New iMac (late 2012) color calibration
Started Mar 19, 2013 | Questions
David Crockett Contributing Member • Posts: 662
Just bought a new 27" iMac, was using mac pro 2006 with an NEC multi sync 2090 uxi monitor. Cant use my spectraview, that came with the NEC,  with the iMac so I've been reading about other calibration options and I seem to run into a lot of disagreement as to which profiling product is better. That's to be expected, however there seems to be some forum posts regarding a difference with the new iMacs, versus older iMacs regarding color calibration. So is anyone familiar with a difference calibrating the new iMacs versus the older iMacs and is there a preferred product specifically for the new iMacs and Mountain Lion OS? Thanks.
BeachnCruz Senior Member • Posts: 2,034
Re: Colorimeter and calibration software for New 27" iMac
I recommend you go with an X-rite i1 Display Pro Colorimeter, which comes with X-rite Calibration software compatible with your new 27" iMac and also your NEC Monitor. The i1 Display Pro Colorimeter is also a great match for using with your NEC Spectraview II Calibration software (latest version 1.1.14) when calibrating your NEC Monitor.
Jim
Howard Moftich Veteran Member • Posts: 8,613
Jim's is the correct solution.
Stock i1Display Pro, Spectraview sw, OSX 10.8.3 (has the fix for Mac/nVidia problems)
JulesJ
JulesJ Forum Pro • Posts: 45,069
Re: New iMac (late 2012) color calibration
Yes, I had the same problem with my I-One Display calibrator . Very annoying at I now have to buy a new model. Also I had to buy a £25 adaptor so that I could plug in my G-Tech external drives, bought from ......Apple not long ago. l love Apple prodcts but they certainly push their luck when it comes to comparability. I also have an older Altec Lansing iPod dock/player that now won't charge the later iPods because they changed the wiring order. Also the now iPad Mini has a new smaller socket that you can't share the charger from an older iPad. They know how to make money.
