100D/SL1 is not that small
Started Mar 21, 2013 | Discussions
Wellington100 Forum Pro • Posts: 11,807
Its smaller than the OM-D so its tiny
tkbslc wrote:
Looking at the size of this 100D compared to previous entry level models:
http://camerasize.com/compare/#448,218
See here
http://camerasize.com/compare/#448,289
Doctors are bad for your lifestyle.
 Wellington100's gear list:Wellington100's gear list
Ricoh GR Panasonic Lumix DMC-GM1 Fujifilm X-T1 Panasonic Lumix DMC-GX85 Fujifilm FinePix S100fs +12 more
(unknown member) Veteran Member • Posts: 5,590
It seems quite small to me
bobn2
bobn2 Forum Pro • Posts: 71,950
Re: Comparing wrong...
TTMartin wrote:
EvokeEmotion wrote:
Olga Johnson wrote:
Canon also states that the SL1 has a new sensor which is not even shared with the T5i. So it's a different type of smaller dSLR.
You sir, are keeping the Canon marketing (read: hype) department humming.
When the megapixels are the same, the sensor is the same?
So, 24 megapixel sensor in the Nikon D7100 is the same as the 24 megapixel sensor in the Nikon D5200.
Technically, no it isn't. It has the same Toshiba silicon, but the package of the D5200 includes the rear section of the AA filter, while the D7100 sensor package doesn't. That does make for a very slight performance difference. The 24MP D3200 sensor is different again, it is a Nikon sensor - not quite as good as the Toshiba ones, but still quite OK.
Bob
TTMartin
TTMartin Veteran Member • Posts: 7,304
I was actually aware of that. And I was using that point out the error that assuming since two sensors have the same megapixels that they are the same sensor.
But, thanks for being here to defend Nikon.
 TTMartin's gear list:TTMartin's gear list
Canon PowerShot S100 (2000) Canon PowerShot SD1000 Canon PowerShot G1 X Canon EOS 40D Canon EOS 400D +26 more
bobn2
OK, the intent of your post wasn't so clear.
All I'm doing is introducing a few factual facts. It was you that chose to indtroduce a Nikon camera into a thread about the size of Canon cameras, why was that?
Bob
