need to replace my 17-55 with…
Started Mar 27, 2013 | Questions
paolobernardis New Member • Posts: 11
I sold my lovely 17-55 because of lot of problem with the autofocus. after 3 years of usage with a 40D before and after with a 7D, my impression is that this lens is great from an optic point of view but not very solid. Probably I was a bit unlucky, so I'm looking for a replacement. any suggestion? Another 17-55 (hoping to be more lucky)?
thanks
paolo
Canon EF-S 17-55mm f/2.8 IS USM Canon EOS 40D Canon EOS 7D
Rad Encarnacion Regular Member • Posts: 292
Re: need to replace my 17-55 with…
I believe both Sigma and Tamron produce lenses with the same or similar focal range and aperture.
 Rad Encarnacion's gear list:Rad Encarnacion's gear list
Canon EOS Rebel T4i Canon EOS 6D Canon EF 85mm F1.8 USM Canon EF-S 18-135mm F3.5-5.6 IS STM +3 more
irm Veteran Member • Posts: 3,105
Have you sent it to Canon for repair/adjustment?
The 17-55 f2.8 is the main lens on my 7d took over from a 16-35 f2.8 on 10D and 40D.
my 2 exposed flashcubes worth.
Ian the pbase supporter.
http://pbase.com/ianm_au
Please check my profile for equipment list.
An amateur with dreams of being a good to excellent photographer.
 irm's gear list:irm's gear list
Canon EOS 10D Canon EOS 5D Mark IV Canon EF 50mm F1.4 USM Canon EF 50mm F1.8 II Canon EF 135mm F2L USM +9 more
brightcolours Forum Pro • Posts: 15,885
You can try the Sigma 17-50mm f2.8 EX DC OS HSM
It has comparable optics, a bit less bulk and weight, costs a bit less, and is a bit better built. Maybe it will give you less problems?
OP paolobernardis New Member • Posts: 11
the problem with the lens was tricky. each time that I brought it to the store, it behave perfectly with no signs of this focusing problem. very frustrating...
Re: You can try the Sigma 17-50mm f2.8 EX DC OS HSM
thanks, but i'd prefer to stay on canon.
Johnyguy Regular Member • Posts: 241
Hi i have a 17-55 for sale its like brand new if you interested?
thanks
paolo
James R. McMillan
James R. McMillan Contributing Member • Posts: 523
I have to ask what is the question?  You want to stay with Canon and you want another 17-55.  I think the others assumed that you are looking for an alternative to the Canon 17-55.  When you get a good copy, it is a good lens.  You've read and experienced the problems that some have complained about the Canon....ie, attracts dust, build quality on some....so again what is the question?
KOENIG
 James R. McMillan's gear list:James R. McMillan's gear list
Canon EOS 10D Canon EOS 7D Canon EF 50mm F1.8 II Canon EF 85mm F1.8 USM Canon EF 70-200mm F4L USM +2 more
Sovern Contributing Member • Posts: 907
24-70 2.8 (Tamron) & 10-22 should have you covered.
Didier Thomas New Member • Posts: 5
Hi,
I owned the 17-55 mm. If you don't intend to upgrade your gear with a FF camera, I would recommend to stay with the 17-55 mm. IMHO, it's probably the best EF-S lens Canon ever made.
DT
you centered the problem. i'm very undecided.
option 1: buy another (crossing fingers) 17-55,
option 2: buy a EF 17-40L or
option 3: buy a EF-S 15-85
still undecided
that's an option, but most of the time I prefer to travel light with only one lens. I think that the 24-70 is perfect with a FF, I have a 7D, and the 17-55 is the equivalent of the 24-70.
I also own a 50/1.4 and a 70-200/f4 IS.
thanks
paolo
thank you, I prefer to buy a new one.
best
p.
James R. McMillan
I understand your dilemma.  Good luck with your choice.
KOENIG
Silverwind Senior Member • Posts: 1,344
thanks
paolo
I am curious, what type of AF problems?  Did it work a lot of the time and then inexplicably just focus hunt?  But yet, you could not reproduce it at the store??
happysnapper64 Veteran Member • Posts: 5,421
still undecided
I have the 15-85 on my 7D, but am considering the 17-55f/2.8 for indoor low light shots. The 15-85 is a very good lens & I would not sell it as the FR is great for an outdoor carry round lens, but is not too good for indoors in low light when flash is not allowed.
lee uk.
There are old pilots, & there are bold pilots, but there are no old bold pilots.
 happysnapper64's gear list:happysnapper64's gear list
Canon EOS 5D Mark II Canon EOS 7D Sigma 150mm F2.8 EX DG OS Macro HSM Sigma 17-50mm F2.8 EX DC OS HSM Canon EF 24-105mm f/4L IS USM +6 more
thanks
paolo
Well sometimes when I try to focus with the autofocus the AF system start to go back and forth continuously and is not able to focus to any point. This in turn prevent the shot. This issue appeared not very frequently. And never with the technician. I tried to clen contacts and to change the body, but with no results.
MgrBuddha Junior Member • Posts: 34
still undecided
All excellent lenses. I used to own the 15-85 and it was my main lens for the 650d I had before going FF. If you plan to stay on crop I would still get the 17-55 though, as it is pretty much everybody's favorite EF-S. 17-40L is a good choice (I have that one now) if you plan to move on to FF later. Depending on your preferences it might be a bit limited as a standard lens on crop, but it is a very good lens and a nice wide-angle lens on FF.
 MgrBuddha's gear list:MgrBuddha's gear list
Fujifilm FinePix X100 Canon EOS 7D Canon EOS 5D Mark III Canon EF 14mm f/2.8L II USM Canon EF 50mm F1.4 USM +10 more
