Wide angles with NEX-7
Started Mar 24, 2013 | Discussions
ktveter Regular Member • Posts: 141
I really dont understand why so many dicredit the NEX-7 sel1018 combo. I for one am quite happy with the combo. All but one of the shots below have been pp in lightroom with the new 1018 lense profil.
C&C are as always welcomed.
The Washington Arch
Subway Entrance
Ken
Sony Alpha NEX-7
RezaTravilla
RezaTravilla Regular Member • Posts: 313
Re: Wide angles with NEX-7
great shot!
 RezaTravilla's gear list:RezaTravilla's gear list
Sony RX100 III Nikon D300S Olympus E-M5 II Nikon 1 J5 Nikon AF-S Nikkor 24-70mm f/2.8G ED +7 more
Richard Adrey New Member • Posts: 21
I share your enthusiasm for the SEL1018 and have enjoyed it immensely.
 Richard Adrey's gear list:Richard Adrey's gear list
Sony SLT-A77 Sony a7 Sony 16mm F2.8 Fisheye Sony 20mm F2.8 Sony 50mm F1.4 +10 more
Mel Snyder
Mel Snyder Veteran Member • Posts: 4,088
Those shots are precisely why I love super-wides. If I didn't already own the Tokina 11-16mm f2.8, I would spring for the Sony equivalent (which weighs about the same)
 Mel Snyder's gear list:Mel Snyder's gear list
Sony Alpha NEX-6 Sony a7 Sony E 16-50mm F3.5-5.6 PZ OSS Sony E 55-210mm F4.5-6.3 OSS Leica Summicron-M 50mm f/2 +12 more
Lightshow
Lightshow Veteran Member • Posts: 6,615
Cool shots, thanks for posting them, I too really like wide angle lenses, I can't hardly wait to use my CV15 on a FF body.
 Lightshow's gear list:Lightshow's gear list
Sony Alpha NEX-7 Sony a7R Voigtlander 15mm F4.5 Super Wide Heliar Leica APO-Summicron-M 90mm f/2 ASPH Leica Elmarit-M 24mm f/2.8 ASPH +20 more
J Yohan Regular Member • Posts: 146
Nice shots!
I've been mulling over the SEL 10-18mm. Still not getting consistent feedback on magenta cast with the 10-18/NEX 7 combo.
 J Yohan's gear list:J Yohan's gear list
Fujifilm X100T Carl Zeiss Planar T* 2/50 ZM
Jim Funston Senior Member • Posts: 1,698
Nice shots Ken but in all honesty HDR's and B&W would never show the color shift issue some see with the Nex 7 and the 10-18. Additionally, not everyone uses Lightroom. I use 7 other post processing softwares and Lightroom will not run because one of these other softwares is blocking the path of one of the Lightroom directories. I have spent hours with adobe techs trying to get it to run unsuccessfully.
Glad you are enjoying that combo though.
Color shift issues just bother me too much especially on a Sony dedicated lens at that price. I expected more from Sony... So I am waiting for the Zeiss 12mm hoping they found a way around UWA color shift with the 7. If not? ... Well, I'll cross that bridge when I come to it ....
seachicken2000
seachicken2000 Veteran Member • Posts: 3,236
I'm with you. I have 16Mpixel and 24Mpixel NEXes, and IMO it's better on the NEX-7 because it's sharp enough to exploit the extra resolution. Magenta casting doesn't seem to be a problem if you a shoot around the lens's optimal aperture, which I almost always do.
Great images you posted there too by the way.
"The only thing that gets in the way of a really good photograph, is the camera"
Norman Parkinson
 seachicken2000's gear list:seachicken2000's gear list
Sony Cyber-shot DSC-R1 Sony Alpha NEX-5 Sony Alpha NEX-7 Fujifilm FinePix S2 Pro Sony a7R +21 more
nzmacro
nzmacro Forum Pro • Posts: 15,497
Very nicely done, good eye for a shot and the perspectives are great when this wide.
Danny.
 nzmacro's gear list:nzmacro's gear list
Sony Alpha NEX-7 Sony a7 Olympus OM-D E-M10 Olympus E-M1 +6 more
alextardif
alextardif Senior Member • Posts: 1,376
Great shots!
What is considered to be the optimal aperture on this glass?
 alextardif's gear list:alextardif's gear list
Sony FE 35mm F1.4 Sony a7R III Sony FE 90mm F2.8 macro Sony FE 50mm F1.4 ZA Sony FE 85mm F1.4 GM +2 more
Nexographer Regular Member • Posts: 218
Great shots!
From my experience testing the lens for a couple of days on my NEX-7, stopping down does not improve significantly on the magenta casting issue.
At focal lenghts of 14mm and longer the the casting becomes less visible, enough so that I would say it's not a problem for practical use. For me that was too much of a compromise, that's why I returned it.
I'm curious to see somebody posting full-res shots of the new SEL 20mm with the UWA-converter which should give a pretty nice 22,5mm equivalent f.l. in a compact package. Might become the best solution for NEX-7 users.
 Nexographer's gear list:Nexographer's gear list
Sony Alpha NEX-7 Sony a7 II Zeiss Batis 25mm F2 Sony FE 24-105mm F4 +1 more
seachicken2000
Optimal is somewhere between f/5.6 and f/8, I think. I'll go as far as f/11 if there are foreground elements.
Here's one at 10mm (where the magenta casting should be most pronounced), taken at f/7.1. I haven't applied Adobe flat field correction to it, and I don't think it's needed.
Here's one at 10mm f/4:
It also hasn't been corrected and doesn't need it IMO.
I've taken 500 images so far with this lens. 10% are at f/4, 10% are at f/11 and f/13, and 80% are at the lens's optimal aperture. Of the 10% taken at f/4 half are just test images to see how the lens behaved at f/4, and there are 7 that I would want to apply correction to. These mostly contain blue sky and could/should have been taken at optimal aperture.
The image below is typical, corrected using a brush and a local adjustment in Lightroom.
The images that did actually need f/4 were either night-time (this lens can be hand-held very effectively at night), or indoors and the casting wasn't visible to me in any of these images.
Norman Parkinson
BennyKingston Regular Member • Posts: 166
Those are very nice dramatic shots. I seriously want to get this lens, but think I am going to wait to see if the 7N corrects the magenta issue.
Are any of you with the 10-18 anticipating the 7N this spring, and would you move to it?
OP ktveter Regular Member • Posts: 141
Thanks for the feedback guys. Glad you liked them too.
I really havent had any problems with magenta cast even though I have used this lense mostly wide open and at 10mm, I might have just been lucky though. But at least for us that use lightroom there is a new lense profile out that takes care of distortion and chromatic aberrations.
I will most likely consider the 7n if its priced resonably and I can sell my 7 for a decent price. Mostly because I hope for improvements on the ISO side.
Also very excited to see how the new 12mm zeiss will perform given how happy Im with the 24mm.
Ken
If I have to buy a new camera(7n) so I can buy a Sony UWA (11-18) that works without issues (est combined price would be over $2000 usd for both or more) then I may just bail on my whole NEX system and look at other options. For another $700 I could get a a99 body and use my 11-16 Tokina. For me it is all becoming a matter of economics. I run 3 systems currently. I like the NEX system and was a early adopter of the original NEX 5 but this performance issue with my 7 and the UWA Sony has really festered under my skin to the point it won't take much to make me a two system NEX-less photographer. Two of my systems are the A-mount and E mount so a $700 price difference for a a99 vs a new NEX body and UWA makes one think is small really worth it.
So my answer is no I will not buy a 7n so I can buy and use a Sony UWA.
