Wildlife with G3 and 100-300
Started Mar 17, 2013 | Discussions
Solomente Regular Member • Posts: 176
I continue practicing with the 100-300 I got a day and a half ago.  Went out to a nearby nature reserve today and saw some interesting things.  After today I'm totally convinced the 100-300 is a HUGE step up from the 14-140 I had been using (at least for wildlife shooting).  One thing I've noticed though is the pinpoint focusing is far more difficult to use with the 100-300 than it is with the 14-140.  Single point (1-area) focus is working much better for me.  Even when the focus box is slightly larger than the subject, it still hits pretty well.  Pinpoint has become very unreliable for me.
All pics were taken in RAW and processed in LR3.6.  They were taken in coastal South Carolina.
What is this, a song sparrow?  Looks like one but none of my bird books show a yellow bar on the forehead
Male downy
Sweet dreams...
Now here's something I've never seen before!  5 wild baby alligators piled on top of each other!  They were between about 1 to 1.5 feet in length from nose to tail.
 Solomente's gear list:Solomente's gear list
Panasonic Lumix DMC-ZS3 Panasonic Lumix DMC-G3 Olympus E-M1 Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Lumix G 20mm F1.7 ASPH +7 more
Aleo Veuliah
MOD Aleo Veuliah Forum Pro • Posts: 14,768
Re: Wildlife with G3 and 100-300
Favorite is the first picture.
Simplicity is the ultimate sophistication.
Pure logic is the ruin of the spirit.
If plan A doesn't work, the alphabet has 25 more letters, keep calm.
Imagination is more important than knowledge.
God is the tangential point between zero and infinity.
Aleo Photo Site
 Aleo Veuliah's gear list:Aleo Veuliah's gear list
Panasonic Lumix DMC-ZS1 Nikon Coolpix P7100 Panasonic FZ1000 Panasonic ZS100 Panasonic Lumix DMC-GF1 +12 more
Ronald Contributing Member • Posts: 641
Wow
I didnt know there were gators in SC.
Did you use a tripod ?
Ronald Nikon cp4500, tc-e2, canon tc-dc58n, Fuji S9000, Panasonic G3
Ron Evers
Ron Evers Senior Member • Posts: 1,751
Perhaps a Savannah Sparrow.
The wood is clear between the knots.
 Ron Evers's gear list:Ron Evers's gear list
Panasonic Lumix DMC-G1 Panasonic Lumix DMC-GF1 Olympus PEN E-PM1 Olympus OM-D E-M5 Olympus E-M5 II +15 more
dafus Junior Member • Posts: 28
My wife also votes Savannah Sparrow.   (The yellow lores are quite variable.)
 dafus's gear list:dafus's gear list
Panasonic Lumix DMC-GH2 Panasonic Lumix DMC-G3 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Panasonic Lumix G Vario 45-200mm F4-5.6 OIS +7 more
OP Solomente Regular Member • Posts: 176
Thanks all! Just looked up Savannah Sparrow online and that definitely appears to be it.
No tripod, all hand held. I accidently left it at home
eagle_I
eagle_I Senior Member • Posts: 2,670
Nice shots ... I enjoyed them!
One of my problems with pinpoint focus on the GH3 with the 100-300mm at full zoom is I cannot hand hold steady enough and frequently miss the spot I wanted hitting something else instead.   On the plus side it's made me concentrate much more on getting a steady hold ... tho being a shaky old guy sometimes no amount of concentration can stop my wiggles.  So sometimes I use pin point sometimes I don't.  I do like having the choice tho as it's a cool new feature for me
One thing that has helped me a LOT in focusing my Panny's at high telephoto is to PRE-focus on a spot CLOSER to me than where I anticipate I'll need to get a quick focus.  The hummingbirds I shoot don't give me much opportunity making only very short stops on a nearby branch ... so I gotta be ready.  If I don't to a close PRE-focus it'll almost always lock on to something behind the bird.  From a spot I frequently stand to get view of the tree where the birds land there's sharp spiny leaf plant below and close to me.  A quick point at it and half shutter press gets me set to grab as quick shot.
Mark
Thanks Mark! I will definitely try that focusing tip you mentioned.
howardfuhrman Veteran Member • Posts: 4,153
The photos are well composed and with interesting subjects, but to me the photos are OK but a little soft. It could be my monitor or it could be that you hand held them (but your shutter speed seems to be high enough), used too high an f stop, the AF may have focused in the wrong spot. From my experience I have a lot of difficulty hand holding a long lens to focus on anything--a small movement on my part and I cannot find my subject without making the lens wider.  Again, I want to be constructive not ciritcal, the photos do not appear to tack sharp.  I used a G3 until I upgraded to a G5 and got excellent IQ with the 20 1.7, 45 1.8 and 7-14mm. My results with the 45-200 were marginal and I have never used the 100-300, but have read it is a better lens than the 45-200.
My suggestions is keep experimenting with the G3 100-300 combination.  Use a tripod with the stabilization turned off and see and evaluate your results, open the lens, use a lower ISO, shoot at 250mm rather than 300mm (I saw you used various focal lengths in the photos that you posted).  Be sure that your lens is clean.
Good luck and thanks for posting.
Hi Howard, I appreciate the criticism. I had intended to take my tripod that day but just forgot it. I do plan to try it next weekend and see if I get better results. But to address some of the specific points...
First, discard the 5 alligator shot as that was just something interesting, not a good photo. There was no way for me to get into a good position, as evidenced by all the busy reeds in the foreground. For the others, all are crops from the original image, in some case for more reach and in others just to get a better composition. The birds move so fast I always just worry about getting them in focus and snapping, knowing I can adjust the composition in PP. The cropping no doubt comes at a cost of sharpness. Also, I have the 20mm and 45mm and I don't think the 100-300 will ever yield results as sharp as they can produce. All that said, you and others have offered some good feedback and techniques that I will experiment with and hopefully improve my results. You can be the judges, as I'll be sure to post my results in the future
Thanks again for looking and critiquing!
