipment.
Oddly I've knocked the cheap plastic 50mm f1.8 all around and it still works. It's getting full of dust though.
 Scott Larson's gear list:Scott Larson's gear list
Sony RX10 IV Canon EOS-1D Mark IV Canon EOS 5D Mark II Canon EOS 5D Canon EOS-1D X +17 more
cortlander1
cortlander1 Regular Member • Posts: 448
I had bought the Canon f/1.4 for my son, and then got the Sigma f/1.4 for myself. Both are very good. I am impressed with the solid build quality of the Sigma, but what stands out is the 77mm lens diameter. I have heard issues with focus accuracy, but mine was spot on.
cortlander
 cortlander1's gear list:cortlander1's gear list
Canon EF 11-24mm F4L Canon RF 28-70mm F2L USM Canon RF 100-500mm F4.5-7.1L IS USM Canon EOS 5D Mark III Canon EOS 7D +15 more
Thorbard Contributing Member • Posts: 691
I disagree.
While I'm sure its a great lens, it isn't the be-all and end-all.
There are some really outstanding lenses out there. My personal recommendation for a first would be the newer 40mm f2.8 (sharp wide open, nice rendering of OOF areas, small package).
My own first prime was the 85mm f1.8 (sharp from around f2.4, wonderfully smooth out of focus areas, fast focus with real USM, makes a great sports lens too). Maybe not a great choice for "first" but certainly worth considering.
 Thorbard's gear list:Thorbard's gear list
Canon EOS 7D Canon PowerShot G15 GoPro Hero7 Black GoPro Hero5 Black Canon EF-S 15-85mm f/3.5-5.6 IS USM +4 more
Suave Senior Member • Posts: 2,289
That's just your luck - front element assembly on 50/1.8 is known to pop out from relatively minor knocks.
 Suave's gear list:Suave's gear list
Canon EOS 5D Mark III Nikon D7000 Canon EOS RP Canon EF 24-105mm f/4L IS USM Canon EF 85mm F1.8 USM +7 more
Lemming51
Lemming51 Forum Pro • Posts: 15,278
Re: fragile focus mechanism ==> use the lens hood
Yes, the focus mechanism is not so robust as it should be.  If interested in this lens, get and use the ES-71 II lens hood, or a cheap clone of it.  It bayonets to the fixed outter barrel, and completely shrouds and protects the extending inner barrel.
IMHO, YMMV.
Unapologetic Canon Apologist
 Lemming51's gear list:Lemming51's gear list
Canon EOS 40D Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 70-200mm f/2.8L USM Canon EF 50mm F1.8 II Canon EF-S 55-250mm f/4-5.6 IS STM +5 more
Lemming51
Re: 50/1.8 II
Yep, mine too.  Let it sit a couple years, then got curious and opened it up.  All the broken pieces were still there.  A little 'super glue' and it's back together good (or bad ) as new.
But it is cheap enough to be considered a "disposable lens".
qianp2k Forum Pro • Posts: 10,350
Like most owners, I found this lens is only sharp at least f2.2 or at F2.8 for reasonable sharp at edges. I sold it recently more than original purchase price (bought in Jan '08). I enjoy Canon 40/2.8 STM pancake and 24-70L II these days. At F2.8, both are as sharp as or sharper than 50/1.4 in center and definitely sharper in edges. When stop down, 50/1.4 is sharper than 40/2.8 but not better than 24-70L II. However 50/1.4 has better bokeh when you shoot below F2.8 although not really sharp. It's a good portrait lens nevertheless. Canon should update this 20-yr-old lens with a new design, better build quality 50/1.4 IS lens
Amazingly, you can pop it right back in. In fact you can blow out all the dust in the lens before you do that!
Not always, as pointed out above sometimes a drop or two of superglue is in order.
But that makes it hard to remove the front element again if you want to clean the internal parts of the lens.
photosen Veteran Member • Posts: 6,226
It's what I did, might not be for everyone
The advantage is it will make your jaw drop, never mind the softness wide open and yada yada; the other advantage is it's great for head and shoulders porraits and baby pics on aps-c.
The problem is familiar for aps-c: too long... So you end up looking for something wider which will give you a more normal focal length...
Still, no regrets, mine just performed flawlessly at a wedding.
 photosen's gear list:photosen's gear list
Canon EOS 30D Canon EOS 70D Canon EF 70-200mm F4L USM Canon EF-S 10-22mm F3.5-4.5 USM Canon EF 50mm F1.4 USM +3 more
jackpro Regular Member • Posts: 376
I am thinking the new Canon 35 F2 IS is a good option & ends up a 56mm equiv focal length on aps-c  extremely pricey for a non L  Price:$849.00 US, $1249 in NZ which seems crazy!
 jackpro's gear list:jackpro's gear list
Canon EOS 5D Mark II Canon EOS 450D Canon EF 35mm F1.4L USM Canon EF 85mm F1.2L II USM Canon EF-S 18-200mm f/3.5-5.6 IS +4 more
MAC Forum Pro • Posts: 18,502
that is the better indoor ap-c focal length for sure.  I am waiting too for the price to come down
 MAC's gear list:MAC's gear list
Canon EOS 7D Mark II Canon EOS RP Canon EOS M6 II Canon EOS R8 Canon EF 100mm F2.8L Macro IS USM +7 more
rebel99 Veteran Member • Posts: 4,025
50mm is my least fave FL and i don't think i'll ever own one. my fave prime FLs are 35mm and 85mm and beyond! i particularly don't like this 50mm from canon line up because of its cheesy focusing mech. i have read and  heard some really bad experiences from people who own this lens in these forums!
cheerz.
Mark D Regular Member • Posts: 325
I agree with everything you wrote except one thing.  My copy is very sharp down to f2.8.  And that is where I generally use it.
Dan_168 Forum Pro • Posts: 11,061
That was actually the first I got rid of
That was actually the first prime lens I got rid of (ever since I migrated to digital).
