NX1000 without OIS vs NX210 with OIS
Started Mar 30, 2013 | Discussions
mindcater New Member • Posts: 4
Hi,
since the NX300 is released, now it is the best time to obtain my first hybrid.
I found some banging deals for NX1000. After my own research the only thing that made me doubt was that the kit lens does not have OIS, while NX210 kit lens has it.
I have not a decent camera and I guess a hybrid makes a perfect solution for me.
My only worry is do I need a camera that does have OIS?
Thank you for the help.
Samsung NX1000 Samsung NX210 Samsung NX300
chrisrabe Senior Member • Posts: 2,001
Re: NX1000 without OIS vs NX210 with OIS
If you are not so concerned about video, then I would not worry too much about OIS at the focal lengths the kit lenses provide.
 chrisrabe's gear list:chrisrabe's gear list
Sony FE 90mm F2.8 macro Sony a9 Sony a7R III Sony a6600 Zeiss Batis 18mm F2.8 +5 more
tufir Regular Member • Posts: 277
The OIS depends on the lens and usually both kit lenses sell very cheap second hand. So in the worst case you can buy the other one later. Still, don't worry to much about it. With that focal lengths you will be limited by subject movement before OIS kicks in.
