Rokinon / Bower / Samyang 8mm f/2.8 fisheye is a winner
Started Mar 21, 2013 | Discussions
boudro_ Senior Member • Posts: 1,190
The lens feels great on the NX210, and it performs very well for the size and weight.  Great sharpness, contrast, and easy to use.  People look good anywhere in the frame, not like rectilinear UWA that distort faces near the edges.
The f/2.8 is only availible for Samsung and Sony mounts, the 3.5 is cheaper, bigger, and less interesting.
 boudro_'s gear list:boudro_'s gear list
Canon EOS 5D Samsung NX210 Canon EOS 6D Canon EF 200mm f/2.8L II USM Canon EF 17-40mm f/4.0L USM +6 more
Samsung NX210 Samyang 8mm F2.8 UMC Fisheye / Rokinon 8mm F2.8 UMC Fisheye
Bryan M
Bryan M Contributing Member • Posts: 956
Re: Rokinon / Bower / Samyang 8mm f/2.8 fisheye is a winner
Let's see more! Did you handhold this shot?
Bryan
www.bcmcue.com
 Bryan M's gear list:Bryan M's gear list
Nikon D750 Nikon Z6 Tamron SP 70-300mm F4-5.6 Di VC USD Tamron SP 70-200 F2.8 G2 Nikon Z 14-30mm F4 +2 more
Knallberto Veteran Member • Posts: 5,478
Wrong.
There exists 7.5mm/3.5, very small for MFT.
http://www.foto-tip.pl/sklep/micro_4_3_mount-c-55_169.html
The "big" 8mm/3.5 fits ALL cameras (one lens + cheap adapters), small 8mm/2.8 version ONLY Samsung OR Sony.
With 8mm/2.8 you get problems with Sony, with 8mm/3.5 you get NO problems with Sony.
Samyang 8mm/3.5 and Samyang 7.5mm/3.5
OP boudro_ Senior Member • Posts: 1,190
There is a 7.5mm but that is for the 4/3 sensor, not APS-C, good for olympus, bad for Samsung and Sony.  I am talking about the 8mm f/2.8, looks almost the same as the 7.5mm.  I am guessing you thought there were only 2 lenses but there are 3.
Yes, the sunset photo was half a second shutter hand held, and it was cold out.
Knallberto wrote:
Wrong.
Samyang 7.5mm/3.5 on APS-C .... hehehehehehe
NEX7 + Samyang 7.5mm/3.5 (MFT) ... heeeello, it's APS-C!
I know 8mm/2.8 making troubles with NEX .... did you see pictures?
http://forums.dpreview.com/forums/post/50999333
I have Samyang 7.5 / 8 / 14 / 35 / 85 ... all excellent lenses,
but I NEVER would buy 8mm/2.8 (for NEX)!
elliotsam Forum Member • Posts: 93
The 8mm is probably my favourite lens
This is a shot I made when I had it on m4/3
tecnoworld
tecnoworld Veteran Member • Posts: 7,232
On several occasions I was almost about to buy the 8mm f2.8 for the nx...would you recommend it or not?
 tecnoworld's gear list:tecnoworld's gear list
Samsung TL500 Samsung NX100 Samsung NX200 Samsung NX300 Samsung NX1 +15 more
Re: Rokinon / Bower / Samyang 8mm f/2.8 fisheye is no winner
ALL pictures I saw with 8mm/2.8 and NEX7 were catastrophal ... you need a color correction program for each photo. Reason seems NEX7-24mp, the effect is not/less with 16mp NEX.
I've NEX5/NEX7 - and noooooo problems with Samyang 8mm/3.5 - this lens has other construction
PS: my 8mm/3.5 fits ALL my cameras, NX, NEX, m4/3, Canon, ...
http://www.getdpi.com/forum/sony/39401-nex7-samyang-8mm.html
http://www.getdpi.com/forum/sony/24738-nex5-samyang-8mm-3-5-a.html
http://www.getdpi.com/forum/4-3rds-cameras/32701-lumix-g3-samyang-7-5mm.html
http://www.getdpi.com/forum/4-3rds-cameras/28373-bats-brownie-samyangs.html
http://www.getdpi.com/forum/4-3rds-cameras/18905-gh1-nex5-3-samyangs-moonlight.html
tecnoworld
Ok, but what about 8mm f2.8 + nx (not nex!)?
I didn't read bad things about ... seems to be okay ... buuuut there are one/two/three (?) users using this combination
I love the lens on the NX210, I haven't seen the same problems the sony people have.
armin304 Contributing Member • Posts: 740
It's a really good fisheye lens with my old NX10, but with my NX20 I don't like it very much. You may see why...
Samyang/Walimex 2.8/8mm, NX20, ooc.
 armin304's gear list:armin304's gear list
Nikon Coolpix P900 Sony a7 II Panasonic Lumix DC-GX9 Nikon Z6
Laurie899 Regular Member • Posts: 150
Hi thanks for your sample showing purple vignetting on the NX20 this was also reported by Eric in October and is the reason I have not purchased this lens.
http://forums.dpreview.com/forums/post/50103219
I am interesed to know if anyone is using the 8mm 3.5 on the NX20 as there is a view being expressed that it is free from this problem - a sample image would be very helpfull
Laurie
 Laurie899's gear list:Laurie899's gear list
Samsung NX20 Samsung NX 18-55mm F3.5-5.6 OIS Samsung NX 50-200mm F4-5.6 OIS Samsung NX 12-24mm F4-5.6 ED Fujifilm XC 16-50mm F3.5-5.6 OIS
ouuuuh, bad! Same like with Sony NEX7. Lens doesn't like 20mp/24mp
I never had any problem with my Samyangs, wether with 8mm/3.5, not with 7.5mm/3.5
I am using 8mm/3.5 with NX10, NX100, NX1000 without any problem.
Thanks that is very encouraging- do you have any samle images you can post please?
Laurie
tecnoworld
After seeing this, I won't be buying the lens...
Re: Rokinon / Bower / Samyang 14mm f/2.8 is a winner
Some pictures with NX10 + Samyang 14mm/2.8
Re: Rokinon / Bower / Samyang 7.5mm f/3.5 fisheye is a winner
Samyang 7.5mm/3.5 and Lumix G3 (m4/3)
