How to lock 70-300L @300mm ?
Started Mar 31, 2013 | Questions
mermaidkiller Senior Member • Posts: 1,450
This lens (the 'L' version of the 70-300) has a zoom lock but it only works when competely zoomed out (70mm). When at 300mm it does not work.
How can I lock the zoom when completely zoomed *out* ? Is there a trick for it ?
Canon EOS 7
Canon EF-S 15-85 f/3.5-5.6
Sigma 10-20 f/4-5.6
Canon EF 85 f/1.8
Canon EF 50 f/2.5 Macro
Canon Powershot S100
 mermaidkiller's gear list:mermaidkiller's gear list
Sony RX100 VI Canon EOS R6 GoPro Hero7 Black Canon EF 85mm F1.8 USM Canon EF 50mm f/2.5 Macro +5 more
CameraCarl Veteran Member • Posts: 9,204
Re: How to lock 70-300L @300mm ?
You can't.  The lock is intended to keep the barrel from extending while you are carrying the lens, not to lock it at any desired focal length.
Atoche
Atoche Contributing Member • Posts: 682
Are you having a problem with it moving?  Or just accidentally?  or some other reason :).  Mine is tight, and stays at the focal length selected...  but it's only about 1.5 years old.....
"I may be a geek, but it pays for the car...!"
 Atoche's gear list:Atoche's gear list
Pentax Optio WG-2 GPS Canon EOS 7D Canon EOS 6D Sony Alpha NEX-3N Canon EF 24mm f/1.4L II USM +9 more
MisterPootieCat
MisterPootieCat Veteran Member • Posts: 3,123
Electrical Tape?
If it's really important then I would simply wrap some electrical tape around the lens barrel.
 MisterPootieCat's gear list:MisterPootieCat's gear list
Canon EOS 40D Canon EOS 300D Canon EOS 7D Canon EOS 80D Canon EF 50mm F1.4 USM +24 more
Lemming51
Lemming51 Forum Pro • Posts: 15,278
Gaffer Tape
Electrical tape will leave gummy residue.  Gaffer tape can be removed cleanly.
Unapologetic Canon Apologist
 Lemming51's gear list:Lemming51's gear list
Canon EOS 40D Canon EF 50mm F1.8 II Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 70-200mm f/2.8L USM Canon EF-S 55-250mm f/4-5.6 IS STM +5 more
Heritage Cameras
Heritage Cameras Senior Member • Posts: 2,301
A rubber band (or the commercial Lens Band product) can add extra tension to a zoom ring that slips.
Dave, HCL
 Heritage Cameras's gear list:Heritage Cameras's gear list
Canon EOS 5D Sony a7 Canon EF 24-85mm f/3.5-4.5 USM Canon EF 100-300mm f/4.5-5.6 USM +2 more
jjwan New Member • Posts: 1
There is no way to lock it at 300mm, the lock is design for transporting the lens only, so that the zoom will drop if you have the camera pointing down.
 jjwan's gear list:jjwan's gear list
Fujifilm X-T1 Canon EF 200mm f/2.8L II USM Fujifilm XF 14mm F2.8 R Carl Zeiss Touit 1.8/32 Carl Zeiss Touit 2.8/12 +3 more
